Differential fluid for 140k 2004 tundra 4wd?
Discussion in '1st Gen Tundras (2000-2006)' started by SvIsaac, May 21, 2021.
  1. May 21, 2021 at 5:27 PM
    SvIsaac
    SvIsaac [OP] New Member
    Isaac
    2004 tundra limited 4wd v8 4.7L
    I've been asking local mechanics and they don't know the answer. I've tried calling the dealership where my truck was purchased from but they haven't returned any calls all week about this question.
    I recently replaced a bad axle and while doing so I lost a decent amount of differential fluid. Im not too sure what to use to top off, and since I'm sure it hadn't been changed in years im just going to go ahead and replace the front rear and transfer. Not sure what I should be using though.
    EDIT: just got off the oil with the dealership and its 75w90 GL5. still pondering over what brand to get. I do a lot of off roading and occasional towing.
  2. May 21, 2021 at 6:53 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
  3. May 21, 2021 at 7:21 PM
    SvIsaac
    Isaac
  4. May 22, 2021 at 9:22 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
  5. May 23, 2021 at 5:25 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
  6. May 23, 2021 at 11:06 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    It's non-synthetic, it is the right 'weight' and of the 15+ oils I've tested for both grip (lockup) and chatter (parking lot turns) it was the best. It has the proper amount of friction modifier in the fluid already. Just enough that the LSD still works great.
    Clutch type LSD's don't work as good with synthetic oils. And thats why all the aftermarket LSD's do not recommended to use it with them.
    I've tried oreilly/kragen, autozone, napa, walmart brands; also valvoline, mobil, amsoil, redline, etc. All of those in various weights, synthetic and non-synthetic and with/without adding friction modifier.
    This was done on my Cusco RS 2-way LSD, which is much better than the OEM.
