CV joints/half shafts
Discussion in '2.5 Gen Tundras (2014-2021)' started by trayday, Dec 15, 2017.
  1. Dec 15, 2017 at 6:03 PM
    trayday
    trayday [OP] New Member
    Oregon
    2015 limited CM 5.7
    Anyone know of a heavy duty half shaft replacement? Specifically stronger CV joints. I'm thinking no but thought I'd give it a shot.
  2. Dec 15, 2017 at 6:25 PM
    Stewie
    Stewie New Member
    2016 Crew Max
    cvjreman.com or rcvperformance.com
    Either one should be able to do something for you.
    Caveat.. i found these companies from a quick google search
    trayday[OP] likes this.
  3. Dec 15, 2017 at 6:32 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Thanks, ill give them a look
  4. Jun 2, 2018 at 6:31 PM
    trayday
    Oregon
    2015 limited CM 5.7
    cvjreman is remanufactured half shafts RCV I can't remember the conversation. While talking to the guy on the phone of CVJ, he said the Tundra's cv joints are built strong and was surprised mine was broke. Anyways, I broke another cv joint last night and I ordered another OEM half shaft online earlier (last half shaft was replaced when the Tundra was in the shop for suspension work.) Anyone know the size of the nut that holds the shaft into the hub? I know I don't have the socket in the garage and I'm looking to order.
  5. Jun 2, 2018 at 7:04 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    39mm. I had to rent a socket from Autozone. Get a 250lb torque bar, too. That nut is spec'd to 249ft/lb.
    I'm in the process of replacing my driver side CV axle, too. Here's the factory service manual with step-by-step instructions and torque spec's for everything you'll need to pull off (its a bit of a pain to search thru):
    https://cardiagn.com/2015-toyota-tundra-service-repair-manual-and-diagrams-pdf/
    trayday[OP], 831Tun and equin like this.
  6. Jun 2, 2018 at 8:06 PM
    n2deep
    n2deep Pavement Princess
    If you have broken 2 CV's I would think you have something binding because they are fairly strong.
    equin likes this.
  7. Jun 3, 2018 at 12:03 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    RCV axles are basically indestructible but there are two reasons why you shouldn't get them.
    1) They're super expensive.
    2) By getting an unbreakable axle, you're moving the next weak in the chain down the line ..which ultimately ends up being more expensive and harder to repair. With RCVs, you'll probably brake your front differential or transfer case first. It's way easier to replace a stock CV axle than it is to replace a diff or transfer case, especially when out in the middle of nowhere. Furthermore, you can drive in 4x2 if you brake an axle. If you bust your transfer case, you're fucked.
  8. Jun 3, 2018 at 10:25 AM
    trayday
    Oregon
    2015 limited CM 5.7
    I'm sure the lift doesn't help
    Thanks for the info!
  9. Jun 3, 2018 at 10:32 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Just get a spare so you can swap easy if it brakes. Find a good axle shop that makes remanufactured ones for a savings especially when exchanging your core for a new one.
  10. Jun 3, 2018 at 10:32 AM
    Spvrtan
    Kris
    San Diego, CA
    Also.. it's worth mentioning that I still haven't broken a CV axle with my 6" bracket lift and 40" tires. With proper driving, not jacking up the lift to extreme angles, and regular maintenance, I imagine they will continue to not let me down.
    ..but I do have 3 spare OEM axles sitting around just in case I need them.
  11. Jun 3, 2018 at 12:05 PM
    trayday
    Oregon
    2015 limited CM 5.7
    I've been buying low mileage from salvaged vehicles online, $40 and $50+
    I've thought about lowering my coils from 7" but the rear sits higher as it is. The first step of the gas after being barely stuck is when I felt the slip. I've never had a problem before in the area but I was also running different tires, after I got out for the winch, I noticed there were other vehicles that have previously been stuck too.
  12. Jun 3, 2018 at 12:34 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Front end have straps? Sounds like your over extending them and slowly beating them to death.
  13. Jun 3, 2018 at 1:04 PM
    trayday
    Oregon
    2015 limited CM 5.7
    I don't, maybe I'll put some on or put the sway bar back on. I'm sure the extreme angles when the wheels are off the ground isn't helping at all.
  14. Jun 3, 2018 at 2:49 PM
    Vizsla
    Vizsla ☠️☠️☠️
    You need straps with your setup regardless of sway bar imo. You like jumping, and both sides droop out on take off. When you jack your front end up and have it drooped, it droops a bit more when hucking it. Yanks all the slack out of the suspension, bushings etc.. Watch your bumps also if it is raised above original, really need to cycle it with the coil spring removed to set properly. I would fix vs relying on having a spare, and carry a spare.
    bryson likes this.
  15. Jun 3, 2018 at 3:09 PM
    trayday
    Oregon
    2015 limited CM 5.7
    Everything was cycled before installation to make the bump stop plate. I'll look into some straps. When the cv joint broke, the tire wasn't past maybe a few inches from normal ride height.
  16. Jun 3, 2018 at 4:04 PM
    Vizsla
    Vizsla ☠️☠️☠️
    Awesome truck by the way, good luck getting it sorted. Got to wheel with a guy twice that has done something similar. It works really well, and is a beast.
  17. Jun 4, 2018 at 5:37 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Dang you guys are hard core. Jumping trucks, breaking axles.... I baby the crap out of my PRO.
  18. Jun 4, 2018 at 6:38 PM
    Help New Member
    Ryan
    Tucson, AZ
    :rofl: but if you don't break anything, you don't have an excuse to upgrade :spending:
  19. Jun 5, 2018 at 7:17 AM
    trayday
    Oregon
    2015 limited CM 5.7
    True, but replacing half shafts isn't any fun.
  20. Jun 5, 2018 at 10:29 AM
    n2deep
    And neither is replacing a front diff. :rofl:
    dcsleeper408 likes this.
  21. Jun 5, 2018 at 10:56 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    You should hit up Total Chaos for new axles, see what they recommend.
    Well, after they get back from the Baja500. I doubt anyone's home right now.
  22. Jun 5, 2018 at 11:31 AM
    trayday
    Oregon
    2015 limited CM 5.7
    Hopefully that doesn't have to happen.
  23. Jun 5, 2018 at 11:36 AM
    trayday
    Oregon
    2015 limited CM 5.7
    I was talking to the shop that's installing my compressor and he mentioned that his friend paid $1800 for 2 axles for his buggy from RCV.
    Limit straps will help, they're breaking from over extending not from the wheel being stuck. I'm trying finish this truck so I can start something else.
  24. Dec 6, 2020 at 7:55 AM
    Gustavo75
    Gustavo75 New Member
    6 inches lift RC 35x12.5x20 tires
  25. Dec 6, 2020 at 7:58 AM
    Gustavo75
    QQ did you have a to regar because the size of your tires?
    I broke a CV joint while doing a light offroad and someone mentioned it is due to my tire size. I have a 6 inches lift with 35x12.5x20
    2016 Tundra 5.7
  26. Feb 1, 2021 at 10:37 PM
    Gryf
    Gryf New Member
    2000 Limited
    None, Yet
    It's more likely the amount of lift. Roughly anything over 3" on that platform should get a diff drop. The higher it is the greater the angle between diff and CV joint. The more extreme the angle the more stress on the CV joint and you'll eventually pull them apart.
    If you have the diff drop then I'm not sure what it could be.
  27. Feb 2, 2021 at 8:11 AM
    Gustavo75
    Thank you for your reply! it makes sense what you said. I will check about the diff drop as I dont have it done, I will let you know if that helped.
