Clifford Remote Start...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Meanjoe, Dec 1, 2020.
  1. Dec 1, 2020 at 9:49 AM
    Meanjoe
    Meanjoe [OP] BT3 USN
    Wayde
    Salem, Oregon
    SOLD: 2020 Tundra SR 4x4 Double Cab Super White Long Bed
    I just had CarToys install a Clifford brand remote start in my 2020 Tundra....BEST DECISION EVER!!! I love it so far...has anyone else used Clifford remote start?
  2. Dec 1, 2020 at 9:55 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    What was wrong with the one that came with your truck?
  3. Dec 1, 2020 at 10:14 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    TheBlackPearl and Brownsfanhere like this.
  4. Dec 1, 2020 at 10:24 AM
    APalmTree
    APalmTree 4x4 SKEPTIC
    Brandon
    SW Washington
    1 or 2... I lost count
    That was one of the first things done to my truck and it is awesome. One of the best things you can do especially up here in the PNW. I use it in the summer and winter to get the truck comfortable in any weather.
    Meanjoe[OP] likes this.
  5. Dec 1, 2020 at 10:24 AM
    The Californian
    Eric
  6. Dec 1, 2020 at 10:42 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    I installed the kit from Tech12Volts + CarLink over the summer. Really regret not doing it sooner!
  7. Dec 1, 2020 at 10:45 AM
    Brownsfanhere
    Brownsfanhere New Member
    2015 Crew Max
    Do these remote starts unlock and leave the truck running until key is in the ignition? Then turn the key and it’s good
  8. Dec 1, 2020 at 10:48 AM
    APalmTree
    Brandon
    SW Washington
    My truck stays locked. You walk up unlock, turn the key in the ignition to on and off you go. If you hit the brake before the key is in it shuts itself off.
    Meanjoe[OP] and Brownsfanhere like this.
  9. Dec 1, 2020 at 10:49 AM
    Brownsfanhere
    2015 Crew Max
    Palm tree which remote do you have then? From what I have read factory one shuts off when you unlock.
  10. Dec 1, 2020 at 10:51 AM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    Same with mine.
    Brownsfanhere likes this.
  11. Dec 1, 2020 at 10:51 AM
    APalmTree
    Brandon
    SW Washington
  12. Dec 1, 2020 at 10:53 AM
    Brownsfanhere
    2015 Crew Max
    Thanks PalmTree.
    Meanjoe[OP] and APalmTree like this.
  13. Dec 1, 2020 at 10:56 AM
    The Californian
    Eric
    Pretty sure they all do, unless you have push button start - then it'll shut off when you open the door.
    Brownsfanhere[QUOTED] likes this.
  14. Dec 1, 2020 at 11:06 AM
    LATERAL G
    LATERAL G New Member
    2013 RCSB SR5 TRD Off-Road 5.7 4x4
    yes
    only the OEM Toyota ones (we have an OEM one on our Sienna) shut off when you unlock
    My Tundra has an aftermarket remote start that does not shut off when you unlock
  15. Dec 1, 2020 at 11:06 AM
    APalmTree
    Brandon
    SW Washington
    Thats what I was thinking. I would think the truck would want to restart with the key in the cabin to prevent funny business but I have done no research on the topic :confused:.
  16. Dec 1, 2020 at 11:07 AM
    APalmTree
    Brandon
    SW Washington
    Does your Sienna have push button start or does it have a real key?
  17. Dec 1, 2020 at 11:10 AM
    The Californian
    Eric
    Not much funny business can happen, if the brake is depressed prior to the key being inserted and turned to the "ON" position, it'll shut off. The truck can not be shifted into gear without the key in place.
    My original question for the OP still stands though, as the 2020s, and 2021s come with a stock remote starter. I'm curious why they felt the need to get an aftermarket one.
  18. Dec 1, 2020 at 11:13 AM
    APalmTree
    Brandon
    SW Washington
    The funny business I'm referring to is specific to push button model. If the truck is on in that case there is no key to insert, so if someone got the door open while it was on they would be off unless I'm wrong which I could be.
  19. Dec 1, 2020 at 11:15 AM
    The Californian
    Eric
    I'm sure they could make it so you have to tap the push button, and as long as it detects your key fob is in the cabin you can drive off, but that would make too much sense.
    MaxMB and APalmTree[QUOTED] like this.
  20. Dec 1, 2020 at 11:31 AM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    Hmmm, my 2020 TSS didn't come with one, maybe his didn't either.
  21. Dec 1, 2020 at 11:38 AM
    Meanjoe
    Wayde
    Salem, Oregon
    My truck did not come with remote start or push button start as it is an SR5 model.
  22. Dec 1, 2020 at 11:41 AM
    Meanjoe
    Wayde
    Salem, Oregon
    No, my remote start locks the doors, then starts the engine, then, when you come out to your truck, push ulock button and get in, and turn the key over to the run position, and then drive away...
  23. Dec 1, 2020 at 1:01 PM
    The Californian
    Eric
    Wild, I thought they all at least come with push button start as of 2020.
    Meanjoe[QUOTED][OP] likes this.
  24. Dec 1, 2020 at 1:02 PM
    The Californian
    Eric
    What trim is yours? A lot of people have it, and don't even realize it. It's not mentioned in the manual that I'm aware of.
  25. Dec 1, 2020 at 1:06 PM
    Do58
    Do58 New Member
    I have a 2021 TSS key ( no push start ) and it didn’t come with one either. I’m fine with it as if I need 1, I will buy one also get the immobilizer bypass and good to go.
