CB shims as a very slight lift for the front?
Discussion in 'Suspension' started by CCLJ03, Jun 8, 2021.
  1. Jun 8, 2021 at 2:36 PM
    CCLJ03
    CCLJ03 [OP] Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Anyone use CB shims with stock OR suspension as a very slight lift for the front? I know it’s not much different from stock but I would love to see pictures if anyone has!
    I’m wondering if I can add essentially 1/2 or 1 inch of lift to the front with shims and then get 285/70r18 ridge grapplers in there without rubbing. I already removed the splash guards In the front of the wheel well.
    I think it would look sick, and I need to maintain some rake because I have an atv in the bed and a camper hitched up quite a bit in the warmer months.
  2. Jun 8, 2021 at 2:56 PM
    Kanobi13
    Kanobi13 New Member
    You could use the shims. As far as rubbing not sure are u on stock wheels?
  3. Jun 8, 2021 at 2:58 PM
    timsp8
    NY
    It would work. It’d be like a mini spacer lift.
  4. Jun 8, 2021 at 3:01 PM
    LML 3500HD
    Remember your ride would be rougher due to preloading the spring. :thumbsup:
    CCLJ03[OP] likes this.
  5. Jun 8, 2021 at 3:04 PM
    LarryDangerfield
    LarryDangerfield Put me in coach! Staff Member
    Tyler
    Northern Wisconsin
    Cement 2020 Trail Limo off-road Tacoma
    Tuxmat floor mats, Bilstein 6112s and 5160s
    I thought the CB shims didn't preload the springs as they went on top of the coilover instead of underneath the top hat compressing the coils.
  6. Jun 8, 2021 at 3:07 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    285/70 18s will fit stock suspension, with the stock OR wheels. I run 275/70 18 and the others are just slightly bigger. At most you may have to remove the front air flaps.
    But yes, you could do a half inch lift or so with those shims, but not needed for those tires if you are using +60 offset wheels.
    You would have to search for it, but there is a thread on this site about someone installing that size on a stock truck
  7. Jun 8, 2021 at 3:23 PM
    Kanobi13
    Kanobi13 New Member
    Correct
  8. Jun 8, 2021 at 3:28 PM
    CCLJ03
    Craig
    awesome! yep stock wheels.
  9. Jun 8, 2021 at 3:29 PM
    CCLJ03
    Craig
    Even better!
  10. Jun 8, 2021 at 3:30 PM
    LML 3500HD
    You could be right. It made mine ride rougher and ended up taking them out. I had two on the drivers side and one on the passenger side for the tundra lean issue on my Bilstein 6112’s, on the lowest setting.
  11. Jun 8, 2021 at 3:57 PM
    CCLJ03
    Craig
    You think it made the ride rougher?? Did you change tires or other suspension parts at the same time?
  12. Jun 8, 2021 at 4:00 PM
    LML 3500HD
    Could be my imagination, but it felt better once I pull one out of the drivers side and one on the passenger side.
  13. Jun 8, 2021 at 5:09 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    I'm not sure how a shim on top of the coilover would make the front end ride stiffer. I had a 1" spacer on top off my factory coilovers for a month until my lift came in. It rode just like stock. Just make sure you install bumpstop spacers to take into account the extended down travel.
  14. Jun 8, 2021 at 5:37 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’ve got two on each side of my Pro suspension and didn’t notice a difference in ride quality. I think you’d be ok. Did you change your mind on assembling new coilovers?
  15. Jun 8, 2021 at 6:55 PM
    CCLJ03
    Craig
    I did!! I was trying to get myself to like the idea of 295’s on 2.5”/1.5” lift but it’s just higher than I need.
    I knew I would drive it every day feeling like an idiot because I would never actually use that setup the way it was intended. lol
  16. Jun 8, 2021 at 7:02 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah… what kind of idiot would daily their truck with that kind of lift… :anonymous:
    Elduder and CCLJ03[QUOTED][OP] like this.
  17. Jun 8, 2021 at 7:17 PM
    CCLJ03
    Craig
    hahaha
    Not knocking it. I’m just very critical of myself. I wish I could just rock it and be happy because it looks sick! I can’t. Haha
    TRDFerguson[QUOTED] likes this.
  18. Jun 8, 2021 at 7:23 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you like the look then I say go for it. You might find you’ll end up using it off road more later on once you do that too. You live in a great state for it
  19. Jun 8, 2021 at 7:47 PM
    CCLJ03
    Craig
    I’ve gone back and forth on that. I think the 285/70s with shims will scratch my itch and keep my towing situation squared away!
