Dash Squeak
Discussion in '1st Gen Tundras (2000-2006)' started by FirstGenVol, Dec 28, 2019.
  1. Dec 28, 2019 at 7:32 PM
    FirstGenVol
    FirstGenVol [OP] Brake Czar
    East TN
    2002 AC
    Edit-picture and fix on page 2, post 49
    Based on comments from the other thread there are at least 3 of us dealing with this. It's been driving me nuts since I bought the truck 4 years ago.
    When I had the radio out last year I both looked back behind the dash and felt. I couldn't determine where the noise is coming from. I even tried shoving stuff in between the dash and windshield.
    Has anyone successful fixed this problem? It makes every bump in the road that much more annoying.
    @abcinv @CodyP
    https://youtu.be/2sK79WMtskw
    Bulldog_tundra likes this.
  2. Dec 28, 2019 at 7:39 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Some guys have stuffed rubber strips or foam matting back there between dash and windshield. Mine hasn't squeaked so I haven't looked into it.
  3. Dec 28, 2019 at 7:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That would drive me nuts as well. If it were mine i would use some silicone spray with the small tube attached and give it a spray between the dash and windshield.
  4. Dec 28, 2019 at 7:44 PM
    FirstGenVol
    East TN
    2002 AC
    So this was a known issue from the old Tundra forums? I just assumed I was unlukcy.
    Since I just got a box of Noico I may try to save a few tiny strips to stick there, or see what else I have laying around.
  5. Dec 28, 2019 at 8:20 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I think mine does this every once in a while, but my delrin lower control arm bushings just started squeaking to I'm starting to tune stuff out.
  6. Dec 28, 2019 at 8:34 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I’ve got more squeaks in my 17 Tundra than my 1998 4Runner. Really crappy.
  7. Dec 28, 2019 at 9:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    damn you....get outta the 1st gen forums.....GET!!! GET I SAY!
    Jbickel likes this.
  8. Dec 28, 2019 at 9:12 PM
    Bulldog_tundra
    Bulldog_tundra New Member
    USA
    2006 Double Cab
    Bilstein 5100 (Top Notch Front) 1” Rear Block Flowmaster 40 w/ 3” Tip Bumperplugs Front Plate Delete
    Exactly my noise, gonna play around with Noico and see if I can figure it out over the next couple days.
  9. Dec 28, 2019 at 9:19 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    My 2001 Tundra had the same noise many years ago and I fixed it my doing the following... Buy some 1/2" round closed-cell foam backer rod, cut it to size to fit the entire length of the dash, and shove it between the dash and the windshield. Don't push it all the way in, but just enough so you can see half the backer rod. Worked for me for years...
    Dave
  10. Dec 28, 2019 at 9:43 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Yup, pretty common. The better TD threads on the topic are hard to find but the remedy like @DSTundra describes is a version of what seems to work.
  11. Dec 29, 2019 at 5:53 AM
    Professional Hand Model
    Hand Protectors
    Thats the sound my bed makes which is a happy sound when its occurring.
    Hand Model Solution: Stuff some cloth rags/strips along the dash and drive it to see if that ‘fixes’ it before doing the foam backer rod stuffing. If successful, then do foam. Also, remove instrument cluster/bezel and glove box and apply sticky sound tape up under dash bottom side and bridge a gap between plastic and firewall as best as possible.
    denteen likes this.
  12. Dec 29, 2019 at 6:53 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Yeah, when TundraNation, TundraTalk and TS went to Forum software by XenForo, they created a major Fubar. In fact it's the main reason I found this great site
    and couldn't be happier.
    What I have found is that if you run across a thread at one of those XenForo forums and a link takes you to a Ooops page, you can use the needed words from that link and place it in their Search box. It should then give you a thread link with those exact words. I realize your link works but take the link you posted just as an example, place the words in bold in their search engine, it should be the first selection found.
    www,tundrasolutions.com/threads/dash-noise-finally-fixed.38840/
  13. Dec 29, 2019 at 10:12 AM
    Bulldog_tundra
    USA
    2006 Double Cab
    Tundra Solutions was great in its prime, Tundrunk and Remmy were HUGE in helping with my ‘03 build. Wonder if they’re here in this forum?
    Really glad this forum is active, it’s a small reason why I was comfortable getting back into a first gen.
