Catalytic converter delete ideas.
Discussion in '1st Gen Tundras (2000-2006)' started by Mr Badwrench, Aug 21, 2022.
  1. Aug 21, 2022 at 2:34 PM
    Mr Badwrench
    Mr Badwrench [OP] New Member
    Has anyone successfully been able to trick the ECM into not throwing any codes in absence of catalytic converters?
    I am not subject to emissions testing where I live. I'm going to get some wiring diagrams specific to my truck and try to reason through this myself, but if anyone has any input on this, I'd like to hear from you.
    2001 4.7 V8.
  2. Aug 21, 2022 at 2:38 PM
    Mr Badwrench
    ...from what I gather, all that really needs to be accounted for are the o2 sensors. I'm guessing the ecm reads the resistance off these?
  3. Aug 21, 2022 at 2:50 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I believe it’s looking for a DC voltage between a tight threshold range. I don’t have the FSM in front of me.
    It should average around 0.45 volts.
  4. Aug 21, 2022 at 3:01 PM
    Mr Badwrench
    Would that be the difference between the two o2 sensors? ... .45 volts I mean.
  5. Aug 21, 2022 at 3:18 PM
    Jack McCarthy
    Bill
    North of Boston
    No, the upstream sensors are basically a sinewave of 0.1-0.9 volts with a DC offset of 0.45 volts.
    The CAT output (downstream sensor) is a diminished copy of the sinewave that is still offset by 0.45 volts and looks more like a DC signal.
  6. Aug 21, 2022 at 3:48 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Many folks have but I would suggest giving great thought to not messing with a wonderful designed engine. If you're hell bent on it, continue your due diligence given there are many threads out there to feed off of.
    The fronts are more important than the rears, so at least consider keeping those....search the net for Air/Fuel ratio sensors for actual function.
    The rears are simply for checking the efficiency of the CATs....search for O2 rear simulators.
    There are good threads out there but pay attention to what DJ offers in the below thread.
