Corner Turn Signal Condensation
Discussion in '1st Gen Tundras (2000-2006)' started by lobar77, Feb 13, 2025.
  1. Feb 13, 2025 at 6:13 PM
    lobar77
    lobar77 [OP] New Member
    Logan
    2006 Darrell Waltrip 2WD
    Lift, 33" Tires, Icon Suspension
    Got these turn signals with my headlights off EBay around September. Didn’t notice the condensation for a while but now because of winter it’s much more noticeable. upload_2025-2-13_14-32-16.jpgupload_2025-2-13_14-32-33.jpg
    It’s only the drivers side corner turn signal that gets it. Yesterday we got 3” of rain and I came back to my truck and there was a puddle of water in it. upload_2025-2-13_14-34-33.jpg
    So I switched only the driver side turn signal out with the OEM one and I just noticed that the OEM one also is getting condensation in it too. I’ve never noticed that before and it wasn’t like that with the OEM one before I bought the new ones. So I’m pretty stumped because I thought the new one I bought had a bad seal but somehow the original ones also have condensation. Anybody have any clue why that is?
    Also the OEM turn signal did not get a puddle of water in it today. Just condensation like the first picture I posted.
    G_unit3000 likes this.
  2. Feb 14, 2025 at 5:16 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Is there a rubber boot that goes on thr bulb socket on the DC?
    lobar77[OP] likes this.
  3. Feb 14, 2025 at 5:38 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    LOL
    same.
    i will say don't use straight rubbing alcohol to help the condensation evaporate.
    it'll make your new lenses crack within 5min. ASK ME HOW I FUCKING KNOOWWWW :(
    best bet is to take it out. Work a towel with windex around and let it dry off in a warm dry area. Maybe even having a few silica packets.
    THEN when she's all nice and dry, get some silicone sealant for boats from you local outdoors store and go around the seams of the lense/casing.
    I should have done this but I said "fuck it" and now my brand new Dr. side corner has a massive crack in it within 2 days.
    learn from my mistakes
    lobar77[OP] and G_unit3000 like this.
  4. Feb 14, 2025 at 6:31 AM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    That's a bummer.
    So obviously there is water intrusion rather than water condensation in that corner light housing. Water condensation is normal and results from humidity and should clear up quickly. I got new corner lights with my blacked out headlights and they fortunately haven't accumulated water. My headlights had a fair amount of excess butyl sealant pushed out of the assembly edges. One approach would be to heat up the problem light assemblies in a large box, pull apart it apart, and then add butyl sealant. Heat up again and then reseal.
    https://www.amazon.com/dp/B0CL9H2Z34
    I'd also make certain there is a good seal with the corner light bulbs/LEDs. I've added silicone seals to different bulbs/LEDs that felt loose when installing
    https://www.amazon.com/dp/B09YXQ7GX5
    lobar77[QUOTED][OP] likes this.
  5. Feb 14, 2025 at 6:47 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Are you using LED signal bulbs?
  6. Feb 14, 2025 at 7:59 AM
    lobar77
    Logan
    Yeah there is a small rubber ring that goes around the bulb socket
  7. Feb 14, 2025 at 8:01 AM
    lobar77
    Logan
    My plan was just to buy a new corner turn signal but what’s holding me back is that if the OEM one that I put back on got condensation in it what’s to say a brand new corner signal won’t
  8. Feb 14, 2025 at 8:02 AM
    lobar77
    Logan
    I think I’m going to try the silicone seals that sounds like a really good idea
    Thank you
    G_unit3000[QUOTED] likes this.
  9. Feb 14, 2025 at 8:02 AM
    lobar77
    Logan
    Yep, in both corner turn signals
  10. Feb 14, 2025 at 9:43 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    It’s too bad it’s a real issue otherwise I would’ve said you were just low on blinker fluid from first glance.
    Let us know if the silicone sealant fixes the issue.
  11. Feb 14, 2025 at 9:50 AM
    tvpierce
    Maine
    I was going to suggest that the aftermarket LED sockets might not be sealing as well as the OEM. But in looking at the bulbs, I see that's not the case because you replace just the bulb and still use the OEM socket.