  20. Jun 8, 2021 at 9:25 PM
    pandapro
    pandapro New Member
    If you decide to go with the CB shims, I have a set of 1/2” shims (adding a 1” lift) that I will list in the coming weeks when my new coilovers come in.
  21. Jun 8, 2021 at 9:31 PM
    BUCS_KID88
    BUCS_KID88 New Member
    You will spend more money for small 1” inch lift then just getting a 2” or 2.5 leveling kit for your truck I assume it’s normal TRD. Now if it was a pro then yea CB shims to add to already leveling kit and keep ride then same I’ve had mine since new and 30k miles now not a issue at all smooth….. but like I said if I was you get leveling kit and add some shackles from CB for rear if you want…and Go 295/70/18 our truck look awesome with 295’s or bigger….
  22. Jun 9, 2021 at 5:27 AM
    CCLJ03
    Craig
    That’s just not true at all. I don’t want a spacer lift because it pre-loads the spring, and any other leveling kit will cost more than the shims by quite a lot.
    Also, I can easily install shims in my garage with the tools I’ve got.
    Finally, like I said previously, I realized i just don’t want to go as big as 295’s. Don’t need it and I think the 285’s on a more stock look are going to look sweet.
  23. Jun 9, 2021 at 6:10 AM
    BUCS_KID88
    Oh okay I see… makes sense
  24. Jun 9, 2021 at 12:09 PM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    You've done a great job on your research,
    We have guys add our shims to their OE struts all the time. Usually they use our 1.00" shim kit but can use the .50"s and would recommend using 2 on driver and 1 on passenger to correct the driver side lean.
    Difference between a leveling spacer and our shim is the total thickness used does not exceed .50" if you install anything thicker than .50" you are no longer positioned in the center line of stroke. Meaning the amount of up travel is greater than the amount of down travel. This is why most will notice how much bouncier or firmer it feels after installing a leveling spacer. Shims are installed above the top plate and will not add any additional preload.. another benefit to using them. Just a simple tool providing the opportunity to dial in your stance.
    Hope this helps.
    https://shop-coachbuilder.myshopify...ides-1-00-of-lift?_pos=2&_sid=7eaeb9049&_ss=r
    https://shop-coachbuilder.myshopify...ovides-50-of-lift?_pos=1&_sid=7eaeb9049&_ss=r
    https://shop-coachbuilder.myshopify...-lift-tundra-2007?_pos=6&_sid=7eaeb9049&_ss=r
    D4x4TRD likes this.
  25. Jun 9, 2021 at 1:22 PM
    CCLJ03
    Craig
    I’m sold. My tundra is a 2018 and I don’t really have any lean (yet?). Should I just order an extra 1/2” and add it to the drivers side preemptively?
  26. Jun 9, 2021 at 2:33 PM
    DUKFVR
    DUKFVR New Member
    Houston & Young County TX
    2020 Cement Tundra DC SR5, Stage 1 Icon kit, LT75/60/20 Toyo AT III, Ranch Hand Midnight Bumper Replacement
    I just put half inch shims on top of my icons. Got right at 1 inch of lift. Put a set of +2 rear shackles too. Truck rides great. Can't tell the shims were even put in.
  27. Jun 10, 2021 at 4:48 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The lean is mostly an aftermarket coil issue. If you are keeping the stock springs in place you won’t have to worry about it.
    CCLJ03[QUOTED][OP] likes this.
  28. Jun 10, 2021 at 5:22 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    But it's so much fun looking down on everyone else! :D
    I can vouch for the CB shim quality. I installed their 0.25" shims on top of the TRD Pro Fox coilovers for a 2.5" total lift and all fit perfect.
  29. Jun 10, 2021 at 10:48 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
    This seems like a pretty inexpensive way to level the truck - anyone have a totally stock suspension with just the CB Shims?
    Wouldn't the Rough Country 1.75" Level Kit (https://www.roughcountry.com/toyota-leveling-lift-kit-88000.html) be the same idea, just 1.75" instead of the 1" provided by CB? Everything I keep reading seems like they are installed in "generally" the same location on top of the coil-over. Am I missing something?
    As always, appreciate all the knowledge on here.
  30. Jun 10, 2021 at 10:55 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    "Leveled" is considered a 2" lift in the front relative to the rear. So technically you wouldn't be level after 1" of lift in the front, but yes, it will give you some of the benefits of levelling or adding coilover shocks with perch at .9" or similar. David's explanation up a little bit is solid on what goes on with a spacer lift.
    Badknees likes this.
