Coach Builder +1 or +2 Shackles?
Discussion in 'Suspension' started by UTAHRTK, Jan 26, 2020.
  1. Jan 26, 2020 at 7:31 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, 6112/5160, MR 701's, TOYO R/T Trails 285/75/17
    I am installing 6112's & 5160's this Saturday. The 6112's will be set at the 1.3 setting. I currently have +2 shackles ready to instal. With the front at 1.3 do you think downsizing to the +1 shackles will be better in terms of the amount of rake with the 1.3 setting?
    If I stick with +2's should I do the CB drop kit?
    Once I have the shocks and all on and alignment dialed in I will be installing 305/75R17's at 0 offset; most likely about a week or so later. Truck is Tundra SR5 4x4. Thanks.
  2. Jan 26, 2020 at 7:32 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    At 1.3 you should do the +1 shackles
  3. Jan 26, 2020 at 7:40 AM
    UTAHRTK
    SOCAL
    Damn. Thanks
  4. Jan 26, 2020 at 5:10 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Did you measure the center hub to fender on the front and rear? That will give you a better idea on how much rake you would want.
  5. Jan 27, 2020 at 3:54 AM
    UTAHRTK
    SOCAL
    Yes. I have decided to instal front and rear shocks this weekend (I am not actually doing installation), get a tape measure alignment and then take to alignment shop. I will drive it for a couple weeks to "verify" alignment. I will measure again and maybe jack it up in rear at the hitch to eyeball it- measure and decide which if any shackle to go with. After that - new wheels/tires go on. I have a type in original post - I am installing 305/65/17s...
  6. Jan 27, 2020 at 3:56 AM
    timsp8
    NY
    I’m at 1.9” and +2 shackles and it has a slight rake. Looks almost level. So I think 1.3” and +2 would be noticeably higher in the rear. But 6112s seem to settle differently.
  7. Jan 27, 2020 at 4:07 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Just bump the front up a little more if you already have +2”s on hand. Save some cash.
  8. Jan 27, 2020 at 6:36 AM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    The way I understand it is you choose the shackle that matches you’re lift. +3 for 2.5-3”. +2 for 2”. +1 for 1.3”.
    If I woke up in your shoes I would got 1.9”!!!
    Tundyfundy likes this.
  9. Jan 27, 2020 at 7:28 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    6112s on the 2.5" setting (top) and shims. 5100s in the rear with @BOSS4x4s shackles set at 2" top setting. I have rake.
    Army_of_One and Skew12 like this.
  10. Jan 27, 2020 at 11:42 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    or at 1.3 don't put any shackle and decide if you want it after. I have 2.5 front with +2 shackle and I have rake.
  11. Jan 27, 2020 at 11:43 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    Like a glove
  12. Jan 27, 2020 at 8:50 PM
    UTAHRTK
    SOCAL
    Thanks for all the input. Going to put 1.3 and go from there. Ill be stoked if i don't need to lift rear at all. I will replace OEM bushings with poly though. I guess worst case I will trade the +2 for a +1. Im hoping it turns out good with the 305/65/17s- gonna go Method 701s in bronze. BTW that MGM above looks bad ass.
    r1-superstar likes this.
  13. Jan 28, 2020 at 2:45 PM
    nowayout
    nowayout New Member
    NY
    17 CM
    Good to hear, I think you will be happy with it
  14. Feb 5, 2020 at 9:12 AM
    UTAHRTK
    SOCAL
    Thanks for the great input.
    I ended up setting at 1.3 - no shims and no lift in rear at this time (installed 5160's though). It rides sweet- way better than stock. Truck "looks" level and measured at 1.5" height increase (with exception of some lean on driver front) Lean is not visually apparent at this time and will be a pain in the ass to add shim at this point. As far as rear- I will not add +1 shackle but will swap OEM leaf bearing for the poly bearing.
    I tapped into a Tundra wizard for optimum alignment numbers and went to the Truck Shop and they made it happen with their sweet laser alignment system - that includes zero point calibration.
    Camber 0.0/ 0.0
    Caster 2.8/ 2.6 (goal was between 2-4; closer to 4 as possible)
    Toe .06/ .07 (goal was no more than .15 total)
    I am OCD'ing over wheels & tires now... Gonna go M701s 17" with 0 offset in bronze. As far as tires: They will need to be 33ish ; goal is mild offroad/ sand and to keep stock shift points (regear not gonna happen). With the close to stock size tires the revs should work to this advantage. I am complete novice but have been learning from others...
    Here is what I am pondering-
    305/65/17- meaty looking at level height- probably rub plastic at full lock. I would let it rub.
    295/70/17- probably rub bumper and something else at full lock. maybe a CB bumper shim?
    285/70/17- meh'
    Also wondering should I go with "C" or "E"- they will be BFG KO2s (C not available in 305).
    Again, your input is greatly appreciated.
  15. Feb 5, 2020 at 7:45 PM
    RVR UBER
    RVR UBER New Member
    So Cal
    2018 TRD Sport
    Quick question. I’ll be towing a boat during summer and about to do suspension. Little uneducated. I would want some rake if towing I would assume?
  16. Feb 5, 2020 at 7:50 PM
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Yes, especially with TSS. I left an inch and a half of rake on my 2017 so I don’t end up nose high while towing.
    Tundyfundy and RVR UBER[QUOTED] like this.
  17. Mar 2, 2020 at 6:48 PM
    recomr
    recomr New Member
    2014 1794 Edition
    01 V8 4x4 ARB Front Dobinsons Front SCS F5 305s South Paw Lights
    Nice! I’ll stay tuned, let us know what size tire you go with. I’m 305/65/17 on rock warrior wheels. Stock suspension. Just ordered 6112s. On my end, I’m trying to calculate how far out I can push these out with a spacer. Guessing 1” wheel spacer at this point.
  18. Mar 2, 2020 at 6:52 PM
    recomr
    recomr New Member
    2014 1794 Edition
    Nice! I’ll stay tuned, let us know what size tire you go with. I’m 305/65/17 on rock warrior wheels. Stock suspension. Just ordered 6112s 2.5” after shims. On my end, I’m trying to calculate how far out I can push these out with a spacer. Guessing 1” wheel spacer at this point.
  19. Mar 3, 2020 at 5:02 AM
    UTAHRTK
    SOCAL
    Will do. Do you have any pics of tries? BTW I may be adding shim on driver side to counter the damn lean. Other option I am considering is setting driver side to 1.9 and leaving passenger side at 1.3. Im thinking if I stagger the settings and the ride feels off I could then proceed to drop back down to 1.3 and add 1 shim instead. I getting near the point where I just want to get it right and get the wheels/tires on. It is a slow journey.
  20. Mar 3, 2020 at 6:07 AM
    r1-superstar
    DB
    UTAH
    Don't set them differently. Not a good idea. Get the shim.
    recomr and Tundyfundy like this.
  21. Mar 3, 2020 at 6:15 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    So the number of the shackle doesn’t mean it lifts that much.
    +1 is about .65 inches, +2 is 1.25”, and + 3 is 1.75 inches of lift.
    If you want to keep factory rake for towing and such then you should go with +2 at 1.25 inches which matches your front lift height. If you want less rake than factory go +1 at .65 and you will lose .6 inches of rake(more leveled).
    If you want less rake and keep the +2 add a CB shim to each side for an extra half inch of lift. This is a good way to do it because you keep the soft ride of the 1.3 setting but gain some extra lift.
    If you keep +2 def install the carrier bearing drop per manufacturer specifications. They should have come with the drop spacers.
  22. Mar 3, 2020 at 6:20 AM
    Tundyfundy
    Bay Area, CA
    Yes because when you load the truck, if the ass end sags below the front it’s no good. You lose handling and control real quick. You need some rake unless you have airbags you can use to level the truck after loading.
  23. Mar 3, 2020 at 6:22 AM
    Tundyfundy
    Bay Area, CA
    Bad idea as stated above. Get the shim. 25 bucks. Problem solved forever.
    recomr likes this.
  24. Mar 3, 2020 at 8:58 AM
    recomr
    recomr New Member
    2014 1794 Edition
    305/70/17. Stock suspension.
  25. Mar 3, 2020 at 9:25 AM
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    I went with 6112's at 1.9 (no shims needed) and stock TRD Bilsteins in the rear (also have airbags in rear set at 10psi when not towing). Sits perfectly level after settling in for 25k miles. Tires are 285/75r17 ~33.5" tall.
    To me this is the perfect set up without having to change UCA's, add diff drop, or change gears and speedo calibrate for bigger tires. If I ever decide to go to 35" tires, I wouldn't want to do it without
    increasing the 6112's to the top setting, adding rear shackles with 5160's, changing the UCA's, adding diff drop, and changing the gears to 4.88. Not saying that you can't do it without adding those things, but to retain current performance they would be needed. Thus costing about $3500 (not including cost of tires) to add 1.5" of tire height and 1" of suspension height (net 1.75" of overall height). Sure it would look that much better and perform, but not sure I could justify it.
    drobb and recomr like this.
  26. Mar 3, 2020 at 9:51 AM
    r1-superstar
    DB
    UTAH
    Correct. I installed my own spacers I had laying around. Be sure to use blue Loctite.
  27. Mar 4, 2020 at 5:15 AM
    UTAHRTK
    SOCAL
    Great looking truck! Thanks again for the info.
  28. Mar 5, 2020 at 6:06 AM
    UTAHRTK
    SOCAL
    Contacted Bilstein yesterday at 0600 and heard back at 0800- "I would not recommend changing the ride height on the Tundra 6112 kit to different settings left to right. This can over lift the one side and cause issues. Our recommendation is to go with a shim under driver's side assembly. I believe CB makes a good one." So... I am definitely using 1 shim and not experimenting with different heights. Thanks for the guidance above. Now wondering if I should go 1.9 instead! hahaha.
    r1-superstar and Tundyfundy like this.
  29. Mar 5, 2020 at 6:14 AM
    MSU Tundra
    Mississippi
    Go 1.9
  30. Mar 5, 2020 at 7:35 AM
    Tundyfundy
    Bay Area, CA
    I went 1.9 with 2 shims on each side and got 2.9 inches of height but it still rides like the 1.9” settting. I was surprised how subtle a 3” lift was. I think you’ll want it to be higher later if you don’t go to 1.9 now. :devil:
