Cutting the exhaust
Discussion in 'General Tundra Discussion' started by Willskaf, Apr 7, 2020.
  1. Apr 7, 2020 at 10:12 PM
    Willskaf
    Willskaf [OP] New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    Hey Fellas,
    I'm looking at cutting/dumping my OEM exhaust on my 2019 Tundra behind the Axle after the last hanger . I have a single exhaust. It's not a TRD exhaust. Has anyone done it and how will it sound be like?
    Rica25 likes this.
  2. Apr 7, 2020 at 10:39 PM
    Rica25
    Ricardo
    Tulare
    Might be little more drone but nothing major will change
  3. Apr 7, 2020 at 11:37 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    My stock (single) exhaust is dumped after the last hanger. I didn’t notice any change in sound or drone.
    Wallygator, Rica25 and Tundyfundy like this.
  4. Apr 8, 2020 at 1:42 AM
    lunchbox
    lunchbox Im lost
    Ryan
    Killeen
    2018 TURD 4x4
    "Stock"
    Nothing will happen, you need to change the muffler if you want a sound change.
    Rica25 likes this.
  5. Apr 8, 2020 at 4:43 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  6. Apr 8, 2020 at 12:13 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thanks Fellas.
    @sr5shark and @Rex Kramer , What is the pros and cons on dumping it? For me, I'm doing it because I hate the look of the one pipe sticking out . I haven't seen it personally cut, but I think it looks cleaner from the back without it. What do you think?
    I have the single exhaust on a 2019 TRD Offroad. I almost pulled the trigger on the TRD dual Exhaust and dumping it after the last hangar. I did not move forward with that because, 1st, I would be wasting money because cutting the TRD Exhaust will be stupid because they are not cheap and 2nd. if I keep it the way it is, I hear that I will lose low end torque. I can't make a decision. Some guys on this forum say they love the TRD dual exhaust and they did not feel like they lost any torque and some do.
    Rica25 likes this.
  7. Apr 8, 2020 at 12:14 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    @sr5shark and @Rex Kramer, Do you like the look of dumping it better than OEM? Does it look cleaner from the sides and back ?
    Rica25 likes this.
  8. Apr 8, 2020 at 12:17 PM
    Rex Kramer
    Georgia
    I lowered the rear of my truck, so I had no choice.
    That all being said, I do like the lack of tail pipe look.
    Rica25 likes this.
  9. Apr 8, 2020 at 12:17 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Cleaner look, out of the way when you off road and if you get longer shackles it may hit the exhaust i think trd exhaust might be in the way can’t recall. Make sure you paint the end after you cut it to prevent rust.
    Rica25 likes this.
  10. Apr 8, 2020 at 12:20 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Ok, Cool. That's what I thought . I love the cleaner look. What would you paint it with? Just the edge you mean?
    Rica25 likes this.
  11. Apr 8, 2020 at 12:20 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Should I cut it while on the truck or remove it?
  12. Apr 8, 2020 at 12:21 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I cut my exhaust for better clearance offroad. (Before cutting I would drag my tailpipe across rocks.) I chose dump after the last hanger because I did not want any exhaust coming back into the cab. Eventually I will replace my stock muffler with something louder - hopefully I'll find a deal on a used TRD dual setup because you are correct, these are really expensive to buy new and then cut up.
    Rica25 likes this.
  13. Apr 8, 2020 at 12:22 PM
    Rex Kramer
    Georgia
    I marked where I wanted to cut, and then removed the tail pipe to cut it.
    Rica25 and sr5shark like this.
  14. Apr 8, 2020 at 12:23 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I marked where to cut while on the truck and then I removed it to cut so I was able to get it close to the hanger. If you cut wile on the truck I suggest removing the spare tire to give yourself more room.
    Rex Kramer likes this.
  15. Apr 8, 2020 at 12:34 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    If you ever buy the TRD Exhaust, you would also cut it? Is it true that you lose low end torque with the TRD Exhaust ? Lot of guys here recommend Dirtydeeds. Would you go that route or TRD?
  16. Apr 8, 2020 at 12:52 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I prefer the sound of the TRD system so this is what I'll be going with. I'll probably dump the exhaust after the muffler unless I find a great deal on the either system in which case I would likely cut the pipes after the rear hangers. For my setup it is more about the clearance offroad than the aesthetics (although I do like the symmetry of pipes on both sides of the truck rather than just on one side.) As for the loss of torque, I am running 35's with stock gears so I'm not too worried about losing a little more torque. :D
  17. Apr 8, 2020 at 1:41 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    Thanks Brother . I agree with you
  18. Apr 8, 2020 at 1:46 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    I cut mine at the last hanger as well, I also have a borla muffler. No difference in the sound or drone. Looks alot better as well.
  19. Apr 8, 2020 at 1:58 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    I might do this when My DirtyDeeds 8" gets here. Tracking says it will be here Fri.
  20. Apr 8, 2020 at 4:59 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    What did you pay for the DirtyDeeds 8" ?
  21. Apr 9, 2020 at 4:36 AM
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    The TRD exhaust came on my truck new. I didn’t like the look exhaust pipes that exited behind the tire.
    The Trd muffler was too quiet for my taste so I switched mufflers and cut the pipes behind the axle for more of a clean look. I saved the trd tips and welded them on. Doing this behind the axle dumped cut the drone I was having between 60-70. Pleased with the sound now and look. ED61D008-3C6F-4210-8DBB-3EC4091AEA25.jpg
    nlaroy, biebs96, Wallygator and 5 others like this.
  22. Apr 11, 2020 at 7:54 PM
    Willskaf
    William
    Castro Valley, CA
    None Yet
    I hear that if you are Offroading and you have your exhaust dumped, it gets pretty dusty from throwning dirt? Have you experienced such thing ?
  23. Apr 11, 2020 at 8:26 PM
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Just don’t do this with a magnaflow I got to crazy now the drown is nuts lol
  24. Apr 11, 2020 at 9:20 PM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Damn that looks really good !!
    ScarWars[QUOTED] likes this.
  25. Apr 11, 2020 at 9:26 PM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
    @dirtydeeds please chime in on this... cutting the factory tailpipe I’m assuming drone like a MFer and power loss... please clarify
  26. Apr 11, 2020 at 9:52 PM
    TheBeast The Beach
    cut mine because at full droop the aftermarket eaf pack was sitting on the tail pipe.
    Also welded tip similar to @ScarWars
    ScarWars likes this.
  27. Apr 11, 2020 at 9:56 PM
    Trdwillie14
    Billy
    2014 trd off road
    How’s it sound ?
  28. Apr 11, 2020 at 10:11 PM
    TheBeast The Beach
    sounds the same to me. i Have Corsa DB exhaust
  29. Apr 11, 2020 at 10:54 PM
    tarathetundra
    tarathetundra New Member
    Nate
    2018 white CM
    37x13.50R18
    Dude I completely agree I have a xpipe and dual magnaflows with turn down tips welded to em and going up a hill it’s obnoxious. But I absolutely love how it sounds when I’m on it. Don’t know what to do about the drone luckily I’m locale to SoCal and might stop into @dirtydeeds and rack his brain on somethings.
    Trdwillie14[QUOTED] likes this.
  30. Apr 12, 2020 at 2:15 AM
    ScarWars
    ScarWars New Member
    I haven’t experienced any negatives with the way my exhaust is done, only positives. I like the cleaner look in the back, the bad drone I was having from 60-70 is now gone and it sounds great.
    TheBeast and Rica25 like this.