  14. Dec 29, 2019 at 11:18 AM
    Hand Protectors
    I pushed on my dash in those areas in the video and they are super firm. Zero to extremely minimal play depending on where. I’d consider some type of jack leg support bracket inside there as a fix if possible.
  15. Dec 29, 2019 at 11:32 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    On my old Corolla, the fix was some Vasoline in the joints for where the dash was clipped together or there was a seam. A light application, wipe off excess and it was good to go.
    I'm going to try the towel/foam between windshield and window to see if I can fix it on my 2019 Tundra. It definitely happens more when it's -20 then when it's +20. It seems to happen on my way to work and I've parked outside all night, but not on my way home after I've parked in a +20 indoor, heated parkade for 8hrs.
  16. Dec 29, 2019 at 11:48 AM
    SouthWestGA
    SouthWestGA New Member
    Gas??!?!?
    don’t smoke and drive!!
  17. Dec 29, 2019 at 11:49 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    D'oh....gasoline.
    Autocorrected and updated my post. Don't want anyone pouring gasoline in their Tundras based on my advise. :anonymous:
    bmf4069 likes this.
  18. Dec 29, 2019 at 4:59 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I'll try to run to Lowe's in the morning and grab the backer rod and will report back. It'll be late as I'm also hooking up a reverse camera / mirror tomorrow morning as well.
    This is what I should look for? -
    https://www.lowes.com/pd/M-D-20-ft-x-1-2-in-Gray-Polyethylene-Window-Weatherstrip/1091865
    From the pic this could be the same gray as my dash...
  19. Dec 29, 2019 at 5:02 PM
    Hand Protectors
    Grab all sizes just in case as the diameter stuffing can be tricky. Not big enough and it falls in. A little too big is better. Hahaha. Return what is not used.
  20. Dec 29, 2019 at 5:06 PM
    abcinv
    Tommy
    South of ATL
    Good point!
  21. Dec 29, 2019 at 8:44 PM
    KarmaKannon
    Utah
    Some junk
  22. Dec 29, 2019 at 8:54 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I dont think Remmy is around, I haven't seen him if he is. I think he became a mod on TS, I know he got a 2nd gen.
    Tundrunk here, thanks for the kind words.
  23. Dec 30, 2019 at 5:06 AM
    bmf4069
    bmf4069 Yup, that's car parts in a dishwasher
    TX
    02 AC sr5 4wd v8
    I lurked around a lot on TS about 5-6 years ago when I first got this truck. I remember seeing that name and truck on there and kinda wondered if you might be him. I think I posted on there about replacing the sub under my back seat and starting a resto. Sorry, just rambling.
  24. Dec 30, 2019 at 6:06 AM
    Bulldog_tundra
    USA
    2006 Double Cab
    Man, glad you’re still around - I can still see the monkey with the beer (I think that was your pic?).
    And for nostalgias sake, here was my last post on TS - even 5.5 years ago I knew I’d be back in a DC...
    Darkness[QUOTED] and bmf4069 like this.
  25. Dec 30, 2019 at 6:25 AM
    FirstGenVol
    East TN
    2002 AC
    So after looking at my dash, I'm wondering how this will work. The part of the dash that touches the windshield is very thin, it seems like this material will just fall down into the abyss. I'm not seeing how the dash will be able to pinch it against the windshield. Certainly worth trying though.
  26. Dec 30, 2019 at 6:48 AM
    abcinv
    Tommy
    South of ATL
    If it doesn't work then I'll give this a go -
  27. Dec 30, 2019 at 6:50 AM
    FirstGenVol
    East TN
    2002 AC
    I like the looks of that. Do you have a link?
    Also, Darkness posted a link earlier and according to that guy, the squeak was coming from inside the dash where the vent touches the dash. I'll be checking that as well. We may have to try both.
    Darkness likes this.
  28. Dec 30, 2019 at 6:51 AM
    abcinv
    Tommy
    South of ATL
  29. Dec 30, 2019 at 6:52 AM
    abcinv
    Tommy
    South of ATL
    Going to work on the rear camera install now. If it goes quick I'll head over to Lowe's and work on the dash; more to come.
    Bubbles likes this.
  30. Dec 30, 2019 at 7:03 AM
    FirstGenVol
    East TN
    2002 AC
    Curious about that as well. The Alpine I was about to order doesn't have the reverse wire on the back. So I'm not clear how you tap into that. Let me know how that goes for you.
