Changed my oil for $29.37
Discussion in '2.5 Gen Tundras (2014-2021)' started by georgiey22, Jul 7, 2019.
  1. Jul 7, 2019 at 9:26 PM
    georgiey22
    georgiey22 [OP] Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Battled the heat today and changed the oil in my 2019 with 5,000 miles. Headed to the Sierra Nevadas in two weeks, so I wanted to get this sorted out before the trip.
    WM has 0W20 Mobil 1 Extended Performance on roll back for $25.77 for a 5 quart jug. The 5.7L iForce requires 8.5 quarts of course. With the M1 $12 rebate this reduces the per jug cost to $13.77 or $2.75 per quart. $23.37 for 8.5 quarts. $5 for OEM oil filter. $1 for new drain bolt washer. Total was $29.37.
    Is this a big savings? I’m unsure what the dealer charges; however, I won’t let them touch my truck unless it’s an absolute requirement. I can ensure the job was done perfectly. While under there I even added a very thin coating of anti-seize to all skid plate bolts. 60 minutes of effort in the heat and approximately 30 big ones and I’m good for 10,000 miles.
    Loaded it up with some work gear and put a few miles on it after the job was complete.
    Paul B, codygs83, aperezsh and 12 others like this.
  2. Jul 7, 2019 at 9:28 PM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    And you lost a few pounds in sweat...for free! Another plus on the day. Rad truck
  3. Jul 7, 2019 at 10:11 PM
    Marty McFly
    Morty McBoonJug
    Dat neighborhood :drool: Someone is ....
    xma, codygs83, BlackSheep and 9 others like this.
  4. Jul 8, 2019 at 12:16 AM
    jtaco11
    jtaco11 New Member
    WM is the go to place for oil & fuel treatment. Purchase online store pickup in & out quickstyle dont like browsing around there. We've all heard not so great headlines happen at WM
    bgdv1, georgiey22[OP] and chugs like this.
  5. Jul 8, 2019 at 5:02 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Yup Kids. That's how you do it. And that's WHY you do it.
    Consider adding a Fumoto valve in place of the drain bolt and it gets even easier.
    jtaco11 and georgiey22[OP] like this.
  6. Jul 8, 2019 at 5:45 AM
    Texas Big Daddy
    Texas Big Daddy New Member
    San Antonio
    2016 Platinum 4x4
    " Petcock "
    CaptSpaulding likes this.
  7. Jul 8, 2019 at 5:48 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I think typically dealers charge something like $75? I do my own oil changes too and with a fumoto valve and RCI skid it's about as easy as it'll get
    georgiey22[OP] likes this.
  8. Jul 8, 2019 at 7:14 AM
    jtaco11
    jtaco11 New Member
    [QUOTE="
    Consider adding a Fumoto valve in place of the drain bolt and it gets even easier.[/QUOTE]
    Put fumoto on all my vehicles at 1st oil change. Well worth it dont have to deal w oil mess when removing the drain plug
  9. Jul 8, 2019 at 7:38 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    So witch Fumoto valve are you guys using? They offer a few different ones for our trucks.
    georgiey22[OP] and TNTundra53 like this.
  10. Jul 8, 2019 at 7:53 AM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    Does your fumoto valve extend past the skid plate?
  11. Jul 8, 2019 at 8:17 AM
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I always do my own as well, but haven't been able to due to shoulder issue, so I took it in to Valvoline (big mistake). $123 for full synthetic and cleaning agent. The monkey underneath complained about the RCI skid being too far away from the filter cap, got oil in his eyes and had a new monkey take over to finish the job. They tell me all is done and great when finished and send me on my way. I got home and took a peak...***do your own work like @georgiey22 to avoid messes like this***
    georgiey22[OP], Black Wolf and Pinay like this.
  12. Jul 8, 2019 at 11:54 AM
    Tundra_Nitti
    Tundra_Nitti New Member
    Delaware
    2017 Silver Sky Tundra SR5
    You have Toyota Care for 2 years 25k miles. The oil is due every 10k miles. The maintenance light comes on every 5k for a rotation. So you weren't due for the oil change yet and it's free from Toyota so you over spent.
  13. Jul 8, 2019 at 11:58 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    WTF???
    georgiey22[OP] and TheBeast like this.
  14. Jul 8, 2019 at 12:07 PM
    shakezoola
    shakezoola Not a new member
    Kansas City
    2019 Tundra TRD Sport MGM
    N-Fab MRDS Bfront Bumper w/ Rigid Industries Radiance PODS and Curved LED Light Bar TRD Skid plate Victory 4x4 Roof rack and hood mounts with Rigid industries Midnight PODS Alpine Halo9 ILX-F309TND Alpine PDR-V75 5-Channel amp powering 4x Image Dynamics component speakers Alpine S-A60M powering 1x 12" sub Fortin Remote Start with MyCar App Switch Pros SP-9100 Pop-and-Lock tailgate lock vLeds front turn signals w/switchback Center Console Safe Pedal Commander Diamond Back HD bed cover Swing Cases Driver/Passenger Katzkin Leather seats w/ heated front seats Bilstein B8 5100's Front and rear AMP Research PowerSteps Toyota TSS wheels w/ DuraTracs Toyota bed mat Bed light (LEDs) Blacked out badges Sport Antenna
    Not really "ballin" if you're trying to save a few dollars on an oil change.
