COMiamiFan 2016 Super White Build- #KNOWN
Discussion in '2.5 Gen Builds (2014-2021)' started by TXMiamiFan, Jan 31, 2017.
  1. Mar 17, 2017 at 2:23 PM
    TXMiamiFan
    TXMiamiFan [OP] SSEM #3 and tractor extraordinaire
    Jose
    2016 White Crew Max TRD
    Stock. Heard 35s are tough to fit so only have OEM (275s if I remember).
  2. Mar 17, 2017 at 2:25 PM
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    Yeah, i've heard a 295/70r18 will fit if you bend the support brackets. I might just keep any eye out on craigslist for a cheap used one and see.
  3. Mar 17, 2017 at 2:28 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    It will be really close with the Toytec Shackles. Coachbuilder will rub. Here's my 34.5" without touching the brackets.
    Jsena likes this.
  4. Mar 17, 2017 at 2:30 PM
    d0zer
    2017 MGM Platinum
    Looks like your stock rim under there, does that setup clear your UCA/skid/whatever?
  5. Mar 17, 2017 at 2:41 PM
    TXMiamiFan
    Jose
    I'll upgrade one of these days. I figured a spare of some sort is better than none for short distances or emergencies. Little of a gangster lean, but beats the alternative.
  6. Mar 17, 2017 at 2:46 PM
    Also can mess up ur rear diff by using a smaller spare. I have a 5th tire..I just need to get a wheel for it
  7. Mar 17, 2017 at 2:48 PM
    TXMiamiFan
    Jose
    Yeah, I know it's not the right thing to have. On the list. What happened to your oem spare wheel? can't u use that?
  8. Mar 17, 2017 at 2:49 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    No, it's a Method NV wheel with 295/70/18. There's nothing to clear back there other than your leafs and your shackles. Mine clears the shackles by atleast 1/2" on each side.
    d0zer[QUOTED] likes this.
  9. Mar 17, 2017 at 2:54 PM
    Maybe
  10. Mar 17, 2017 at 2:57 PM
    d0zer
    2017 MGM Platinum
    Awesome. The UCA/skid was assuming it was stock rim w/ a 295 and running it up front. Glad to see that much clearance!
  11. Mar 27, 2017 at 1:28 PM
    TheBeast The Beach
    @COMiamiFan did you do the cab mount chop to clear the 35"s and 3" lift ?
  12. Mar 27, 2017 at 1:30 PM
    TXMiamiFan
    Jose
    Yessir.
    TheBeast[QUOTED] likes this.
  13. Mar 27, 2017 at 1:43 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Did the cab mount chop erase the possibility of ANY rubbing?
    Reason I'm asking is because I rub only in reverse when turning hard. I think we pegged it as a minor rub on the cab mount. Not bad, just annoying when bacling into a tight spot
  14. Mar 27, 2017 at 1:50 PM
    TXMiamiFan
    Jose
    Yes. I have no rubbing in any direction nor with the wheels at a complete turn in either direction. I had some rubbing on the liner when I put it back on, but I trimmed that at home. So zero rub after CMC. Do you have a different offset? I'm running +18.
  15. Mar 27, 2017 at 1:53 PM
    Eclipsed & Floating
    Voluptuous Whitey
    I'm +12 so it should even be a bit further out than you but I didn't chop any of the mount. Just bumper, liner, and mud flaps. It's only in reverse and turning hard. Not even going forward no matter how hard I crank the wheel. Why would that be?
  16. Mar 27, 2017 at 1:58 PM
    TXMiamiFan
    Jose
    Do you have pics of where it's hitting?
  17. Mar 27, 2017 at 2:00 PM
    Eclipsed & Floating
    Voluptuous Whitey
    No because I can't replicate it without holding the wheel. Do you have a selfie stick that will bend In 4 places I can borrow?
  18. Mar 27, 2017 at 2:01 PM
    TXMiamiFan
    Jose
    LOL. I had my son look at my wheels to see where it hit the liner. Not the safest thing backing out of the driveway, but he survived :rofl:
  19. Mar 27, 2017 at 9:44 PM
    #49
    Shackle
  20. Mar 27, 2017 at 9:55 PM
    #50
    Hola no way Jose! Any issues with led light kit? (Interior) would like to do inside only sweet rig! Color eh mas o menos jk
  21. Mar 28, 2017 at 7:18 AM
    #51
    TXMiamiFan
    Jose
    For what the LED lights cost me, no issues. I just have one that flickers for a bit once in a while, not often. But they cost like $13 so worth the $$. Color is bright white. Thanks for the compliment on the rig.
  22. Mar 28, 2017 at 8:11 AM
    #52
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Dude! Loving your truck!
  23. Mar 28, 2017 at 8:24 AM
    #53
    TXMiamiFan
    Jose
    Thanks Mr Law!
    Law323[QUOTED] likes this.
  24. Mar 28, 2017 at 8:31 AM
    #54
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    This truck is just insanely dope. Nuff said
  25. Mar 28, 2017 at 8:38 AM
    #55
    TXMiamiFan
    Jose
    Thanks, brutha!
  26. May 22, 2017 at 10:21 AM
    #56
    SW72
    SW72 New Member
    Shane
    Kansas City
    2013 Tundra RW
    Biltsein 5100 shocks, BFG 315/70/17, tinted windows, TRex billet grille insert, more to come.
    Whoa! looks great.
    TXMiamiFan[OP] likes this.
  27. May 22, 2017 at 10:24 AM
    #57
    TXMiamiFan
    Jose
    Thanks, Shane! Appreciate it, buddy.
  28. May 22, 2017 at 10:49 AM
    #58
    Eclipsed & Floating
    Voluptuous Whitey
    For what it's worth...I think white tundras are ugly. :D
    Coolhardy and TXMiamiFan[OP] like this.
  29. May 22, 2017 at 10:53 AM
    #59
    Aye Cabron
  30. May 22, 2017 at 10:58 AM
    #60
    Eclipsed & Floating
    Voluptuous Whitey
    @aramirez73
    Jose and i are brothers in the white world. He knows i'm joshing with him
