Decal remover did something weird to my paint
Discussion in 'Detailing' started by 70m4h4wk, Jan 28, 2021.
  1. Jan 28, 2021 at 4:28 PM
    70m4h4wk
    70m4h4wk [OP] New Member
    Vancouver Island
    23 Silverado LT, CCSB, 2.7L Turbo
    0/2 Level
    I debadged my truck the other day, washed it, and then took a decal remover to the sticky bits left by the badges. It worked great, and all the stuff came off, but it left weird marks in the paint. It doesn't look like it scratched anything, but washing the spots doesn't seem to help. Is this something I can fix by waxing the truck? Or is there another way to fix it?
    There's also some road dirt on there now, but the obviously smudged parts is what I'm talking about.
  2. Jan 28, 2021 at 4:35 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    get some polish go over that area, then follow up with a coat of wax. May take some elbow grease, it is not going to be a wipe on, wipe off situation.
    BlueRibbon4x4 and 70m4h4wk[OP] like this.
  3. Jan 28, 2021 at 4:36 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Did you polish they area?
    After I roved mine, I washed it, rinsed it, then played those areas
    70m4h4wk[OP] likes this.
  4. Jan 28, 2021 at 4:37 PM
    70m4h4wk
    Vancouver Island
    0/2 Level
    I didn't polish it, just scrubbed it with a couple different car scrubbers I had around.
    So a wash, polish and wax should fix it?
    BravoDeltaRomeo likes this.
  5. Jan 28, 2021 at 4:38 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Not sure. But from my own experience, I had ghosting and odd marks until after I did.
  6. Jan 28, 2021 at 4:39 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    rubbing compound and polish :sawzall:
  7. Jan 28, 2021 at 4:40 PM
    70m4h4wk
    Vancouver Island
    0/2 Level
    Sounds like as good a place to start as any
  8. Jan 28, 2021 at 4:41 PM
    P-Factor
    P-Factor New Member
    WD40 will most likely be your friend (without being abrasive) cleaning up residue. :thumbsup:
    70m4h4wk[OP] and BravoDeltaRomeo like this.
  9. Jan 28, 2021 at 4:42 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I used Auto GooGone
  10. Jan 28, 2021 at 4:42 PM
    frichco228
    yep, and probably should watch using car scrubbers, easy to scratch the paint. Wash the truck, then you can get some cleaner/polish and it will clean that up. Follow up with some wax. Use microfiber or something soft.
  11. Jan 28, 2021 at 4:44 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    How long have the badges been on there? Please don't say 2007.
  12. Jan 28, 2021 at 4:48 PM
    70m4h4wk
    Vancouver Island
    0/2 Level
    I wish I had known that a few days ago. Residue is gone, just the smudges now.
    They were just microfiber ones, said they wouldn't scratch the paint. What do you recommend for polish/wax?
    They were on since 2007. Did I screw up? Are they collectible now or something?
  13. Jan 28, 2021 at 5:05 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    The paint will likely be brighter under the badges, where it has been hidden from the sun and other elements for 14years...that's all.
    70m4h4wk[QUOTED][OP] likes this.
  14. Feb 1, 2021 at 3:32 PM
    Tundra SiR5
    Tundra SiR5 New Member
    I used the turtle walk label and sticker remover spray from autozone. Worked perfect no residue left.
    As far as your truck goes rubbing compound and wax, or have it polished and waxed.
  15. Feb 1, 2021 at 3:42 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    I used Goo Off and some good ole elbow grease , took a bit but it all came off.
  16. Feb 1, 2021 at 3:45 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Same thing happened to my 4runner; dirt gets behind the badges and roughed up the paint. Being an 07 that’s a long time to be unexposed to the sub and elements....It will always look like that unfortunately. You can try rubbing compound and polishing wax. It will make it look better but you’ll always see that “box” unfortunately
