Change tail light bulb
Discussion in '2.5 Gen Tundras (2014-2021)' started by BigGuy31, Nov 4, 2016.
  1. Nov 4, 2016 at 1:03 PM
    BigGuy31
    BigGuy31 [OP] New Member
    2017 tundra trd pro
    I needed to change my tail light bulb I removed the 2 torque screws but I can't get the light to come out what am I missing I didn't want to pull too much afraid of breaking something any help would be awesome it's a 2014 if that helps. Thanks
  2. Nov 4, 2016 at 1:04 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    On my 2nd gen you have to twist the base and then it will pop right out. Should be the same for you.
    *EDIT sorry thought you meant the actual bulb. @TTU19 below has it...
  3. Nov 4, 2016 at 1:10 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Do you mean you can't get the whole tail light off the truck? After you remove the torque screws, there are two push pins at the top and bottom on the other side that you have to pop out. Here is a photo that someone had shared with me.
    At the locations where the tape is, you'll need to use a plastic trim tool, or be very careful with a flathead screwdriver:
    Adriver71x and equin like this.
  4. Nov 4, 2016 at 1:12 PM
    LMAO yup those two tabs are a mother to wrestle with jus gotta b careful
    equin likes this.
  5. Nov 4, 2016 at 1:17 PM
    BigGuy31
    2017 tundra trd pro
    So where the tape is you have marked the pins are visible once you have the screws out and push in on them
  6. Nov 4, 2016 at 1:24 PM
    Freaking Toyota engineers!...my uncle used to to say.. "those damn chinese think of everything" when he would use his door striker as a bottle opener for his beer on his '88 Toyota P/U
    SnrDisregardo likes this.
  7. Nov 4, 2016 at 1:25 PM
    BigGuy31
    2017 tundra trd pro
    Okay thanks for the help. Tape is good idea if you have to pry out thanks again
    NewImprovedRon likes this.
  8. Jan 9, 2019 at 10:10 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Resurrecting this old thread now that I’m struggling with the same thing. Need to replace the rear turn signal bulb, so I searched for videos showing how to take the tail light assembly off. Of course, the few I found show it easily coming off. As is typical with my luck, though, mine is stubbornly stuck. Guess I need to get a plastic pry tool and try to pop it out without scratching the paint.
  9. Jan 9, 2019 at 10:15 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    I’ve removed mine quite a few times. They’re still stubborn. After taking out the screws, get your fingers under the front of the light, and pull straight out to the side of the truck. I use my knuckles against the body of the truck as leverage.
  10. Jan 10, 2019 at 6:23 AM
    equin
    Ed
    DFW, TX
    Thanks for the tip. I'll try that later today.
  11. Jan 10, 2019 at 4:23 PM
    equin
    Ed
    DFW, TX
    Well, the finger knuckle option didn't work, so I had to use a plastic auto body pry tool. I didn't have blue painters tape handy, so I used a chamois, which kept me from scratching the paint. But that tail light housing was on so tight, the top red corner piece (right where the top blue painters tape is in the pic above), snapped off before I was able to finally pop it out. A little bummed about that, but live and learn I guess.
  12. Jan 10, 2019 at 4:25 PM
    15whtrd
    15whtrd Mr. Blonde
    I push from the tailgate side of the tail light out.
    equin likes this.
  13. Jan 10, 2019 at 4:26 PM
    equin
    Ed
    DFW, TX
    Yeah, I tried that, too, as tight as it was to get my hand in there, but it just would't budge. It was on there real good.
    15whtrd[QUOTED] likes this.
  14. Jan 10, 2019 at 4:39 PM
    15whtrd
    15whtrd Mr. Blonde
    Bummer. Sorry about the broken lens bud.
    NewImprovedRon and equin[QUOTED] like this.
  15. Jan 11, 2019 at 12:14 PM
    equin
    Ed
    DFW, TX
    Man, I wish I would’ve thought about putting some grease on those pins. I’ll be sure to do that the next time. I didn’t bother with the passenger side because the bulbs are still good. Hope it’s not on there as tight as the driver side when it’s time to replace a bulb.
  16. Jan 11, 2019 at 6:53 PM
    WZ KTM
    WZ KTM New Member
    2018 MGM DC TRD Off-road
    I did the same thing a couple weeks ago, a simple $20. LED reverse bulb swap ended up costing me $150.+ For a new taillight. That pretty much sucked.
    equin[QUOTED] likes this.
  17. Jan 12, 2019 at 6:53 AM
    equin
    Ed
    DFW, TX
    $150?! Dang it! Where did you get your tail light from?
  18. Jan 12, 2019 at 6:59 AM
    equin
    Ed
    DFW, TX
  19. Jan 12, 2019 at 10:54 AM
    Big Yota
    Big Yota New Member
    2018 Double Cab TRD Off-Road 4x4 Blazing Blue Pearl
    Cap (soon)
    Non original manufacturer parts are cheap for a reason. They don't have to adhere to the manufacturers design or durability requirements. Typically you get what you pay for. I'm guessing it will fit or everyone would return them immediately. My guess the seal between the plastic pieces will fail in a couple of years and the light will flood. Burn out a bulb, maybe get corrosion to start on plugs, and then break when you go to get the water out and replace the bulb . By then any warranty is done and you will be SOL. But for what you paid for it you then can buy another one.
    equin likes this.
  20. Jan 12, 2019 at 11:26 AM
    equin
    Ed
    DFW, TX
    Good point on the seals, flooding and corrosion. Hadn’t thought about that.
  21. Jan 12, 2019 at 5:34 PM
    WZ KTM
    WZ KTM New Member
    Toyota of Cool Springs, there price isn’t to bad but I sure got hammered on shipping. Living in the boonies doesn’t always have it’s advantages.
  22. Jan 13, 2019 at 6:26 PM
    Pupule Mike
    Pupule Mike New Member
    2015 Tundra Limited Crew Max
    Good to know...my 2015 has a light bulb contact problem. Blinkers click quickly when it the light is deemed as burnt out. I just bang on the lens with my first and starts working again. Dealer says they fixed it, my guess they didn't do shit!
    equin likes this.
  23. Feb 13, 2019 at 9:17 AM
    fishon
    fishon New Member
    tony
    2014 tundra
    none
    just pulled the tail light off my 2014 tundra...what a Pain!!! I thought for sure i was going to brake the lens or something expensive. anyway i did brake the plastic insert for the top pin. is there anyplace online i can buy new inserts? TIA
  24. Feb 13, 2019 at 9:23 AM
    15whtrd
    15whtrd Mr. Blonde
