Custom switches what to get?
Discussion in '3rd Gen Tundras (2014+)' started by phogallen, Feb 5, 2019.
  1. Feb 5, 2019 at 7:20 AM
    phogallen
    phogallen [OP] My Last Mid-Life Crisis
    Kansas
    2019 Black 1794 Fusion Edition
    TRD Pro Grill, front bumper end caps, mirror caps and door handles blacked out. ATC Cap, Cap Pack 6 Gun Drawer, LED lights in CAP, Rhino rails on top, 12 volt accessory plugs. Weathertech floor mats, after market antenae. 45 Ceramic tint film to driver and passenger door. Coachbuilder shims ,+2 shackles, steering kit, bumper shims, Bora 1.25 wheel spacers Bilstein 5100's on mid setting. BW flares with blacked out Route 66 screws. Gloss black powder coated OEM rims and Cooper 295/70/18 Cooper ST MAXX. Tech12Volt sound system upgrade...JL C2's doors and C1's on dash, 5 channel JL amp, 2 10inch subs in custom box and DSR1 sound processor...Soundskins in doors and back wall. Trunk and body badges removed. Powder coated tow hooks red. Linex bed lining front bra film and flares along with full ceramic coat. Ceramic Pro interior plus windshield treatment. Toyota running boards and TRD anti sway bars in front and rear along with blacked out exhaust tip. TRD door latch cover plates. Full VLED light upgrade puddle, license, interior added footwell plus rear tail light brake, reverse. Added ASM turn signal LED's in front. OPT 7 tailgate light in red. Baja Design amber squadrons wc in front and SR2 Pro's in amber on rear bumper. Filmed reverse light in back, added red shackle on tow hitch and new license plate in front. Custom painted badge on tailgate. 3M crystalline on windshield and sunroof. Ceramic window film on rear seat windows. Added dirty deeds 8 inch stainless and summit racing dual tip. Soundproofed floor with foam and mass loaded vinyl. Black Bedslide added to bed.
    I'm beginning to need to plan this out... I can easily see myself needing 6-8 for various lights etc. Doubt I would ever need more than that. Its a bit confusing regarding various manufacturers, options, customization, power modules etc. Would love to get perspectives, ...photos etc. Thanks as always!!
  2. Feb 5, 2019 at 7:29 AM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    You should go with an sPOD. If you’re not already planning to..
  3. Feb 5, 2019 at 7:35 AM
    kparrow
    kparrow New Member
    Kevin
    Great Falls, MT
    2008 Tundra DC 4x4 5.7l V8 Blue 120k miles
    Cooper AT3 4S 275/65/r18, Access Toolbox Bed cover, Stoptech Cryo Slotted Rotors/Hawk LTS Pads, Stubby Antenna, Paracord Grab Handles, more planned!
    I hear great things about the sPOD, and also SwitchPros. If I was going to go with a MOFSET module switch panel I'd probably go with sPOD. I'm cheap though, and going for a "factory" look as well so at this point my plan is to build a custom fuse/relay panel and trigger them off switches from Air On Board. They have switches that fit in the factory Toyota slots and I've got plenty of blanks in the truck.
    https://www.aironboard.com/online/products/switches/toyota-push-switches.html
    texasrho83 likes this.
  4. Feb 5, 2019 at 7:40 AM
    040Tundra
    040Tundra El Chapo
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    My truck came with no blanks switch locations in it. They were all filled, so I had to cut a hole in my center console in front of the shifter.
  5. Feb 5, 2019 at 7:57 AM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    This setup works awesome for me (switchpros in the sdhq mount):
  6. Feb 5, 2019 at 8:24 AM
    Rubberdown
    Rubberdown New Member
    Level kit Rock Warriors with 35s Ain’t doing anything else.
    Crap. Yall spend a lot of money on relays and switches. But it sure looks nice.
  7. Feb 5, 2019 at 8:31 AM
    Erichudgins
    Erichudgins New Member
    Eric
    Murfreesboro, TN
    2017 Super white Limited DC
    https://www.tundras.com/threads/the-un-limited-build.25949/
    got the same setup. absolutely wouldn't go any other direction.
    040Tundra likes this.
  8. Feb 5, 2019 at 8:32 AM
    TheBeast The Beach
    texasrho83 and joonbug like this.
  9. Feb 5, 2019 at 12:44 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Go-Rhino Bumper, FRAC Harness, VLED puddle lights, Decked Bed Drawers, King OEM Coilovers, SPOD control, Baja Designs lights, etc. etc. etc.
    I have the SPOD setup with the switches replacing my sun glass holder. I love it, only thing i would do different is get the switches in Red.
    I got blue which is too bright at night and kind of distracting.
  10. Feb 5, 2019 at 1:57 PM
    phogallen
    Kansas
    Looks great...whole set up aint cheap but it does look good.
  11. Feb 6, 2019 at 8:25 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Can you post a pic of the switch pod in the sunglass holder?
  12. Feb 6, 2019 at 8:30 AM
    kparrow
    kparrow New Member
    Kevin
    Great Falls, MT
    I didn't know someone else had "Toyota" switches other than AirOnBoard....good to know will have to check them out. Thanks!
