Cat-Back for RCSB ??
Discussion in 'Dirty Deeds Industries' started by Rex Kramer, Apr 27, 2019.
  1. Apr 27, 2019 at 6:29 AM
    Rex Kramer
    Rex Kramer [OP] Vinyl Spinner
    Georgia
    I believe I am suffering from over analysis paralysis, but I know what I don't want.
    The truck: '07 2WD 5.7L RCSB, daily driver street use
    Mods: Lowered rear and DAP tune
    Exhaust: Factory manifolds and muffler dumped with resonator in front of axle
    Goals: Extract additional low RPM torque by installing a custom cat-back
    What I don't want: Drone, or a loud exhaust.
    Keith, can you make a properly sized bolt on cat-back that meets my requirements?
    Also, I assume that since I am keeping the factory exhaust manifolds I will require a
    single tail pipe... can this tail pipe exit on the passenger side in front of the tire?
  2. Apr 27, 2019 at 6:37 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  3. Apr 27, 2019 at 6:44 AM
    dirtydeeds
    Keith
    USA
    2003 and 2013 tundra
    more than I can list here
    Thanks for the mentions guys!! I can help for sure.
    I need a little more info. Give a call Monday. 760-877-4234
  4. May 22, 2019 at 5:17 AM
    Rex Kramer
    Georgia
    Keith, I need a little more info.
    ... would I benefit from, and is there room for an H or X pipe on your 10" system for the regular cab short box?
    EDIT: I am told that the Y pipe at the end of the cat back makes an H or X pipe unnecessary, can you confirm?
