Cruise control relocation plate.
Discussion in '1st Gen Tundras (2000-2006)' started by BDAMON4, Jan 15, 2026.
  1. Jan 15, 2026 at 9:10 AM
    BDAMON4
    BDAMON4 [OP] New Member
    2000 white tundra SR5
    Howdy, I recently swapped my OEM steering wheel to a momo cause the previous owner must’ve been chewing on the the wheel. I want clipped and butt-spliced my cruise control. But I’ve been traveling for work and I wanted to put it back on. After digging around I really haven’t found a relocation plate, or atleast don’t want to pull the trigger and pray one fits. If y’all have any suggestions or links it’d be greatly appreciated.
  2. Jan 18, 2026 at 5:52 PM
    Dirk Gently
    Dirk Gently New Member
    2000 SR5 AC 2UZ-FE NON-ABS, RIP: 2006 SR5 AC 1GR-FE A340
  3. Jan 19, 2026 at 7:49 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    That’s a very trick part. Y’all some real smart folks here.
  4. Feb 4, 2026 at 12:29 PM
    BDAMON4
    Update:
    that battle-aero relocation plate actually worked. Some fabrication was needed as the hole location on out cruise control yoke aren’t completely the same. But it work as the holes need to be drilled. A spacer would be recommended to push the cruise control away from the wheel so the studs of the bolts don’t hit the wheel.
    PNW15 and shifty` like this.
