Cascadia 4x4 VSS Tundra specific Solar System Just Installed
Discussion in '2.5 Gen Tundras (2014-2021)' started by cquilichini, Mar 3, 2021.
  1. Mar 3, 2021 at 11:04 AM
    cquilichini
    cquilichini [OP] New Member
    Hey Guys,
    I just installed the Cascadia 4x4 90 watts front hood mounted solar panel with their mppt charge controller and is a very cool kit to keep your battery always topped out and allows you to run your accessories for longer periods of time without the need to start your truck to also allows you to keep the fridges going almost indefinitely.
    Here some pics of the install.
    bulldog93, CorsoTundra, Voss and 8 others like this.
  2. Mar 3, 2021 at 11:21 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    I see you were able to color match yours :)
    Sweet looking truck and seems like a great idea!
    Black Wolf and cquilichini[OP] like this.
  3. Mar 3, 2021 at 11:37 AM
    cquilichini
    Thanks!
  4. Mar 3, 2021 at 12:02 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Very cool to see...
    Did you mount the panel directly to the hood or did you add a clear film first?
    Any whistle or wind noise?
  5. Mar 3, 2021 at 12:06 PM
    cquilichini
    I added the film they include on the kit. I haven't noticed any noise produced by the panel.
    mountainpete[QUOTED] likes this.
  6. Mar 3, 2021 at 12:11 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Cool! Is it easily removable? Does the kit protect the paint on the hood?
  7. Mar 3, 2021 at 12:14 PM
    cquilichini
    It's installed with 3M double sided VHB tape. It can be removed but is intended to stay permanently. The kit includes a vinyl film to protect the hood.
    619Tundra and Bakershack[QUOTED] like this.
  8. Mar 3, 2021 at 1:44 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    I'm really liking this. A lot. Hmmmm.....
  9. Mar 3, 2021 at 2:10 PM
    Aurora CO
    Can you post a close up of the control box? I'm going to be spending a lot of time at my off grid property this spring and summer. This would be ideal. Especially on a blaaaaack Tunny:thumbsup:
    619Tundra likes this.
  10. Mar 3, 2021 at 2:18 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Any reason I can’t be mounted on the roof?
  11. Mar 3, 2021 at 2:38 PM
    cquilichini
    It can be mounted in the roof but it’s designed to be mounted on the hood.
  12. Mar 3, 2021 at 2:40 PM
    cquilichini
    here you go.
  13. Mar 3, 2021 at 2:40 PM
    Aurora CO
    ......and the roof isn't flat due to the risers in the sheet metal. Might not stay on plus would negate having a roof rack.
  14. Mar 3, 2021 at 2:42 PM
    Aurora CO
    Kuul. But your mounting setup/location. I thoroughly checked out Cascadia's site. I'm really thinking about getting in on the April pre order shipment. Out of stock now.
  15. Mar 3, 2021 at 2:51 PM
    cquilichini
    That I don’t have pictures of. But if you look at the first picture of my post, the charge controller is actually hidden at a cavity on the right back hand by the firewall. You will see the cables with the MC4 connectors from the solar panel if you look closely.
  16. Mar 3, 2021 at 2:53 PM
    Aurora CO
    I do my own wiring and it looks fairly simple actually. Damn it. I'm going to get this. Ha!
  17. Mar 3, 2021 at 2:54 PM
    cquilichini
    Is a real easy project. The wiring cannot be simpler.
  18. Mar 3, 2021 at 2:55 PM
    Aurora CO
    Aesthetically is doesn't look bad at all on black. Prolly look good on white and other colors too.
  19. Mar 3, 2021 at 2:56 PM
    Aurora CO
    I wonder if Cascadia would be interested in a group buy?
  20. Mar 3, 2021 at 2:59 PM
    cquilichini
    I will show you later. I have 2 80watts solar panels in parallel fixed on the truck bed charging the Dometic PLB40 Lifepo battery. I use the battery for my Dometic CFX50 fridge. I have a problem with solar panels.:bananadance::bananadance::bananadance:
    bulldog93 and Black Wolf[QUOTED] like this.
  21. Mar 3, 2021 at 3:01 PM
    Aurora CO
    I think the hood location is ideal. Fitment looks perfect too. A bit different but I like the utility of it there.
  22. Mar 6, 2021 at 2:59 PM
    cquilichini
    Here are the twin 80 watts panels in parallel that I use to feed the Dometic PLB40 directly. Pictures as promised.
  23. Mar 6, 2021 at 5:40 PM
    Aurora CO
    Sweet!
  24. May 31, 2021 at 12:59 PM
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    still happy with this kit? What do you run off it?
    Ryan
  25. May 31, 2021 at 1:54 PM
    cquilichini
    I'm happy with it, I use it right now to keep the truck battery topped. Is a second layer of assurance if my secondary battery fails.
  26. Jun 22, 2021 at 12:18 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    Hey OP, how is the system holding up so far, any issues?
    I'm about to pull the trigger and get one too.
    Thanks
  27. Jun 22, 2021 at 3:18 PM
    cquilichini
    Really good. No problems whatsoever.
    Piki[QUOTED] likes this.
  28. Jun 22, 2021 at 4:35 PM
    Unclebuck
    Unclebuck New Member
    2018 Crewmax SR5 TRD Offroad
    First I have heard/seen this setup. Looks like a reasonably priced setup and easy install.
    I just got my tundra and will be moving my dual battery setup that I had in the Taco to it. I have been running a Redarc BCDC1240 with a 170AH lithium mounted in the rear of the cab and using a foldable Overland Solar 130W panel when in camp. My only goal is to power my National Luna fridge and occasional items through the 1000w inverter...The Cascadia panel looks like it might be something to seriously consider to integrate into my system.
  29. Jul 28, 2021 at 8:01 AM
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    I'm strongly considering this product for my upcoming FJ Cruiser 2022, I think it will look sick on the yellow hood. For the Tundra, I have the Redarc 112W SOLAR BLANKET AMORPHOUS CELLS (SAF1112) with the Dual Input 50A In-vehicle DC Battery Charger (BCDC1250D)
  30. Jul 28, 2021 at 8:01 AM
    1794-BlackTundra
    Sergio
    One can only hope :fingerscrossed:
