csuviper's Rock Warrior Build (VENOM) - TRADED IN
Discussion in '2nd Gen Builds (2007-2013)' started by csuviper, Jan 6, 2014.
  1. May 1, 2017 at 9:39 PM
    #1051
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Krezz likes this.
  2. May 1, 2017 at 9:41 PM
    #1052
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Bed stiffers?
  3. May 1, 2017 at 9:42 PM
    #1053
    csuviper
    Broomfield, CO
    Yes sir hidden bedside supports
    Thegr8punkin[QUOTED] likes this.
  4. May 2, 2017 at 3:39 PM
    #1054
    csuviper
    Broomfield, CO
    Look at this comparison between the stock and SDHQ lower fender supports.
    Law323, blue16 and T-Rex266 like this.
  5. May 2, 2017 at 3:46 PM
    #1055
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I'd say a little beefier.....:benchpress:Are those the supports from under bed side to bedside outer fender ? I think I made the similar setup out of round tubing. Mine was unique cuz I modified the inner fenders too.
    joonbug and Jsena like this.
  6. May 2, 2017 at 4:07 PM
    #1056
    TheBeast The Beach
  7. May 2, 2017 at 4:21 PM
    #1057
    csuviper
    Broomfield, CO
    Looks like it.
  8. May 2, 2017 at 4:21 PM
    #1058
    csuviper
    Broomfield, CO
  9. May 2, 2017 at 7:28 PM
    #1059
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Whats the idea behind those Brian?
  10. May 2, 2017 at 7:31 PM
    #1060
    csuviper
    Broomfield, CO
    Stiffen up the back end from the bedsides to the lower fenders.
  11. May 2, 2017 at 7:33 PM
    #1061
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Brian, i do a good bit of bed deck rail walking around to get things mounted/adjusted and can hear creaking as i maneuver. You suppose these would alleviate some of the extra movement? Also, with an RTT being engaged often i would assume it could certainly take its toll as well. Thoughts?
  12. May 2, 2017 at 7:38 PM
    #1062
    csuviper
    Broomfield, CO
    I haven't fully completed the install yet but based on the thickness of the materials it is going to definately make it solid. Turn the collar to tighten it up either way in or out. Should help with a RTT rack.
  13. May 2, 2017 at 7:41 PM
    #1063
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    These are designed to help stiffen the bed during off roading or to help support the rear of the bed. The Tundra beds have a lot of flex and this just helps prevent any seperation and cracking that we have seen.
    These are an adjustable support system so even if your bed is already bent, you can use the heims to pull them back into spec.
  14. May 2, 2017 at 7:53 PM
    #1064
    csuviper
    Broomfield, CO
    Stay tuned for the installation instruction thread.
    Medic, ramonortiz55, TheBeast and 2 others like this.
  15. May 4, 2017 at 10:30 AM
    #1065
    csuviper
    Broomfield, CO
    Never did post these pics up here
  16. May 4, 2017 at 8:05 PM
    #1066
    csuviper
    Broomfield, CO
    Keep a look out tomorrow for something interesting
    TheBeast, zcarpenter92 and T-Rex266 like this.
  17. May 4, 2017 at 8:37 PM
    #1067
    Eclipsed & Floating
    Voluptuous Whitey
    What bank did you rob? Did you keep the blueprints?
  18. May 4, 2017 at 8:45 PM
    #1068
    csuviper
    Broomfield, CO
    :spy:
  19. May 5, 2017 at 10:00 AM
    #1069
    csuviper
    Broomfield, CO
    JC303 likes this.
  20. May 6, 2017 at 8:57 PM
    #1070
    csuviper
    Broomfield, CO
    Got my truck a toy for camping
  21. May 6, 2017 at 9:12 PM
    #1071
    Eclipsed & Floating
    Voluptuous Whitey
    Let me know if you like it. I have one in my work truck and rarely use it. Camping would be a different story. I haven't even started pricing them yet but was thinking of coming up with a double battery backup to run everything without taxing my main battery.
    If I get an inverter I would increase capabilities. I've run corded power saws off the one in the COV. Good purchase :thumbsup:
    NewImprovedRon likes this.
  22. May 6, 2017 at 10:50 PM
    #1072
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Great stuff in here man!
  23. May 7, 2017 at 5:04 AM
    #1073
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    Are you going to mount it? I have this on my list as well but want to mount it and just have the plugs accessible.
  24. May 19, 2017 at 8:55 AM
    #1074
    csuviper
    Broomfield, CO
    az1441, Medic, TheBeast and 2 others like this.
  25. May 19, 2017 at 9:08 AM
    #1075
    csuviper
    Broomfield, CO
    Now to figure out where the noise is coming from.......
  26. May 19, 2017 at 9:27 AM
    #1076
    csuviper
    Broomfield, CO
    Initially i think it will just be portable and not mounted anywhere. If i see the need then i will figure that out.
  27. May 25, 2017 at 12:46 PM
    #1077
    csuviper
    Broomfield, CO
    What tire should i get?
  28. May 25, 2017 at 12:47 PM
    #1078
    TheBeast The Beach
    I say KO2 or Ridge Grapplers or Toyo R/T
  29. May 25, 2017 at 1:07 PM
    #1079
    Eclipsed & Floating
    Voluptuous Whitey
    one of each and see how they perform :thumbsup:
  30. May 25, 2017 at 1:19 PM
    #1080
    csuviper
    Broomfield, CO
    Yea i wish but im not a millionaire.
