Damaged Rear Bumper
Discussion in '1st Gen Tundras (2000-2006)' started by H1N1777, May 9, 2019.
  1. May 9, 2019 at 3:14 PM
    H1N1777
    H1N1777 [OP] New Member
    Gary
    Orange County, CA
    2002 Tundra V8
    I backed into a pole and jacked up my rear bumper and part of the fender. The metal beneath the plastic is bulging upwards below the tailgate, making it impossible to open the tailgate. Is there any use in banging it out with a hammer, or should I just spend my money on a new one? Then I’ll have to get the body looked at too...
  2. May 9, 2019 at 3:36 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    When I did something similar on my Tundra I grabbed my trusty cable come-a-long and wrapped it around the offending pole (basketball goal post in my case) and hooked it to the bumper STRATEGICALLY and pulled the bumper back out. Got underneath and tapped out the little bit of body work that "popped" with a rubber mallet. My initial damage wasn't as bad as yours but you need to at least get it the heck out of the way so the tail gate works again. That shouldn't be too tough.
    Black Wolf likes this.
  3. May 15, 2019 at 8:05 PM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    5160/6112
    I second tundramcgov. I backed into a 4” aspen in my T-100. It did the exact same thing. A little damage under the passenger brake light, a bump in the metal bumper under the plastic, and the tailgate wouldn’t open. I hooked a tow strap to a tree and bumper, and I had a friend watch the progress. The bumper came out pretty good and the tailgate went back to normal operation.
    Also, I would suggest four low as you can easily control moving just a few inches. I repositioned the tow strap hook on the bumper for the necessary pull and did a handful of small pulls.
  4. May 15, 2019 at 9:06 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Now you gotta buy a 2019 Tundra!!
  5. May 16, 2019 at 3:36 AM
    Professional Hand Model
    Hand Protectors
    But what if it gets a wittle scwatch on it? We’ll get a thread with 347 posts.
    Pucks18 and TX-TRD1stGEN like this.
