Diff an trans oil
Discussion in 'General Tundra Discussion' started by Bigdog, Mar 25, 2019.
  1. Mar 25, 2019 at 4:40 AM
    Bigdog
    Bigdog [OP] New Member
    2014 sr5 tundra 4x4
    7 inch pro comp lift 37 12.5 nitro ridge grapplers 639 k&n cai hyperforce interceptor tuner
    Changing oil in all three just a quick inquiry what is the thoughts on Lucas synthetic 75-90 gear can get on Amazon preety decent$for what i need
  2. Mar 25, 2019 at 4:53 AM
    15whtrd
    15whtrd Mr. Blonde
    Transmission or transfer case?
  3. Mar 25, 2019 at 4:55 AM
    Bigdog
    2014 sr5 tundra 4x4
    Just front rear diffs an transfer case
  4. Mar 25, 2019 at 5:02 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t know if they changed the transfer case in 2014 or 15, previously you could use the same oil as the differentials in the transfer case. Now they require 75W in the transfer case. Refer to the manual for specs.
    Trooper2 likes this.
  5. Mar 25, 2019 at 5:05 AM
    Bigdog
    2014 sr5 tundra 4x4
    Ya know I think I'll just stick to Mobil 1 synthetic its what i run in motor oil the 0 20 so for 12 quarts an pump an gaskets yes i know but try an find straight 75 yes the German company has it trust me I've read all the post on subject thanks for your input got to go BigRig pulled in got to go do some wrenching
  6. Mar 25, 2019 at 5:13 AM
    sundance
    sundance New Member
    Been running the German 75 for a few months now in my 14 Transfer and the transfer case shifts in an out better.
    Either way, I wouldn't change it. My old transfer case oil was virtually clear. I doubt I'll change the transfer case oil again.
    You can find Redline synthetic gear oil in the right spec...... rather cheaply. 75w-85
  7. Mar 25, 2019 at 5:16 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Here you go. Buy online.
    Front differential, rear differential: Red Line 75W85 Gear Oil. They just recently offered this weight that matches Toyota's spec perfectly. They also have a 75W90 (what I'm using) that works fine.
    Transfer case: Ravenol 75W.
    brewster7 and 15whtrd like this.
  8. Mar 25, 2019 at 5:25 AM
    sundance
    sundance New Member
    I bought mine here. Cheapest I found it.
    https://www.rvautoparts.com/50104-Red-Line-Oil-Gear-Oil-Single_p_387665.html?
