Chime in if you know what manufacturer makes a decent+ 18 off set Rim
Discussion in 'Wheels & Tires' started by Part_time, May 1, 2019.
  1. May 1, 2019 at 11:29 AM
    Part_time
    Part_time [OP] Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I have been told after I get my truck leveled, I will have to get a +18 offset rim, to be able get 305/65 or 60 /18 . It should fit in the wheel well with no rubbing. With out a body chop, don't want to do that. Any one got an idea on which manufacture makes a decent rim for this offset?
    Thanks in advance
  2. May 1, 2019 at 11:41 AM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    KMC XD wheels is one. They have a good selection of wheels for Tundra's. Mike are 20x9 +18 but you can probably get +18 in 18" as well. Check the link in my signature for more pictures.
  3. May 1, 2019 at 12:11 PM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    you don't just look at the offset. There's also the wheel width that comes in to play to clear those size tires.
    An 18x8.5 +18 wheel will have different clearance as an 18x9.5 +18 wheel.
    Fotnot likes this.
  4. May 1, 2019 at 12:18 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    +18-+25 should be no issues. Only 7mm difference. That should open your possibilities a little more.
    That's a 9" rim, rim size will play a factor. Backspacing is better. About 5.5-5.75"
  5. May 1, 2019 at 1:49 PM
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    SCS wheels
    mtTundra likes this.
  6. May 1, 2019 at 1:52 PM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
  7. May 1, 2019 at 1:57 PM
    TheBeast The Beach
    METHOD
    Novajess1972 and Blkdmax like this.
  8. May 1, 2019 at 6:41 PM
    Part_time
    Oregon
    So what your saying is that +18 or more same result?
  9. May 1, 2019 at 6:42 PM
    Part_time
    Oregon
    He was saying 8×9
  10. May 1, 2019 at 7:02 PM
    SK_Tundra
    Stockton Ca
    For tundra, 18x9 +18to+25 is the sweet spot
    Part_time[QUOTED][OP] likes this.
  11. May 3, 2019 at 7:01 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Method makes 18x9 +18 and +25.
    jewsNbrews likes this.
  12. May 3, 2019 at 9:01 AM
    Part_time
    Oregon
    Might go with 20" rim for the extra height
  13. May 3, 2019 at 10:40 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Wheel width makes no difference in clearance, other than the tire slightly bowing more on a skinnier wheel. Only the width of the tire matters. A 305 tire will basically have the same fit whether on a 8.5" wheel or a 9" wheel.
  14. May 3, 2019 at 5:30 PM
    Part_time
    Oregon
    Looking up steel rims card id has 18x8 with 50mm off set for 71.00. Would this work with decent tires or will this be too narrow?
  15. May 3, 2019 at 5:41 PM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Vision Wheel makes a handful for the Tundra at +18
  16. May 3, 2019 at 5:49 PM
    Part_time
    Oregon
    What is the size of the hub bore supposed to be?
  17. May 3, 2019 at 5:58 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I went with Raceline's... 18x9's on 35x12.5 rubber. Plus18 offset.
    Part_time[OP] likes this.
  18. May 3, 2019 at 6:02 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Backspace is such an easier concept than offset. All the wheel companies used to list backspace in simpler times. As backspace doesn’t change with whole width changes
  19. May 3, 2019 at 6:27 PM
    realtorblake
    Yeah... backspace used to be in inches, if it is even listed now... then you have to go metric for offset! LOL
  20. May 3, 2019 at 6:39 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    Cali Offroad 20x9ET18 mounted on 295/60 STT Pro
    Here’s a pic to give you perspective of a +18 mounted on a 295 tire
    Part_time[OP] and jewsNbrews like this.
  21. May 3, 2019 at 6:49 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    I have Moto Metal wheels that are +18. Looks like they don't make the ones I have anymore, but they have lots of choices for +18 offset
  22. May 10, 2019 at 9:58 AM
    Novajess1972
    Novajess1972 New Member
    Jesse
    2019 MGM TSS OFF ROAD
    Ready Lift 4in/20x10 Fuel Triton/35x12.50 BFG KM3
    X2
    TheBeast[QUOTED] likes this.
