Decked system vs Bed slide????
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bmendez1124, Jan 3, 2019.
  1. Jan 3, 2019 at 4:30 PM
    Bmendez1124
    Bmendez1124 [OP] New Member
    Modesto, CA
    2016 Tundra Crewmax
    ◾️Mod List: 2016 MG Tundra Crewmax ◾️Rims: @methodracewheels — Con6 18x9 ET +18 ◾️Tires: @bfgoodrichtires — KO2’s 35x12.5x18 ◾️Suspension: @kingshocks ◾️Headlights: @spyderauto ◾️Fog lights: @cali_raised_led ◾️Bed Rack: @max_modular_truck_bed_racks ◾️RTT: @tepuitents — Explorer Kukenam 3 ◾️Tanks: @rotopaxofficial ◾️Suspension/Wheels/Tires work: @88rotorsoffroad — One of the best spots for any of your truck work.
    How's it going just wanted opinions on the decked system vs bedslide. We go camping often now and like the storage of a decked system but also like that with the bed slide it makes a majority of the bed accessible to whatever is placed on the slide. Just asking for pros and cons from people with either system or what they've noticed from friends with the systems. Thanks!
    OR18TRD likes this.
  2. Jan 3, 2019 at 4:33 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Had a bed slide in my 06 Dodge, liked it, made stuff easy to load and unload, but had issues of stuff falling off in front of the wheel wells, being hard to retrieve.
  3. Jan 3, 2019 at 4:37 PM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Went with BedSlide under a truck cap as well.
    I stick stuff in for forward corners in front of the wheel wells I don't need or use often, but want in the truck - plastic ammo box of medical and water purifier supplies in 1 corner, and rubber boots and QBeam in the other front bed corner. Never gets in the way of the Slide, and no trouble loading cargo so far. Depends on how and what you need to load.
    Getting too old with bad knee to be crawling up into the bed all the time.
    bmcdds likes this.
  4. Jan 3, 2019 at 4:40 PM
    Sunnier
    Sunny
    San Diego, CA
    I'm thinking about a bedslide and research already had me convinced I'll get low side rails mounted on the portions nearest the cab, anticipating that otherwise, stuff will fall off.
    I still think bedsides will work better for me than a decked system because I want to store spares and bins with equipment. The decked system doesn't allow me the same flexibility as bins secured with bungees, on a bedslide.
  5. Jan 3, 2019 at 4:42 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    I plan on getting a cap as well and have a dog that will be traveling so placing a dog crate in the bed with either system. I agree trying to access things in the back of the bed gets tiresome over time and like having the ability to slide it all out with the bed slide also if I end up with a fridge adding that to the slide.... any pics of your setup by chance @tundracap
  6. Jan 3, 2019 at 4:47 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    I kinda have been leaning away from decked I like the security of a decked system but not sure if it will have enough space for storage we carry larger bins with our sleeping bags etc. and not having a cab cover yet I can't feel comfortable leaving items in the bed.
    Sunnier[QUOTED] likes this.
  7. Jan 3, 2019 at 4:53 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Icon 17 rebounds, total chaos UCA's, general grapplers 35's, corsa exhaust chopped, fox 2.5 DSC coilovers, DAP, white knuckle sliders, voodoo bed rack, baja lights everywhere, VLEDS, bedslide, C4 front bumper, warn winch, victory high hitch with dual swing out rear bumper
    Like others have mentioned it's how you plan to use it. I have a bedslide with open bed and voodoo bed rack. I like my set up for camping. I have tons of space to load gear with ease with the slide. Plus I have tons of room to mount things to my voodoo rack. My hi lift jack, roto packs, maxtraxx, bike mount etc.. all on my bed rack. And all my storage containers, yeti cooler and other crap on the bed slide. For me the decked system is nice if running a shell or open bed. If you run a bed cover and deck system, it really limits you on the vertical space you have available from the deck drawers to the bed cover. I also have the option of running a roof top tent on my voodoo rack like many members here, but I prefer ground tents.
    Sas and OR18TRD like this.
  8. Jan 3, 2019 at 4:57 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Perfect!!! :thumbsup: That's exactly what I was thinking also what mounting plates are you using for your axe and shovel??? Those are next on my list of items to add for gear @pdiddy
    pdiddy[QUOTED] likes this.
  9. Jan 3, 2019 at 5:00 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Rago fabrication is the mount I am using for my quick fist mounts for my axe and shovel on my cab side rail. I also use their fire extinguisher rail mount on the side rail for my fire extinguisher. Sorry the pics I have posted are a little old. I can try to take some pics tonight if you need, let me know.
    Sunnier and TheBeast like this.
  10. Jan 3, 2019 at 5:02 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Man that would be great if you didn't mind I wasn't sure where I was gonna locate my shovel axe and fire extinguisher but now seeing your setup it's def a nice locatio
    TheBeast likes this.
  11. Jan 3, 2019 at 5:04 PM
    tundracap
    NC
    Been looking at the Rago brackets for several things I have in mind.
