Cloth seat spot remover suggestions
Discussion in 'Detailing' started by AxelsHumanDad, Sep 21, 2015.
  1. Sep 21, 2015 at 3:30 PM
    AxelsHumanDad
    AxelsHumanDad [OP] I am Groot
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    Girlfriend spills a few drops of coffee on the seat. It happens. It was just a few small spots, not real bad- I wasn't upset- I would deal with it later.
    We get home from the weekend away and she grabs this:
    and with three blasts of the trigger, a week later the seat looks like this:
    Anyone have a suggestion for something that might improve the damage?
    <sigh>
  2. Sep 21, 2015 at 4:15 PM
    scratchex
    scratchex New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    Maybe try using a Magic Eraser, start on a small spot & see if it works. If not you may see about getting it steam cleaned. Good luck.
  3. Sep 21, 2015 at 4:58 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Weird looks like you can see all 3 trigger pulls. I would check out and read reviews on Amazon and go from there.
  4. Sep 21, 2015 at 4:59 PM
    Virgils12
    This is what I use but I have covers.
  5. Sep 21, 2015 at 5:09 PM
    csuviper
    Broomfield, CO
    2012 Rock Warrior 5.7L 4X4
    This has always worked well for me and the wife. Foams when sprayed on. Comes with a scrubber attachment.
  6. Sep 21, 2015 at 5:22 PM
    Sean266
    Sean266 #ThinBlueLine Staff Member
    I think you posted this on the TC FB page. Was that you? :spy:
  7. Sep 21, 2015 at 5:32 PM
    csuviper
    Broomfield, CO
    Yea I saw it there too. Prefer the forum to facebook
  8. Sep 21, 2015 at 5:40 PM
    53flattie
    53flattie New Member
    Upstate SC
    2015 SR5 CM 4WD
    2.5" / 1.5" leveling kit ; 275/70/18 BFG AT/KO's
    I had the exact same thing happen with some Turtle Wax upholstery cleaner. I kept thinking it would dry, but after several days, it still looked like yours. On a hunch, I grabbed a towel and soaked it with hot water. Scrubbed the spot and it soaped up like crazy. I kept rinsing the towel and scrubbing until the spot(s) no longer foamed up. About 2 hours later, everything was gone.
    I guess I used too much and what I was seeing was the dried soap. Give the spots a few swipes with a wet towel and see if they foam up. If so, I bet you have the same problem that I did.
    AxelsHumanDad likes this.
  9. Sep 22, 2015 at 7:54 AM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
    Walmart carries some stuff called Spot Shot. It comes in a spray can with an orange top. We use it on pretty much everything. I've pulled grease out of white carpet with it. The only thing it didn't completely remove was red dye from a Code Red Mountain Dew. I'd test shoot it just to be safe, but so far, it has never faded anything we've used it on. That being said, it squirts a good bit when you hit the nozzle so be prepared for it.
  10. Sep 22, 2015 at 2:03 PM
    AxelsHumanDad
    2015 CM Platinum
    Thanks for all the suggestions, I'll be working on it later today ;-)
  11. Sep 22, 2015 at 3:21 PM
    AxelsHumanDad
    2015 CM Platinum
    huh. Simple as that ;)
    Rub rub rub with the wet washcloth, got some foam buildup. Rub some more getting the entire area wet, went back with her hair dryer- sweet!
    Thanks everyone.
    ~Mike~
  12. Sep 22, 2015 at 4:43 PM
    csuviper
    Broomfield, CO
