Compatible Rear Axles
Discussion in '1st Gen Tundras (2000-2006)' started by Somemedic, Sep 22, 2018.
  1. Sep 22, 2018 at 9:12 PM
    Somemedic
    Somemedic [OP] New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    Was considering the rear axle and compatible models already with disc brakes.i really am lost with Infinitis but I gotta believe Landcruisers of similar years are bolt on...? This isnt easy to search
  2. Sep 26, 2018 at 11:16 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    I don't know much about the LC rear axle but the closest disc brake is first gen Sequoia.
    because_wumbo-truck and Boerseun like this.
  3. Sep 26, 2018 at 2:34 PM
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    X2 on sequoia brakes there a direct bolt on
    because_wumbo-truck likes this.
  4. Sep 30, 2018 at 2:53 PM
    Somemedic
    Mark
    I'm not sure I follow.
    The sequoia back plates, calipers, and rotors will bolt on? Or is the entire axle bolt on?
    Same ratios? Same width?
    Car parts.com show those axles at $400 all day long. What would labor be to swap em out...3hrs?
  5. Sep 30, 2018 at 3:02 PM
    Somemedic
    Mark
    I forgot about the coils... pfft
  6. Sep 30, 2018 at 3:41 PM
    Professional Hand Model
    Hand Protectors
    This is good info as I’m eyeballing 1st gen Sequoia.
    Casper421 likes this.
  7. Sep 30, 2018 at 6:37 PM
    ethan1911
    Take everything from the backing plates out from a sequoia axle. Depending on the year of the tundra axle vs sequoia parts you might have to drill out the four bolt holes for the axle retainers in the axle housing. It’s a pretty straightforward swap once you have all the parts in hand.
    Watt maker likes this.
  8. Jan 24, 2019 at 9:17 AM
    Somemedic
    Mark
    Anybody seen a write up or vid yet? The sequoia axles are still cheaper than the tundra axles.
    How would I confirm my axle ratio, also?
  9. Jan 24, 2019 at 9:47 AM
    15whtrd
    15whtrd Mr. Blonde
    I haven’t performed this myself. But there is a way to spin the wheel and count the revolutions of your driveshaft. Then a bunch of mad bullshit and you’re done LOL. I would just Google it.
