coolant strip test
Discussion in '2nd Gen Tundras (2007-2013)' started by TheBeast, May 16, 2025.
  1. May 16, 2025 at 10:12 AM
    TheBeast [OP] The Beach
    I'm about to do a drain/refill coolant on my 2012 truck and decided to run a little coolant strip test.
    Last time coolant was changed was 2017. Since then I put 45K miles on the truck mix of highway, off road and light towing (mostly ATVs). I'm in the southwest.
    well the results are in :)
    original coolant in my radiator (7 1/2 years old, 45K miles): pink Toyota coolant shows 50% Glycol and PH of 8.
    New coolant out of the Toyota jug: you guess it...50% glycol and PH of 8.
    Seems the fluid is very stable after all those years/miles.
    Anyone else got similar results ? Please share.
  2. May 16, 2025 at 11:44 AM
    IEsurfer
    IEsurfer New Member
    jimbo
    Socal
    2005 tundra 4x4
    I have and all my trucks I’ve used it on the strip said I’m good so I sorta question it lol
    TheBeast[OP] likes this.
  3. May 16, 2025 at 11:54 AM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    I did mine at almost 100k miles and it came out pink. Looked great, no metal shavings or anything.
  4. May 16, 2025 at 11:55 AM
    yeah I started thinking about it after watching the infamous Car Care Nut video on toyota coolant going acidic after few years/mileage. I wish he would have confirmed his theory by measuring coolant PH.
    Tunrod and coldcanuk like this.
  5. May 17, 2025 at 11:04 AM
    SBGibson
    SBGibson New Member
    2011 Tundra 4 wheel drive
    Have watched the car nut vid also and it does draw concerns Where did you get the PH strips? Was looking around for them and not sure what to buy.
  6. May 17, 2025 at 2:41 PM
    Amazon. Give it a try. In my case I don't see any difference with the new Toyota coolant. PH is what I was looking for since there is a mention of acidity.
    Now we don't know the whole history of that truck in the video. Previous owner could have used a non Toyota one or mixed in the past. Lots of variables before reaching that conclusion imo.
    https://www.amazon.com/dp/B0753MZT7P
    Tunrod likes this.
  7. May 17, 2025 at 4:02 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Concur ... I think CCN is an excellent mechanic with his vast experience with Toyota's but may be a little full of shit when it comes down to the engineering/longevity aspect of items.
    My 149k Camry coolant tested just as well as the coolant that replaced it.
    I thought the Amazon coolant testing strips were a swiz until I tested my ATV's and one did show a decline in one of the parameters, can't recall which one.
    TheBeast[QUOTED][OP] likes this.
  8. May 19, 2025 at 11:36 AM
    SBGibson
    SBGibson New Member
    Thanks for the tip on where to grab the test strips. In the Car Care Nut vid, he mentions working on the ride many times and knows the owner. AT one point he mentioned the engine had a terrible
    problem with the knock sensors and pointed out which ones were the bad ones. One of them were around the cylinder where the HG gave up the ghost. Detonation is an evil B..... Just wondering
    if Detonation could be as big a factor if not more that the PH theory the gents talking about.
  9. May 27, 2025 at 12:36 PM
    post week end and full drain/fill of my truck plus Memorial Day trip..guess what..same results .Seems Toyota coolant is very stable. I am not observing any PH/Glycol difference between a 7y.o one in the radiator, a brand new test in Toyota bottle and new coolant in radiator post full flush. All 3 record at 50% glycol and PH8.
    OldGuy03 and Tunrod like this.
  10. Jun 2, 2025 at 9:15 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    is there only one pink toyota coolant or is there a specific one to look for for these trucks? i had my radiator replaced a few years ago (maybe 10K miles ago?) but i doubt the shop i took it to used toyota coolant. i want to baseline my fluids before summer road trips
  11. Jun 2, 2025 at 1:30 PM
    bought mine from a dealership on ebay. They have better prices than my dealer. But run a baseline and test the current coolant. My experience with genuine Toyota coolant is that it is very stable.
    grave likes this.
  12. Jun 7, 2025 at 11:55 AM
    SBGibson
    SBGibson New Member
    I run regular gas in my 2011 tundra with the 4.6. That's 87 octane. Would running mid-grade 89 octane be a better choice to fight detonation . Still thinking that could also be a problem.
    What octane do the 5.7 engines require?
  13. Jun 7, 2025 at 11:58 AM
    not the correct thread but as far as your issue, run 87 maybe from a different gas station (shell ,Chevron quality) and dump a bottle of Techron. Might be a bad batch at the gas station you went. Start with that.
  14. Jun 7, 2025 at 1:45 PM
    SBGibson
    SBGibson New Member
    My Bad Sir, I was still thinking that detonation might be as big a factor causing head gaskets going south, along with the thought that coolant going acidic is one of the culprits for the problem.
    Should have been clearer in my post. I have no problems with my ride and was noodling about using a bit higher octane , with an idea that doing so might help and keep detonation away and insure the hg problem doesn't come up to bite me.
  15. Jun 10, 2025 at 10:58 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i've always been under the impression that non-forced-induction engines are just fine on 87. if you want better gas, use chevron or shell with the good additives.
    SBGibson likes this.
