Crewmax running boards on double cab
Discussion in '2.5 Gen Tundras (2014-2021)' started by easleycrawler, Oct 31, 2018.
  1. Oct 31, 2018 at 11:37 PM
    easleycrawler
    easleycrawler [OP] TOYOTA ADDICT- SSEM #78
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Has anyone put crewmax running boards on a double cab?
  2. Nov 1, 2018 at 12:17 AM
    easleycrawler
    Travis
    That's exactly why I started this thread, hoping that it's been done and look right.
    OR18TRD[QUOTED] likes this.
  3. Nov 1, 2018 at 5:37 AM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    It would look fine as long as it didn’t rub the back tire. You may have to cut some off since the crew Max is longer. But I like running boards that go under the bed. You can reach into the bed. Measure the distances on each truck and see how or where the mounts are. Good luck with it
  4. Nov 1, 2018 at 10:11 AM
    915tundra
    915tundra New Member
    LEE
    WEST TX
    2017 Tundra TRD Pro
    I'm thinking maybe the side steps are the same ones installed from the port, on both cabs. That is the factory installed 5" oval side steps, black, and chrome.
  5. Nov 1, 2018 at 10:52 AM
    15whtrd
    15whtrd Mr. Blonde
    Pretty sure it’s the same wheelbase just different cabs and beds.
    Boerseun likes this.
  6. Nov 1, 2018 at 11:01 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Boards will be fine. If you get tubes or others that have steps, the location of the rear steps might be too far back and look out of place.
    EagleClaw972 likes this.
  7. Nov 1, 2018 at 11:02 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Verify the bolt/bracket locations. There are mounting holes in the rocker panel, and on mine the rear bolt holes are almost all the way back. The brackets on my steps are however adjustable, so it should work on a DC, but if they are not adjustable and made for a CM only, you will have to do some fab work.
  8. Nov 1, 2018 at 11:32 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    I don’t think so the cab is longer on the crew max the steps go under the cab. Post some pics show me Where I’m wrong. Exhaust systems are the same because of same wheel base.
  9. Nov 1, 2018 at 11:36 AM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    I just talked to my parts back counter guy, and he says they actually might be a different part, lol, since I never installed a set side by side I couldnt really compare them but they seemed the exact same. I'll go out and measure w my tape so we can make sure
  10. Nov 1, 2018 at 11:43 AM
    Boerseun
    Ferdie
    Sarasota Florida
    Wheel base is the same, but the CM cab is definitely longer than the DC - no way around that. DC is shorter cab, longer bed, same wheel base.
    915Tundra has confirmed above that the steps will fit regardless.
    15whtrd likes this.
  11. Nov 1, 2018 at 11:48 AM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
  12. Nov 1, 2018 at 11:49 AM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    On the double cab the steps extend out slightly futher past the cab corner, as where on the crew max they are pretty much even w the cab.
  13. Nov 1, 2018 at 11:56 AM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Is the crew max bed 5 1/2 foot ? Either way that’s a foot or foot and a half difference in Cab length. I don’t know how they make that up
  14. Nov 1, 2018 at 12:27 PM
    915tundra
    LEE
    WEST TX
    2017 Tundra TRD Pro
    I'm going to actually measure a set overall size, and mounting locations. will report back w the results.
  15. Nov 1, 2018 at 12:31 PM
    15whtrd
    15whtrd Mr. Blonde
    The cab length is not a foot and a half bigger than the double cab. The crew max is 1 foot larger cab and 1 foot shorter bed than the double cab. They just make it up in cab and body.
  16. Nov 1, 2018 at 12:39 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Hmmm, The difference in CM vs DC cab/bed is about 1 ft. The CM step is about flush with the end of the cab. It does not look like the DC step sticks 1 ft past the cab. They might be different length steps.
    619Tundra and 15whtrd like this.
  17. Nov 1, 2018 at 12:46 PM
    15whtrd
    15whtrd Mr. Blonde
    When I use my eyeball measuring tape they do look like different length steps. The only thing consistent in the photos are the front doors of both trucks. If you compare that, the Crew Max steps look to be about 6 to 8 inches longer LOL
    Boerseun[QUOTED] likes this.
  18. Nov 1, 2018 at 8:43 PM
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    Read my post that’s what I said .
  19. Nov 1, 2018 at 9:04 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah you said a foot or a foot and a half so I was just letting you know which.
  20. Jul 3, 2020 at 10:26 PM
    Ltd
    Ltd New Member
    2011 Tundra DC Ltd
    Custom pressure washer rig
    So, what did we ever figure out on this? Does it work?
    I'm thinking to buy some bed access running boards, but it would be a lot cheaper just to buy a used Crewmax set.
  21. Jul 3, 2020 at 11:03 PM
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You can use the crew max boards on the double cab. They will bolt up but the board will be unsupported after the end of the cab where the box starts so you might not want to step on it.
    EagleClaw972 and Ltd like this.
  22. Jul 6, 2020 at 1:27 PM
    Ltd
    Ltd New Member
    2011 Tundra DC Ltd
    Well, the whole idea is to step on it to access the bed. Hey, can you tell how far the metal goes on the bottom? On my double cab the metal part stops about a foot short from the end. So, I can step on the end and it supports me but it feels a little shaky cuz it's not over the metal...
  23. Jul 6, 2020 at 2:03 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The running board is going to overhanging the last support for about 26". I dont think it would be possible to step on it even if the board could take it the two 8mm bolts for the support might not.
    Ltd[QUOTED] likes this.
  24. Jul 6, 2020 at 2:26 PM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    When I bought my 16 DC it had N-fab steps on it (mounted on cab). after 1 time off road I bent them a bit and moved to Sliders (mounted on frame). I was going to give them to my neighbor with a 15 crewmax. It would not fit. The mounting spots on the cab are in different spots. If you are mounting on the frame it "should" work since it's the same frame.
    Ltd likes this.
  25. Jul 6, 2020 at 2:41 PM
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Lots of the boards have mounts that can slide in a track on the board so you can mount as required
  26. Nov 19, 2021 at 9:50 AM
    EagleClaw972
    EagleClaw972 New Member
    2008 Tundra Crewmax
    Straight Pipe, A/T on stock 20s, towing mirrors, kickers pro comp subs and amp
    So can someone answer with a yes or no? I found a set on which Website says they fit Crewmax(double cab) Yet in the diagram it highlights double cab only...
  27. Apr 12, 2023 at 4:14 PM
    FilchedToyoResto
    FilchedToyoResto New Member
  28. Sep 2, 2023 at 7:33 AM
    PickupMan2008
    PickupMan2008 Gladys Knight Industries Two Thousand
    Quentin
    Orange City, FL
    2008 Black Double Cab 4x4 5.7
    Cover King seat covers, weathertech rain guards and floor mats - still working on mods
    This for the normal chrome running boards, not the ones that extend to the bed
    I just bought XSP OEM crewmax running boards and they do not bolt up on the last part towards the bed. The welded bracket hits the cab Mount.
  29. Sep 2, 2023 at 7:34 AM
    PickupMan2008
    Quentin
    Orange City, FL
  30. Sep 2, 2023 at 7:35 AM
    PickupMan2008
    Quentin
    Orange City, FL
    Side view
    831mic likes this.
