Confused
Discussion in 'Other Toyota Vehicles' started by Theyfzman, Mar 30, 2021.
  1. Mar 30, 2021 at 1:33 PM
    Theyfzman
    Theyfzman [OP] New Member
    Pa
    08 TRD
    So had a customer bring there 2011 4Runner in said there experiencing intermittent gear shift issues
    Here’s what it does and fortunately it did it for me go to put it into drive the shifter will move so the interlock switch is working but it will not actually go into drive or any gear for that matter, the indicator on the dash doesn’t light up either and if you move it through the range a few times eventually it will go into drive or reverse and the indicator will light up
    Is there a switch on the shifter that goes bad ?
  2. Mar 30, 2021 at 1:38 PM
    I know there is some plastic pieces in there. Honestly I would post this in their forum.
  3. Mar 30, 2021 at 2:08 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
  4. Mar 30, 2021 at 7:27 PM
    Theyfzman
    Pa
    08 TRD
    I’m just curious if the is a gear selector switch and not a cable actuated
    Was hoping to get some info before I teAr the console apart
  5. Mar 30, 2021 at 7:32 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have you looked underneath to see if there's a cable to the side of the transmission? Might save you from tearing into the interior...
    Have you looked into seeing what the procedure is for checking fluid level?
  6. Mar 30, 2021 at 7:48 PM
    Theyfzman
    Pa
    08 TRD
    I haven’t done anything yet they dropped it at my shop today
    And I just took a quick look at it
    And it’s not transmission related once it finally goes in to drive it runs fine and it’s only intermittent he said it can go months and then nothing no drive, reverse nothing just park no matter where you move shifter to and again the indicator on the dash shows P and when you move shifter it just goes black till finally after moving the shifter back and forth for a while it will work and go into gear kinda baffling
    Wynnded likes this.
  7. Apr 8, 2021 at 12:25 AM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    That definitely sounds like a switch or some sort of electrical issue.
