Column Shifter always skips over reverse.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Southerntothebone, Nov 1, 2019.
  1. Nov 1, 2019 at 1:02 PM
    Southerntothebone
    Southerntothebone [OP] New Member
    Luisiana
    2018 Tundra SR5 w/TRD off road package
    Bilstein 5100s up front, hidden LED light bar.
    Has anybody else had this problem? It seems that every time I come from park down to reverse it just skips right over and goes to neutral. Then i have to go backup into reverse. It's really annoying. Thanks in advance.
  2. Nov 1, 2019 at 1:19 PM
    15whtrd
    15whtrd Mr. Blonde
    It will happen to me if I’m not paying attention. But I’ve gotten used to it, you need to make sure you pull towards yourself to get it over the notch which will help with it skipping past it.
  3. Nov 1, 2019 at 1:21 PM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    I had the same troubles in my last truck when I first got it. After about a year either I got used to it, or it wore itself in, because I didn't have that issue nearly as often.
  4. Nov 1, 2019 at 2:23 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Easy workaround. When parking, shift to N, firmly set the parking brake, let off the service brake pedal so the drivetrain can unload and the parking brake takes the weight, and then shift straight to P fast enough that it won't engage reverse. That way the transmission won't be holding the weight of the truck and the shifter will come out of park easily, no longer flying past R at warp speed.
    Plus it's safer that way. No one wants to be Anton Yelchin'ed by relying on the parking pawl.
  5. Nov 1, 2019 at 2:26 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    My 17 does this.. every time it gets an ohh shit lol
    Pinay likes this.
  6. Nov 1, 2019 at 2:36 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Mine did that too. But exactly what @Squatting Pigeon said, it stopped after awhile. I think I just got used to it.
    Squatting Pigeon likes this.
  7. Nov 2, 2019 at 5:09 AM
    Southerntothebone
    Luisiana
    Thanks for the replies everybody. I already unload the tranny when parking, and it does help. However does anyone know if an adjustment could be made, either at the column or at the tranny?
  8. Nov 2, 2019 at 5:37 AM
    Cpl_Punishment
    Cpl_Punishment Here to do some business
    Neil
    2020 MGM SR5 CM 4X4
    Off topic but which Tundras came or come with a column shifter. I thought they'd all been console shifters for years now.
  9. Nov 2, 2019 at 5:56 AM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    You can still get a front bench seat configuration that has column shift :thumbsup:
  10. Nov 2, 2019 at 5:57 AM
    Squatting Pigeon
    Holden
    North Texas
    Luxe Trail Pig
    No, I don't know of any way to adjust it. I just got used to it and it eventually wasnt an issue.
  11. Nov 2, 2019 at 11:37 AM
    socaltundra951
    socaltundra951 Gentlemen Prefer Black Tundras
    Southern California
    Black CrewMax 5.7
    This, so much. This is how I was taught as a teenager to park vehicles, old man was a semi driver and said that parking brakes are cheaper than transmissions, so why let the transmission hold the weight.
    Later in life when I obtained a commercial license myself, I learned that this is standard practice in the commercial world.
  12. Nov 2, 2019 at 12:53 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    ^This! I got my 2019 SR DC specifically with the column shifter and bench seat...the way trucks were meant to be!
    deepblu89 and Eric32444 like this.
  13. Nov 2, 2019 at 1:03 PM
    15whtrd
    15whtrd Mr. Blonde
    I’ve gotten into a habit of doing this every tome I stop now.
  14. Nov 2, 2019 at 1:58 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Mine does it. Gotten used to it.
