Difference between Internal vs Remote Reservoir on Shocks
Discussion in 'Suspension' started by vanthesupreme, Apr 3, 2020.
  1. Apr 3, 2020 at 2:05 PM
    vanthesupreme
    vanthesupreme [OP] I'm Batman
    OKlahoma
    2014 Tundra
    I have been looking at replacing my front shocks since I will be putting an aftermarket front bumper. I cannot tell what the difference is between an internal reservoir vs remote reservoir when comparing aftermarket shocks. I have looked at many different companies but the two below are just for reference.
    https://realtruck.com/p/icon-vs-2-5-series-coilover-shocks/v/toyota/tundra/2014/
    Any input would be greatly appreciated. Thanks in advance
  2. Apr 3, 2020 at 2:16 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Internal has the fluid inside the shock....remote has the fluid external to the shock, stored in another tube or receptacle and there is a tube that feeds fluid to the shock. The benefit of remote- holds more fluid and the fluid remains cooler, less froth...so better shock performance.
    They look great but you may not need remote shocks...they are helpful for heavy off-road use. If mainly street driven, the extra cost may not be worth it for you.
    vanthesupreme[OP] likes this.
  3. Apr 3, 2020 at 2:28 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Aren't externals for folks Needing extra range of shock motion due to body and suspension lifts in offroadie situations?
  4. Apr 6, 2020 at 4:42 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    The remote reservoir has oil and nitrogen in it. The remote reservoir allows for less pressure inside the shock, and smoother compression.
    https://accutuneoffroad.com/articles/the-difference-between-emulsion-remote-reservoir-shocks/
  5. Apr 6, 2020 at 4:46 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Make sure you get a heavy enough spring rate to accommodate the bumper that’s more important than the resi. If your working it hard Offroad then get remote resi’s. If not stick to internal. Unless you find a good deal on a set with remotes.
  6. Apr 6, 2020 at 4:48 PM
    AccuTune Offroad
    El Cajon, CA
    Correct spring rates and valving yes. Its very common to over spring a coilover, which can result in a harsh ride.
    xtyfighterx likes this.
