Choose my Offset
Discussion in 'Wheels & Tires' started by Navy Jumper, May 21, 2019.
What Offset for OE Flares?
  1. +1
    10.0%
  2. +20
    90.0%
  1. May 21, 2019 at 3:38 AM
    Navy Jumper
    Navy Jumper [OP] Airborne Paratrooper
    2023 TRD PRO
    What's up everyone!I So I'm looking into getting aftermarket 20's to run w/ my factory 275/55R20 Dunlops until it's time for new tires. I'm having a hard time deciding on an offset to match my OE flares, even after thoroughly searching. I measured and the flares stick out about 1.75“ from the wheel. I've narrowed it down to two choices.
    +1 or +20.
    What is everyone's opinion or thoughts on what I should do? Side note: I may eventually lift/level on a 3/1. Thanks in advance!
  2. May 21, 2019 at 4:35 AM
    I have a 3/2 with 285/70/18's on a +1 offset with Bushwackers. I'll take some pics in a little while.
    Navy Jumper[OP] likes this.
  3. May 21, 2019 at 4:59 AM
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    According to tiresize.com's wheel offset calculator ( ), the +20's will make your wheels stick out another 1.57" and the +1's will have them out 2.32"
    So how aggressive do you want it to look? The +20's will get you close to flush. The +1's will have you out about 1/2" past the flairs. If you go with larger (wider) tires later, they will stick out even more. Personally I'd go with the +20's
    flinky14 and Boerseun like this.
  4. May 21, 2019 at 8:31 AM
    Navy Jumper
    2023 TRD PRO
    Damn, thanks for the input. I'm not sure how aggressive I want to go. I've been going through photos of Tundra offsets trying to figure out.
  5. May 21, 2019 at 9:10 AM
    TheTripleLindy
    TheTripleLindy New Member
    i have 20's with zero offset; gives it an aggressive stance. no fender flares.
  6. May 21, 2019 at 9:11 AM
    Navy Jumper
    2023 TRD PRO
    Got a photo?
  7. May 21, 2019 at 9:15 AM
    TheTripleLindy
  8. May 21, 2019 at 9:22 AM
    TheTripleLindy
  9. May 21, 2019 at 9:25 AM
    Navy Jumper
    2023 TRD PRO
    Thanks! This one really puts it into perspective.
