Cutting exhaust pipe after axle
Discussion in 'Performance and Tuning' started by TheBeast, Jan 31, 2019.
  1. Jan 31, 2019 at 9:22 PM
    TheBeast [OP] The Beach
    alright guys, I want to create a bit more clearance and not drag my exhaust pipe everywhere.
    I already removed the chrome exhaust tip and it's a bit better. If you guys have any pictures where you cut the pipe and the angle that would be great. Also did you notice more cabin noise after cutting ?
    thanks.
    Tacoma picture for illustration:
    joonbug and GodlessPro like this.
  2. Jan 31, 2019 at 9:27 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I didn't notice an increase cabin noise.
    Black Wolf, smslavin, joonbug and 5 others like this.
  3. Jan 31, 2019 at 9:30 PM
    is that the stock pipe cut or a dump style extension like the Dirty deeds ones ? I like it.
    Also OK for CA smog ?
  4. Jan 31, 2019 at 9:34 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Definitely increased cab noise for me. Anyone sitting back seat/passenger side usually complains.
    Would I change it....nope
  5. Jan 31, 2019 at 9:34 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    First one is the stock tailpipe. Second and third is the custom catback I had made after installing headers.
  6. Jan 31, 2019 at 9:35 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Oh yea, it’s louder.
    CaptSpaulding likes this.
  7. Jan 31, 2019 at 9:35 PM
    GodlessPro
    Matthew
    NorCal
    I cut the stock exhaust. It isn't quite as high as I was aiming for, but that is my fault for not dropping the spare tire first.
    Haven't had to get it smogged, but I heard the new checks just use the obd port.
  8. Jan 31, 2019 at 9:40 PM
    GodlessPro
    Matthew
    NorCal
    Noise is going to be bigger problem before the axel. Cut it at an angle at the rear hanger and you should be fine.
  9. Jan 31, 2019 at 9:47 PM
  10. Jan 31, 2019 at 9:52 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    U will pass smog no problems. Ur just cutting ur pipe
    TheBeast[OP] likes this.
  11. Jan 31, 2019 at 9:54 PM
    no CO getting back inside cab when idling ?
    831Tun likes this.
  12. Jan 31, 2019 at 9:56 PM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I just had mine smogged last week. Denied previously for my AEM intake, the chopped exhaust before the axle was no issue Threw in the stock intake, passed, replaced AEM intake.
  13. Jan 31, 2019 at 10:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    My dumped tips from Keith were pointed straight at the ground. This sent up huge plumes of dust off road in dry silty conditions. I couldn't let it run while stopped and open the door or window. I've re-cut them to exit more horizontally and it's much better.
  14. Feb 1, 2019 at 5:53 AM
    IndyTundra
    IndyTundra Did someone say beer?
    Ronnie
    Indianapolis, IN
    2015 Radiant Red SR5 CM TRD
    Toytec, 34" Ridge Grapplers, MBRP Exhaust, Linex'd TRD Pro grill
    My exhaust is cut after the axle and I've had no issues with CO getting in the cab while idling. I don't use my rear window much though.
  15. Feb 1, 2019 at 6:05 AM
    Rubberdown
    I always got told never dump straight under the car cause you can kill yourself with CO2. That being said I think most of our cars had holes in the floor so take that with a grain of salt. I always just kicked it out the side under the door or whatever.
    Trm904 likes this.
  16. Feb 1, 2019 at 6:10 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Mine is similar to this, but I don't have a back seat.
    Sounds great.
  17. Feb 1, 2019 at 10:18 AM
    thanks guys
  18. Feb 1, 2019 at 10:22 AM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I cut mine after the axle when I did my lift. I dont think it is any louder.
    cperezsvp and Mountun Goat like this.
  19. Feb 1, 2019 at 10:26 AM
    GodlessPro
    Matthew
    NorCal
    So what are you going to do?
  20. Feb 1, 2019 at 10:28 AM
    for now, still up in the air :)..no pun intended
    Sunnier and GodlessPro[QUOTED] like this.
  21. Feb 1, 2019 at 10:35 AM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
  22. Feb 1, 2019 at 10:35 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Baby it’s cold outside. And rusty outside too :( need to undercoat when it’s warm outside!
    (Magnaflow 3”)
    Darkness and 15whtrd like this.
  23. Feb 1, 2019 at 11:39 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
  24. Feb 18, 2019 at 2:06 PM
    khens12
    khens12 New Member
    Kevin
    2018 Tundra SR5 Off-Road 4x4
    - Icon Billet UCA - King 2.5 Coilovers - King 2.0 “Shorty” Bumpstops
    This is what I’m planning to do. Any sound differences after the dump?
    What leaf set up is this?
  25. Feb 18, 2019 at 3:21 PM
    smslavin
    smslavin Behind a lens...
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    i cut mine just a bit higher than this. no increase in noise either.
    khens12 and GodlessPro[QUOTED] like this.
  26. Feb 18, 2019 at 3:32 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    No noticeable increase in sound. It’s the Icon RXT pack.
  27. Feb 18, 2019 at 6:51 PM
    i haven't done it yet. Since I run aftermarket exhaust, if I cut past the axle, the catback still has a long portion of exhaust without any brackets. I'm concerned it might be flopping around once I cut it since I will go from 2 points brackets to one. I'll try to post a picture.
    on @joonbug picture you can see he has a bracket holding the catback right before the cut. this is ideal imo
    khens12 likes this.
  28. Feb 26, 2019 at 10:53 AM
    got it done at local muffler shop. Cut after the axle and new bracket welded on. Solid and looks good.
    I had the truck on a lift and at full droop it was hitting the leaf spring before the chop.
  29. Dec 13, 2019 at 6:20 AM
    Rwtundra12
    Rwtundra12 New Member
    2012 White Rock Warrior crewmax
    What muffler are you running?
  30. Dec 13, 2019 at 6:41 AM
    Rex Kramer
    Georgia
    I angle cut mine.
    My stock system dumped in front of the axle and robbed me of some low end power, the additional tail pipe with this new system restored what I had lost and even gave me a little boost. The volume is about the same because the exhaust on a RCSB is so close to the cab.