  12. Jan 3, 2019 at 5:10 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    Lol yeah I was like you I was about to mount to my voodoo rack but like the inside with rago better. I'll try to snap some pics for you
  13. Jan 3, 2019 at 5:11 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    They make quality stuff and it's not cheap but very well built (over built). I am waiting for their large battery tray for the tundra
  14. Jan 3, 2019 at 5:15 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Def gonna look into their stuff you get what you pay for
  15. Jan 3, 2019 at 5:23 PM
    tundracap
    NC
    I had ordered some MOLLE panels from Rago in late November. Hadn't heard from them for a month. Called twice and they couldn't even give me a time when they would ship, so I cancelled the order and they refunded my $.
    They still have some products I am interested in though. First order just didn't work out for me.
    pdiddy likes this.
  16. Jan 3, 2019 at 5:26 PM
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    Not decked but I have a bedslide and Truckvault setup mounted in an open bed with BAMF full bedrack. I run it both ways
    -bedslide only
    -bedslide mounted on top of Truckvault
    I tend to run the bedslide only a lot more often. Drawers are great for daily gear and tools but camping I prefer the bedslide loaded up with waterproof gear containers arrows or netted. I also like bedslide only for mountain biking so I can load them up. I don’t have that option with the Truckvault due to the height.
  17. Jan 3, 2019 at 5:29 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Nice really clever and kinda does the best of both worlds
  18. Jan 3, 2019 at 5:31 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    What rack system is that?
  19. Jan 3, 2019 at 5:35 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    I think it's from BAMF they make some quality racks
    Juddrussell likes this.
  20. Jan 3, 2019 at 5:43 PM
    Juddrussell
    Jacob
    Bentonville, AR
    Yep, BAMF. Jerry knows what he is doing for sure, this is an early version of the rack. He has made a few iterations to his design since. Hands down best looking rack on the market
  21. Jan 3, 2019 at 5:50 PM
    FXFormat
    FXFormat New Member
    I love my DECKED system, great for camping, throw a camper shell on the truck bed and you've got a queen sized sleeping area there.
  22. Jan 3, 2019 at 6:20 PM
    bito
    bito New Member
    Somewhere on the decked site they showed how to add a bedslide. Or used to anyways.
    Sas likes this.
  23. Jan 4, 2019 at 8:37 AM
    pdiddy
    pdiddy New Member
    2017 platinum
    @Bmendez1124,
    Here are some pics of my set up, hit me up if you have any questions.IMG_1973.jpg IMG_1974.jpg IMG_1975.jpg IMG_1976.jpg IMG_1977.jpg
    Krewcial, saybng, Hammerhead and 3 others like this.
  24. Jan 4, 2019 at 8:55 AM
    cantle
    cantle New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    You have the exact set up I have been thinking about. Couple questions for ya:
    1. How hard is it to load a bike up on top of the rack? I'm 5'8" and am thinking I'll probably need a tire step or something?
    2. How is the install on the bed slide?
    3. Any thoughts on the full height vs. partial for the KB rack?
    4. Is there anyway to lock stuff to those Rago brackets, other than the obvious cable through handle or something?
    Thanks, truck looks great with the bed storage option!
    Sunnier likes this.
  25. Jan 4, 2019 at 9:03 AM
    cantle
    cantle New Member
    Durango, CO
    My issue with the decked and TruckVault systems is they just seem very inefficient in terms of space usage. IE, you lose the volume on the sides.
    Rolling Biome, Sunnier and pdiddy like this.
  26. Jan 4, 2019 at 9:33 AM
    pdiddy
    pdiddy New Member
    2017 platinum
    Thanks love this new set up, ditched my first set up which was lesson learned and hurt my wallet a bit. I originally had a pace edwards roll up cover with rails and had yakima bars. That set up pretty much sucked no room for anything
    cantle[QUOTED] and Sunnier like this.
  27. Jan 4, 2019 at 9:48 AM
    pdiddy
    pdiddy New Member
    2017 platinum
    cantle fyi I responded to each of your questions by each number lol
    cantle[QUOTED] likes this.
  28. Jan 4, 2019 at 3:17 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Very well done man def am gonna take some ideas from you my questions are what brackets did you use for your water tanks near the tail gate I really like that option and setup
    Sunnier likes this.
  29. Jan 4, 2019 at 3:34 PM
    pdiddy
    pdiddy New Member
    2017 platinum
    I believe they are fisk racing fuel cans on Amazon and you can purchase with a mounting bracket. I screwed down to my bed floor with metal screws. I think they are meant to hold fuel but don't see why not you wouldn't be able to use for water. FYI if you are in cali they won't ship something with EPA goes for roto pax as well.
    Sunnier likes this.
  30. Jan 4, 2019 at 3:39 PM
    Bmendez1124
    Modesto, CA
    2016 Tundra Crewmax
    Yea I’m Cali gotta love our stupid regulations that’s for the info
