Coil question
Discussion in 'Suspension' started by Crewmax34, Jun 14, 2021.
  1. Jun 14, 2021 at 4:10 PM
    Crewmax34
    Crewmax34 [OP] New Member
    What is the stock spring rating in lbs. for a stock 2018 trd off road. 550 or 600 or less or more any help would be appreciated.
  2. Jun 14, 2021 at 4:12 PM
    AZBoatHauler
    So.Arizona
    Is 700 an option? I thought they were 650 or 700.
  3. Jun 14, 2021 at 4:33 PM
    Crewmax34
    I would like to know because I’m installing a ranch hand bumper and was hoping the spring rate was at least between 600 to 650 stock.
    Piki likes this.
  4. Jun 14, 2021 at 5:16 PM
    AZBoatHauler
    So.Arizona
    I recall when I was looking into changing my suspension research indicating stock coils were either 650 or 700 and the Eibach springs that come with 6112s were slightly softer at 600.
    :notsure:
    Keith @dirtydeeds, David @Coachbuilder1, any help?
  5. Jun 14, 2021 at 6:18 PM
    Crewmax34
    Thank you
  6. Jun 14, 2021 at 6:49 PM
    I believe the TRD coils are rated at 600........definitely not 700. SR5 's at 550
  7. Jun 14, 2021 at 6:57 PM
    Crewmax34
    So if they are 600 what are the coils with the 6112 billys
  8. Jun 14, 2021 at 7:05 PM
    Have no idea. Bilstein doesn't state their coil rating. I've run with 700's on my OME's and 700's now on my Fat Bobs.
  9. Jun 14, 2021 at 7:09 PM
    Crewmax34
    Black Wolf I have one size bigger than stock tire which is 275/70/18 I guess what I’m asking is with the added weight up front should I change the coils and shocks or in your opinion are the stock coils strong enough to handle a ranch hand full bumper?
  10. Jun 14, 2021 at 7:12 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    I believe that all Tundra coils are rated at 600 lbs.
  11. Jun 14, 2021 at 7:23 PM
    I went to 700s when I added a RH grille guard and winch on my 07. I recommend going to the 700s with that full RH bumper.
    AggiePhil likes this.