  13. Feb 7, 2019 at 10:34 AM
    LedFoot86
    LedFoot86 New Member
    Josh
    2015 White Tundra SR5 TRD
    Is your switch always illuminated?
  14. Feb 7, 2019 at 12:27 PM
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    I'm working on a solution to this problem with tundras. There is a thread on the forum from someone (i'll look it up and post a link) who created a 3d CAD model of the useless paper clip on the upper center console. I am currently working on modifying this model to house 6 accessory switches. It will be a custom 3d printed part that will fit the stock location on the upper center console. I'll keep you updated on my progress.
    https://www.youmagine.com/designs/2017-toyota-tundra-overhead-console-panel
  15. Feb 7, 2019 at 12:41 PM
    Berdine
    Berdine Ironhide
    Binghamton, NY
    2016 MGM Crewmax TRD
  16. Feb 7, 2019 at 12:53 PM
    Shallowwatersoul
    Shallowwatersoul New Member
    Dillard
    17' Tundra SR5
    Leveled 3/1. 20x10 XM 313 wrapped with 275/65r20 Trail Graps
    For those of you that are running your switches by your shifter, are yall running wires from behind the radio? I am having a hard time fishing the wires in from that angle.
  17. Feb 7, 2019 at 1:40 PM
    chickunfut
    chickunfut Low-buck Ramp Truck
    Fort Worth, TX
    2007 Tundra Crewmax
    https://www.otrattw.net/ Sells the same switches that come in the SPOD. I replaced mine with red. The last two will be blue once I finish the ARB compressor and locker.
  18. Feb 7, 2019 at 1:56 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    Hammerhead, Therin7 and Part_time like this.
  19. Feb 7, 2019 at 2:02 PM
    TheBeast The Beach
    nope. 2 lights in the switch: one for when you push the button and one for when you turn on the headlights and it illuminates like all other buttons.
    picture was taken when I had the switch on but not the headlights on.
  20. Feb 7, 2019 at 2:06 PM
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    Nice! did you make the housing? Did you have to allow for enough room on the backside for the wiring? that upper console is shallow.
  21. Feb 7, 2019 at 2:32 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Where you get those because if I do 4 switch panel then I won’t want to get 8 sets of lights.. only 4... lol
  22. Feb 7, 2019 at 2:55 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    No I got the whole setup from SPOD.
    https://www.4x4spod.com/tundra_6_switch_panel_source_w_sunglass_holder_12_17_tundra
    I believe they have 2 housings as the shape of the sunglasses holder changed for some reason so you'll want to confirm you've got the right one before ordering. I was amazed by their customer service truly top notch.
    If you call they can customize the color of LEDs used in the switches, I then replaced the switch covers with from some I found on https://www.otrattw.net/.
    The Spod link has a good photo of the connector and wiring you run under your headliner. Its a bit of a pain as you have to cut a hole to fit the connector, but all in all the worst part is going thru the firewall boot. I did this so I only had to go thru the boot twice. *The first time was for the NSV lightbar which comes with its own control unit below the radio.
    Hammerhead and hnsmrob like this.
  23. Feb 7, 2019 at 4:08 PM
    Berdine
    Berdine Ironhide
    Binghamton, NY
  24. Feb 10, 2019 at 4:16 AM
    phogallen
    Kansas
    Which switch set up is that? Looks great too
  25. Feb 10, 2019 at 6:03 AM
    Berdine
    Berdine Ironhide
    Binghamton, NY
    I pieced it together with switches I wanted and the housings.
  26. Feb 10, 2019 at 6:13 AM
    matt kruckenberg
    matt kruckenberg New Member
    20180309_150651.jpg got to be able to switch on/off without moving hand
    Hammerhead and Alexstundra like this.
  27. Feb 10, 2019 at 7:08 AM
    phogallen
    Kansas
    Are those on off or can you get a 3 way switch...?
  28. Feb 10, 2019 at 11:12 AM
    Berdine
    Berdine Ironhide
    Binghamton, NY
    They're on-off, but you can use any kind of rocker switch
  29. Feb 11, 2019 at 5:34 AM
    phogallen
    Kansas
    Appreciate all the input..I'm guessing I will go with Spod. I definitely want switches that have the ability to be lit even when not turned on(two tone LED) and customizable with laser engraving or big enough selection for options. I'm a bit nervous about the ones where you put a sticker on it off a sheet of a bunch of options. Appreciate the many options and advocates out there.
  30. Feb 11, 2019 at 9:44 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    Leveling Lift 3"/1.5" (6112 with a CB shim and JBA UCA, and 5160 and Toytec Shackles Nitto Terra Grappler G2 295/60R20 on Blk Fuel Vector Front and Rear TRD Sway Bars Amp Power Step EVO-One Remote Start Black Powder Coated Bumper Caps Colored Matched Front Bulge and TRD Pro Grill Assy RCI skid plate LED interior lights. Added front and rear footwell led lights. Blue LED lit lock/window switch. Black TRD shift knob Toyota Cargo LED Spyder Headlights (LED Hikari Bulb + Re-wired LED bar as DRL) Limo Tint (all around) Relocated Rear Diff Breather Rear Brake Line Extension Debadged
    Switch Pro?!?
