Clay Bar
Discussion in 'Detailing' started by alpinepro4, Jun 8, 2018.
  1. Jun 8, 2018 at 7:26 PM
    alpinepro4
    alpinepro4 [OP] What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    9C99AE1D-BE67-4D19-B8C5-D814517DECE5.jpg Cleaned my truck today and found I have a fair amount of tar from road construction in my area. It was real bad on passenger side. I did my best and cleaned it, but still many specs remain. I was looking at Chemical Brothers clay bars was thinking Black heavy clay bar? But not sure if that is to heavy and should go next step down. I also have some pesky tree shit, that dried on too.
    Once you clay bar the area do you need to go back and re wax that area?
    TUNDRA375 likes this.
  2. Jun 8, 2018 at 8:12 PM
    I would. Use some quick detail spray to act as a lubricant after washing it. Once clay bar is applied, wash, wax.
  3. Jun 8, 2018 at 8:15 PM
    15whtrd
    15whtrd Mr. Blonde
    Bug and tar remover or wd40 clean then wax.
    TXRailRoadBandit73 and Pudge like this.
  4. Jun 8, 2018 at 8:25 PM
    alpinepro4
    Pat
    Great I will give that a try!
    15whtrd likes this.
  5. Jun 8, 2018 at 10:12 PM
    TheBeast The Beach
    wash,dry ,clay bar, wash, dry,wax.
  6. Jun 9, 2018 at 1:39 AM
    Turtle wax makes a bug n tar remover I used on wife's car, she had some tar spots, sprayed on let soak came off with some light rubbing
  7. Jun 9, 2018 at 3:34 AM
    War Machine
    War Machine SSEM # 5 3MW
    I’d start with the lighter clay bars first.
    seniramsu likes this.
  8. Jun 9, 2018 at 5:05 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    X2
  9. Jun 9, 2018 at 6:01 AM
    alpinepro4
    Pat
    I bought a light clay bar. Lower half of the door is speckled with tar. Bought chemical brothers light clay bar. Hopefully it was the right choice.
  10. Jun 9, 2018 at 6:26 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    If the tar is thick like badge residue I wouldn’t clay it, might rub across and marr the clearcoat. Spray this on, let it sit for a minute and rub it off with a MF cloth. Rinse all the GG off.
    Do clay afterward, it makes a huge difference for a smooth surface followed by polish and wax for a mirror finish.
  11. Jun 9, 2018 at 11:42 AM
    briarpatch
    briarpatch New Member
    X3
  12. Jun 9, 2018 at 12:16 PM
    riley804
    riley804 New Member
    2018 toyota tundra
    " Automotive Clay Bar is an engineered resin mixture that auto detailers use to remove contaminants and pollutants from the surface of your car’s paint, glass, fiberglass, and metal."
    I personally wouldnt use it to remove the tar from the surface as then that clay bar is going to have that mixed in the clay bar, making it pretty much worthless. I would try the wd-40 or dip a rag into some gas and rub the surface......after you clean the tar off, then you can clay bar it and use whatever polish you normally use.
  13. Jun 9, 2018 at 1:06 PM
    alpinepro4
    Pat
    I bought some WD-40, do I spray on a MF or directly on the surface? I will use the clay bar next for contaminants then.
  14. Jun 9, 2018 at 1:08 PM
    VTsuckah
    VTsuckah New Member
    2018 Tundra Limited CM 4x4
  15. Jun 9, 2018 at 2:24 PM
    riley804
    riley804 New Member
    2018 toyota tundra
    either way.....
  16. Jun 9, 2018 at 5:23 PM
    ZPMAN
    Minnesota
    If all else fails use this, you can pick it up at any auto body supply store. Will not harm your paint when used in proportion (dont leve a soaked rag of it overnight on the paint) and will take off pine sap, road tar, stickers and boogers.
