Casual Observation
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Aug 26, 2018.
  1. Aug 26, 2018 at 10:51 AM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    This is a side by side comparison of the Toy Oil Filter next to a Mobil1. Is bigger better? Or, is weight the better metric? Should your filter pleats be dense, or should they be light and let things flow?
    jewsNbrews likes this.
  2. Aug 26, 2018 at 10:56 AM
    Hand Protectors
  3. Aug 26, 2018 at 11:28 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I think it really depends on the quality of the filter. Heavier usually means better quality parts, but not always.
    https://youtu.be/EXFh1gfEWCw
  4. Aug 26, 2018 at 11:52 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I only run the Toyota filter you have there. I have run K&N a few times when they came in oil packages.
    I doubt you'll get any definitive answers unless we have one of them oil analysis nerd guys here to do a comparison.
  5. Aug 26, 2018 at 2:00 PM
    Hand Protectors
    This is exacty what I did. Bought 5 online from a dealership for about $25. When I buy the Mobil1 Full Synthetic oil its at the auto store as their pricing is usually better than online AND they do a ‘free filter’ deal with the oil.
    Thats the reason I had the Mobil1 filter which I’m running right now. I’ll probs do a filter change around 2k miles with the Toy brand. This may be what I do from here out as the oil purchase will come with the ‘free’ filters. And I bought 5 Toy filters online. I’m going to have filters out the whazoo.
    More on the differences, the Mobil1 is much heavier. The metal walls of both ‘felt’ similar in thickness when squeezed. Obviously, the Toy is bigger.
    Darkness likes this.
  6. Aug 26, 2018 at 2:55 PM
  7. Aug 26, 2018 at 3:25 PM
    I figured Ron.
    Watt maker likes this.
  8. Aug 26, 2018 at 3:26 PM
    Hand Protectors
    Thanks for that link. Very informative. My questions were answered in these two pics.
    ColoradoTJ and Watt maker like this.
  9. Aug 26, 2018 at 3:35 PM
    Hand Protectors
    Anyone dialed in on the gear oils for the 02’? Its the limited slip. Front calling for 75w-90 and rear 90w. Hard to find straight 90w. Confused a bit on whether the use a non-Toy brands OR the Toy brand for double cost!
    Hypoid GL-5 for LSD 75w-90 (spec’d) or Straight Synthetic for LSD? Cost difference is HUGE Toy vs. name brands. Might need to go to stealership for the 90w (rear diff) as its hard to find.
  10. Aug 26, 2018 at 4:00 PM
  11. Aug 26, 2018 at 4:07 PM
    Hand Protectors
    Sweet! Thanks for the direction.
  12. Aug 26, 2018 at 4:49 PM
    Hand Protectors
    Walmart out of stock. Still having a hard time finding straight 90w. Might have to go 80w-90 per cold temp specs. Will call stealership tomorrow for more info.
    ColoradoTJ likes this.
  13. Aug 26, 2018 at 5:22 PM
    Casper421
    In the woods
    06 DC
  14. Aug 26, 2018 at 7:34 PM
    Mechanicinkc
    Mechanicinkc New Member
    Michael
    2012 Toyota Tundra Crewmax limited
    Leveling kit, bilsteins, 1 in hub centric spacers. Amsoil in everything.
    I am a yota junkie, but the oem filters are average at best. Mobil 1 extended performance is a much better option. I would use the Wix also. #1 choice is the Ea K 51 Amsoil 25k filter. I own and operate a shop and service a fleet of Tacoma reg cabs 2wd for a printing company and for the last 8 years I have been running them on 15k service intervals with Amsoil signature series oils and Ea filters. Have never had internal engine issues. Some of the trucks are over 300k. Check out their products at amsoil.com. the proof is in the pudding.
  15. Aug 28, 2018 at 2:47 PM
    Hand Protectors
    My rear diff is calling for straight 90w or 80w-90 (in cold). Wondering what all my service mechanics have been putting in all these years as thats something I’ve trusted others to do the right thing. Seems 90w is hard to find unless I buy the Toy stuff for $36 a quart (online pricing). Still haven’t called stealership.
    Next tech question: Can I use the limited slip gear oil in the transfer case? Reason for asking is the way the quantities work out I’ll have almost 1 quart extra left over from the front diff (LS) which is enough to do the transfer case. Otherwise, I need to buy additional 75w-90 non (LS) oil at an extra expense.
  16. Sep 1, 2018 at 11:34 AM
    Hand Protectors
    Spoke with stealership parts dept. and they confirmed one can use Oil 75w-90 GL-5 Limited Slip in all three compartments (transfer case, front differential, and rear differential).
    That makes things easy and efficient as far as purchasing and install. Going to use the Mobil1 Synthetic. Need 5.4 quarts to do all 3 locations.
    Anyone know the specs sizes for both the drain and fill bolts in all 3 case locations? Will need to buy the special metric sockets (torx?).
    2002 4wd LS.
  17. Sep 1, 2018 at 11:46 AM
    I’m just trying to remember here, but the rear diff & t-case 24mm
    and front diff is 10mm.
    Watt maker and Casper421 like this.
  18. Sep 1, 2018 at 11:50 AM
    Hand Protectors
    You memory may be correct according to the Youtube I watched. Thanks. It will be a while before I do these changes so there is plenty time for correction if needed. Are these fill plugs metric torx?
  19. Sep 1, 2018 at 11:53 AM
    Casper421
    In the woods
    06 DC
    Amazon has them but I found them cheaper at the dealership. Drain plugs with magnets and washers.
  20. Sep 1, 2018 at 12:05 PM
    Drain plugs are Allen head Metric for the front.
  21. Sep 1, 2018 at 12:10 PM
    Hand Protectors
    I’m assuming my existing plugs are already magnetic as I think the manual suggests? I will need to buy the new crush washers. My main concern right now is size and types of sockets to purchase.
    I’m assuming the fill plugs get reused?
    The drain plugs get reused, but with new washers?
    Socket Sizes? I will be starting my search for used sockets (torx?).
  22. Sep 1, 2018 at 12:10 PM
    Hand Protectors
    Perfect. I have those.
  23. Sep 1, 2018 at 12:11 PM
    Casper421
    In the woods
    06 DC
    No wonder you were recently promoted, correct as usual. 24mm for rear diff and transfer case drain/fill and 10mm hex for front diff.
  24. Sep 1, 2018 at 12:12 PM
    Ha ha. I just have had Toyota’s my whole life.
    Take care of them, run forever.
  25. Sep 1, 2018 at 12:14 PM
    Casper421
    In the woods
    06 DC
    https://www.amazon.com/gp/product/B017V4BAXI/ref=ox_sc_act_title_1_1_1?smid=A3P66KFG79CPHG&psc=1
  26. Sep 1, 2018 at 12:16 PM
    Hand Protectors
    So
    Front diff is 10mm allen metric for fill plug.
    Rear diff and Transfer Case are 24mm allen metric for fill plug.
  27. Sep 1, 2018 at 12:18 PM
    Casper421
    In the woods
    06 DC
    Transfer and rear diff are both 24mm sockets. Front is 10mm hex.
  28. Sep 1, 2018 at 12:18 PM
    Hand Protectors
  29. Sep 1, 2018 at 12:30 PM
    Hand Protectors
    This is good info. Thanks guys!
  30. Sep 1, 2018 at 2:22 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I use the royal purple differential fluid in my 2000 a d my 2013 tundras.It has the limited slip additive and is full synthetic. I also use the transmission fluid in my 2000 tundra.It has 367,000 miles and still shifts good. I also use the transmission fluid in my power steering.
