Did I blow my shaft seals?
Discussion in '2.5 Gen Tundras (2014-2021)' started by jayhawknavy02, Sep 4, 2020.
  1. Sep 4, 2020 at 6:33 PM
    jayhawknavy02
    jayhawknavy02 [OP] New Member
    SOCAL
    2017 Tundra 5.7L SR5 Crew Max TRD Off Road 4x4
    Dirty Deeds 10” exhaust TRD Accelerator OTT Tune Sony XAV-9000ES Head Unit AJT Interior Upgrades
    Sorry for the noob post. I just greased the propellor shaft on my 2017 4x4 CrewMax Tundra. Felt like there was no grease...thanks Dealer but only about 10,000 miles. Soooo I kept going and as soon as grease purged I stopped and wiped off the excess.
    Speaking to my old man and brother they told me I probably just blew the seals and no grease should have escaped. I read the manual, Haynes, forum, etc. no warning of this but no excuses either.
    Did I do things as I should or am I looking at new seals....
    https://www.tundras.com/threads/wan...erly-lube-the-drive-shaft-in-my-tundra.29912/
  2. Sep 4, 2020 at 6:36 PM
    It's quite common to pump new grease in until the old grease is out and any air bubbles.
  3. Sep 4, 2020 at 7:01 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    When you hear the crackling the joint is full.
  4. Sep 4, 2020 at 8:02 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Grease until all 4 caps of the u-joint purge, and all 4 caps should.
    Source: Spicer driveline service literature, and Spicer makes the driveshafts for our Tundras.
    What you’re being told is a common wive’s tale. Not that wives are always wrong, just ask mine. :D
    Txexplorer23 likes this.
  5. Sep 4, 2020 at 8:17 PM
    jayhawknavy02
    SOCAL
    well that’s 1, badass, Spicer makes amazing stuff and 2, a huge relief.
    Thanks everyone for the assistance
    landphil[QUOTED] likes this.
  6. Sep 5, 2020 at 6:25 AM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    yep, and not just to where you see some grease coming out. Spicer says pump until you see new grease coming out from each cap to ensure most of the old worn stuff and any contaminants it contains is purged from the bearings.
  7. Sep 5, 2020 at 6:31 AM
    Professional Hand Model
    Hand Protectors
    There is a splatter area on my upper chassis frame from grease fling/spin off that purges out after the years of pumpings. Situation Normal.
  8. Sep 5, 2020 at 7:15 AM
    Cthulhu
  9. Sep 5, 2020 at 7:37 AM
    NorthWoodsTundra
    NorthWoodsTundra Hehehe, you said 'member'...hehehe
    2021 GMC 3500 SRW Gasser
    Ha you beat me to it, lol!
  10. Sep 5, 2020 at 8:14 AM
    jayhawknavy02
    SOCAL
    That's what I did (excluding the seal). I took a rag and tried to clean up the grease as best I could, but I let the shaft do its thing and finish the job and wipe up the excess after it spins off.
    Thanks again gentlemen
  11. Sep 5, 2020 at 8:15 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Cthulhu likes this.
