Chip set for reverse Lights???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Machodiver, Aug 18, 2015.
  1. Aug 18, 2015 at 1:20 AM
    Machodiver
    Machodiver [OP] New Member
    James
    2015 Black SR5 Tundra CrewMax
    I'm looking to replace the reverse lighting with LEDs, and was wondering if you guys knew off the top of your heads what the chip set was on the 2015s???
  2. Aug 18, 2015 at 6:32 AM
    What do u mean by chip set? I replaced mine with LED's.
  3. Aug 18, 2015 at 6:34 AM
    You're blinding me.
    T-Rex266[QUOTED] likes this.
  4. Aug 18, 2015 at 6:52 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  5. Aug 18, 2015 at 7:46 AM
    csuviper
    Broomfield, CO
    T-Rex266 likes this.
  6. Aug 18, 2015 at 7:48 AM
    csuviper
    Broomfield, CO
    I assume this is what you are looking for as apposed to chip set.
    "In a computer system, a chipset is a set of electronic components in an integrated circuit that manages the data flow between the processor, memory and peripherals. It is usually found on the motherboard. Chipsets are usually designed to work with a specific family of microprocessors."
    mdavis likes this.
  7. Aug 18, 2015 at 7:56 AM
  8. Aug 18, 2015 at 12:35 PM
    Machodiver
    James
    I just want to make sure I get the right ones that fit my truck. I found those JDMs that @Sean266 has but there are a variety of figments.
  9. Aug 20, 2015 at 3:28 AM
    Machodiver
    James
    @Sean266 did you have to put a relay in when you put the leds in?
  10. Aug 20, 2015 at 5:35 AM
    No sir.
  11. Aug 20, 2015 at 5:39 AM
    Machodiver
    James
  12. Aug 20, 2015 at 11:16 PM
    Machodiver
    James
    Just bought these....
