Different Size Spare Tire
Discussion in 'Wheels & Tires' started by DanTundra, May 7, 2022.
  1. May 7, 2022 at 6:42 PM
    DanTundra
    DanTundra [OP] Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    I'm running 285/75/18 Falken Wildpeaks 34.8" tires, and been searching for a used tire as a spare with no luck.
    I was able to find some Michelin 275/70/18 33.2" tires on Facebook for $40.
    Would I be able to run this as a spare tire without any issues in case I needed to use my spare?
    Or should I try and find the exact same size spare tire?
  2. May 7, 2022 at 7:12 PM
    biebs96
    PA
    Keep yours out or call your local tire shop and ask them to keep you in mind.
    I found a used matching spare from a member on here a year ago. It probably only has 5-7500k miles left on it, but it is the correct size, fits the stock rim and eliminates my fear of needing to drive any type of distance home if I got a flat.
  3. May 7, 2022 at 7:13 PM
    biebs96
    PA
    Side note, I am also 285/75/18 and that tire on the stock rim will fit in the factory spare location.
