Composite Bed
Discussion in '3rd Gen Tundras (2022+)' started by Keepontrying, Jan 21, 2022.
  1. Jan 21, 2022 at 7:51 AM
    Keepontrying
    Keepontrying [OP] New Member
    da Burgh
    2022 TRD OR, CM 6.5 ft. bed, Blueprint (aka Black, Blue or Purple)
    Since the bed is a composite, plastic type material, is it necessary to get a spray on bed liner as there does not appear to be paint that can be scratched up? Dont have to be concerned about rust...maybe can save $500!
    Thanks
    Ron
  2. Jan 21, 2022 at 8:31 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Spray in liner is not not needed, but I got the rubber mat when I had my Tacoma otherwise you have to tie everything down or it will slide all over the place.
  3. Jan 21, 2022 at 10:40 AM
    Keepontrying
    da Burgh
    Thanks for confirming as those were my thoughts.
  4. Jan 21, 2022 at 10:41 AM
    nuclear
    nuclear New Member
    As stated, no, you don't need it. But will probably want something depending on what you are using the bed for.
  5. Jan 21, 2022 at 11:04 AM
    NCSkeeter
    NCSkeeter New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    I can’t believe I dealt with the slick as ice composite bed in my Taco for so many years without a bed mat. I wouldn’t get a spray liner, but I’d definitely get the mat unless you want a slick bed to aid loading/unloading items….
  6. Jan 21, 2022 at 11:53 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Bed mat will be my choice if I elect to buy a new Tundra.
    Sometimes I want to be able to slide big heavy objects in the bed since I will be using a ratchet strap to secure them in place. The ease of loading and unloading makes the slick bed an advantage. When I don’t want a slip-n-slide back there I’ll put the bed mat down.
    NCSkeeter and Mattedfred like this.
  7. Jan 21, 2022 at 1:31 PM
    Wallygator
    When I had my Tacomas the bed mat was mandatory for me. Shit slides like it's on ice on that composite bed without it.
