Colored LED Dash Lights
Discussion in 'General Tundra Discussion' started by Smallblock70, Apr 1, 2021.
  1. Apr 1, 2021 at 9:10 PM
    Smallblock70
    Smallblock70 [OP] New Member
    2016 Toyota Tundra CrewMax
    7” lift, 35” STT PRO’s and TIS Wheels, white accessories and lights
    Have any of you had luck or found a product to change the color of the main gauge cluster (speedo etc)? I’d love to go Blue!
  2. Apr 1, 2021 at 9:19 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I don't own a 16, but my 19 allows different colors. Have you checked all the settings in the H/U? Hopefully others with a 16 will chime in.
  3. Apr 1, 2021 at 9:22 PM
    RobertD
    Robert
    DFW, Texas
    @TILLY wait, you can actually change the color of your clusters? I can change the menu theme color but it doesn't change my actual gauges in my '18
  4. Apr 1, 2021 at 9:24 PM
    Smallblock70
    No I haven’t seen that. Excuse my lack of knowledge but would it be under a particular setting or location? I have found that I can change the background color on the screen but have not seen anything on dash lights... but you have my attention!
  5. Apr 1, 2021 at 9:37 PM
    TILLY
    Massachusetts
    Ok, Let me check again, maybe I was just thinking about the menu theme.
  6. Apr 1, 2021 at 9:41 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    You'll have to change the individual bulbs behind the cluster. I don't know how many the Tundra has but my 4runner had 2 behind the rpm and speed and like 12 more behind all the other warning lights.
  7. Apr 1, 2021 at 9:50 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I can tell you, the 16 doesn't have a multicolored gauge cluster, it's white. The center stack isn't variable either, but is blueish including the key ring light. Blue led door lights and interior match well
    TILLY likes this.
  8. Apr 1, 2021 at 10:08 PM
    TILLY
    Massachusetts
    I was wrong, confused cluster with the menu,...these are the only choices you have.
    RobertD[QUOTED] likes this.
  9. Apr 1, 2021 at 10:09 PM
    RobertD
    Robert
    DFW, Texas
    I'm set to the blue as well!
    TILLY[QUOTED] likes this.