    Doesn't Toyota offer free oil changes for the first few on FFV? That was the case with the 2 Tundras I have purchased, but I also get extended maintenance to cover me for for the first 100k miles or so.
  15. Jul 8, 2019 at 12:08 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Yea, them neighbors might be complaining if the hood is up more than 5-10 minutes. Just Saying........ LOL
  16. Jul 8, 2019 at 12:14 PM
    tacomawv
    tacomawv New Member
    Richard
    Can someone please school me on the M1 rebates at Wal-Mart. I need some oil. Thanks.
  17. Jul 8, 2019 at 12:54 PM
    Marty McFly
    Morty McBoonJug
    My buddy growing up had a millionaire uncle. His uncle drove a 96 Honda Civic and did all his own work on the car. He was a millionaire for a reason LOL :eek:
  18. Jul 8, 2019 at 12:59 PM
    shakezoola
    Kansas City
    Yeah, I've known several millionaires that wear inexpensive white tennis shoes, jeans, and plain oxfords. Drive a regular car/truck, save more than they spend. Couldn't tell by looking at them that they had tons of money.
    There's a huge difference between being a millionaire and "ballin".
  19. Jul 8, 2019 at 2:05 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    What fumoto valve are you guys running?
  20. Jul 8, 2019 at 4:32 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I'm running the Plain Jane F-103. No nipple. Nuttin. I just open the valve and let it fall. Others like the nipple variety and add a piece of hose/tubing to carry it down into the drain pan.
    Here's a link to Fumoto's site for the 2017 Tundra with the 5.7L engine (what I have).
    http://fumotousa.com/results.php?make=79&year=2017&model=36532&makeid=TOYOTA&modelid=Tundra+5.7L+V8
    EDIT: just FYI but I run the simple F-103 on all four of my Toyota vehicles.
  21. Jul 8, 2019 at 4:34 PM
    gdisarray
    gdisarray Short term member
    MGM SR5 TSS
    I went by my local jeep dealer to get a refund on my oil change contract. (10 for $200 on my recently sold JK Wrangler) Full service. They wouldn't refund my last 3 but they offered me one for my Tundra (after the 2 year Toyota dealer freebie is up) They were at 4 for $100 on the 5.7L. They were packed and I forgot to ask what oil. I'll ask tomorrow. Full service oil change and a check on the alignment machine before heading into the bay is what have had for the past 4 years. Can't beat it.
  22. Jul 8, 2019 at 4:58 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Thank you!
  23. Jul 8, 2019 at 9:47 PM
    georgiey22
    This Uncle you speak of is brilliant. I’m blessed to own this home here in CA.
  24. Jul 8, 2019 at 9:50 PM
    georgiey22
    This neighbor is the grandson of a fashion brand we all likely wear, very well off. He is trying to teach his son work ethic and asked me to teach his son how to change the oil on his sons 2018 Tacoma TRD Pro. For the most part, the neighbors in this area keep to themselves and let me do my thing. He laughs with me over beers on the weekends because I also cut my own lawn. I enjoy hard work.
  25. Jul 8, 2019 at 9:55 PM
    georgiey22
    Unfortunately dealers are typically no better than the Quickie Lube shops when it comes to oil changes. Wish I had time to share why I hold this opinion. Nonetheless, we all have our way of doing things, I respect yours, hope it works for you.
    Noticed you are in KC, I’ll be in KC next week on business. Looking forward to enjoying a few nice meals before heading to Omaha for a Berkshire event. Best of luck to you shakezoola.
    shakezoola[QUOTED] likes this.
  26. Jul 8, 2019 at 9:59 PM
    georgiey22
    When I purchased the truck here in CA. Prior to writing the check for the truck, I required the dealer to discount the truck an additional $250 because I wasn’t going to use Toyota Care (Value of 2 OCI’s & Rotations), they weren’t pumped on the idea. They wanted my check, so they agreed. Do you believe I still over spent?
    CCLJ03 and awq735 like this.
  27. Jul 8, 2019 at 10:08 PM
    georgiey22
    This stinks pal. Sorry you experienced this, pains me to see. For this very reason I try and service all of my vehicles. It’s a pain and dirty work but after a similar experience I try and be planful around the work. Next time you are the Los Angeles area look me up, I’d be happy to buy you a few beers and hear the story of how you managed the situation with this shop.
    Pinay likes this.
  28. Jul 8, 2019 at 10:13 PM
    georgiey22
    Thanks Capt!
    Pinay likes this.
  29. Jul 9, 2019 at 2:18 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I always carry my G26 when I go to WM, even here in Vermont.
  30. Jul 9, 2019 at 6:57 AM
    Tundra_Nitti
    Delaware
    If you want you can PM your VIN and I can look to see if you have Toyota Care. I never heard of an option to not get Toyota Care.
