Changing 1st Gen Headers
Discussion in '1st Gen Builds (2000-2006)' started by MarkBeast10, Sep 20, 2021.
  1. Sep 20, 2021 at 5:35 PM
    MarkBeast10
    MarkBeast10 [OP] New Member
    Mark
    2000 4.7l SR5
    I finally changed the headers on my 2000 Tundra 4.7l. The most difficult part to understand was how to get around the motor mount on the driver's side.
    First: do not jack up the vehicle, keep the truck on the ground with the tires on the vehicle. You will need a break bar, a wrench, and a long 14mm socket.
    Second: remove oil filler stick, remove heat shield on OEM header, and remove mid pipe.
    Take the wrench and the long socket to the last two header bolts by getting under the truck and turning the wrench sideways, putting the socket on the bolt. Then go above to the engine bay and pull the wrench from above to get enough leverage to remove the two bolts under the engine mount.
    Doesn't look like I can get images on here..
    Darkness likes this.
  2. Sep 20, 2021 at 5:47 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I found it easy just to support the motor with a jack and a block of wood, then remove the mount. Which headers did you run?
    FrenchToasty and MarkBeast10[OP] like this.
  3. Sep 20, 2021 at 5:52 PM
    MarkBeast10
    Mark
    2000 4.7l SR5
    Went with JBA shorties. Did removing the mounts help with torque specs?
  4. Sep 20, 2021 at 6:08 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I set the torque by feel, didn't see a good way to get the only torque wrench I had in there. I tried a crows foot but got tired of fumbling with it. Pulling the mount gave me lots of room though, I should have done it on the passenger side too but that side was easy.
  5. Sep 21, 2021 at 9:03 AM
    FirstGenVol
    FirstGenVol Brake Czar
    East TN
    2002 AC
    You 2WD guys have an unfair advantage with this job. Much harder with axles and differential blocking the view of even seeing some of the bolts.
    FrenchToasty likes this.
  6. Sep 21, 2021 at 9:21 AM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
    Like Luis said, torque by feel, goodentite was how I torqued mine. I also removed the motor mounts per his instructions. I get to do the driver side again this winter to put my thickness gasket on. 33ED99CF-F13A-4B18-89C2-380388213804.jpg
