Cartridge oil filter drain - there is a better way
Discussion in 'General Tundra Discussion' started by landphil, May 4, 2017.
  1. May 4, 2017 at 12:02 AM
    landphil
    landphil [OP] Fish are food, not friends!
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Well folks, I just completed my first oil change on the ol' 5.7, she was freshly serviced when I bought her used last fall, and I don't put too many miles on. I've done many oil changes during my 15 years as Commercial Truck Tech, most of them 40-45 litres at a time, and don't usually make much mess. Well, tonight I had my first experience with the Toyota cartridge drain system and the wonderful plastic drain nipple. Oil was running off both elbows and I still couldn't get the damn thing to clip in before it was drained, and I was oily and frustrated.
    In my usual way of thinking "There HAS to be a better way", I went looking for a solution. And a solution I did find.
    http://lasertools.co.uk/product/5234/
    https://www.motivxtools.com/products/toyota-lexus-oil-filter-drain-tool
    I ended up ordering the top one from a vendor in the UK, since the shipped price to Canada was the best. I fully expect to leave the "skid pan" in place next oil change. :D:thumbsup:
    If this is old news, feel free to disregard, I'm just excited to be buying a new tool to go with my:
    https://store.snapon.com/Funnels-Spouts-Filler-Oil-Toyota-Lexus-Scion--P646579.aspx
    and my new:
    https://www.amazon.com/Astro-78521-Filter-Socket-Toyota/dp/B00LH05Q88.
    Yota303, bensky, Law323 and 1 other person like this.
  2. May 4, 2017 at 12:16 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Yup; that's a great tool. I've been using mine since I did my first oil change at 10k. I bought mine off Amazon.
    landphil[OP] likes this.
  3. May 4, 2017 at 4:17 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    I did my first oil change a month ago and agree it was a major PITA! I didn't have any trouble with the plastic drain clip but dropping the skid plate sure was a bitch.
    You say you fully expect to leave the "skid pan" in place next time - May I ask how you plan to remove the cover of the filter and replace the cartridge inside?
  4. May 4, 2017 at 6:36 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    My '08 has an opening in the skid pan directly under the filter cap that's just big enough, so no issue reaching up through to drain with the new tool, or remove the filter and cap using the filter socket and long extension. Not sure if 3rd gens have that hole? It looks factory on mine, but then I'm not even sure there.
  5. May 4, 2017 at 6:56 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I've seen a photo of @Spvrtan using his. I just now ordered me one off Amazon and the fumuto drain valve. Oil change time in the next 800 miles :D
  6. May 4, 2017 at 7:04 AM
    West Texas Tundra likes this.
  7. May 4, 2017 at 7:14 AM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    I just watched a youtube video on the filter change, what a pain in the ass. Quick filter housing drain and the filter wrench OR a complete filter re-location kit is going to be a must. Is there a filter re-location kit out there for the 5.7? Found them for the small V8.
  8. May 4, 2017 at 7:56 AM
    JTP
    The Big Black Moose
    Found this and calling the supplier. Im now looking for a spin on filter plate that can be mounted in a handy spot someplace up on the inside of the frame. With all of the additional in and out oil hose that will be required to remotely mount a spin on filter you will have trial and error determine how much more oil you will need to add to the system. My old taco's remote filter lines acted like an oil cooler under the truck and it was nice to carry an additional 2 quarts of oil in the system. Stayed cleaner longer and oil was cooled going through the lines.
    http://www.shop.**************/TR-301-BK-Cartridge-to-Remote-Adapter-TR-301-BK.htm
  9. May 4, 2017 at 8:51 AM
    LibertySand
    LibertySand IH Support Rig
    Montclair, CA
    07 TRD DC 5.7 Tow 4X4
    NOW WE ARE TALKING! Thats what I've been hoping to find! Remote that thing and call it a day, add a second cooler to it and now you have a beast!
    Edit:1
    Ouch! $200
    Edit:2
    So I keep trying to edit this.... the link won't let you go their so go to the website and search for it.... https://www.**************/home.html
    This is the one they recomend for the Tundra
    TS-301-BK (Spin-On) & TR-301-BK (Remote) FITMENT FOR TOYOTA
    Edit:3
    CMON!!!! Why wont the link show?!
    Here is the companies name.
    Baxter Performance.
    JTP[QUOTED] likes this.
  10. May 4, 2017 at 9:00 AM
    JTP
    The Big Black Moose
    Here are the best filter plates that have I found. You can get them at
    speedwaymotors.com
    Im looking for a spot as close to the engine as possible to reduce loosing as much as oil pressure as possible that is coming out of the engine through the filter housing. A small H filter will be just fine i think but I pictured the larger 6" filter plate thats available as well, might be ok too. Will do a little more R&D
    These plates will mount right to the inside of frame
  11. May 4, 2017 at 9:03 AM
    JTP
    The Big Black Moose
    No more skid plate removal and jacking around on oil changes!!
    Lay under the truck, put your drain pan under the filter, screw off the old one, let the lines drain, and screw on a new filter.
    Will probably take at least 2 more quarts of oil in the system for your did stick to read correctly and to fill the lines.
    When I did this to my Tacos I made sure that the to and from oil lines had a little bit of "down hill" slope as much as possible from the engine to the filter bracket so that the oil in those lines would both also drain out when I removed the filter.
    NewImprovedRon likes this.
  12. May 4, 2017 at 9:04 AM
    LibertySand
    Montclair, CA
    Is this just the relocation bracket?
  13. May 4, 2017 at 9:06 AM
    JTP
    The Big Black Moose
    Yes. Its where you can use a screw on type oil filter. You will need the adapter to go on the engine and two oil lines to and from this bracket
  14. May 4, 2017 at 9:17 AM
    SOB
    SOB Big Member
    Ohio
    A pic and dimension of opening would be awesome! My 2nd gen 2013 does not have one.
  15. May 4, 2017 at 10:55 AM
    LibertySand
    Montclair, CA
    Pudge likes this.
  16. May 4, 2017 at 10:54 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Ask and ye shall receive:
    On second look, it does appear to have been hand cut, probably with an air body saw. Oh well, it has no sharp edges, and saves me the bother of cutting my own.
    SOB[QUOTED] likes this.
  17. May 5, 2017 at 3:16 AM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
  18. Oct 27, 2019 at 3:12 PM
    tundraforme
    tundraforme New Member
    Em
    Vancouver, BC
    2018 Tundra TRD Off Road Quicksand
    Just started reading up on this as I am done with paying someone else to do my oil change only to have oil spilled all over my RCI skid plates.
    I'm looking at getting a fumoto valve for the drain port but I stumbled upon your post. (and I apologize if this is a dumb question but I'm learning and I want to make sure that I understand this) Is this so that I can have an external filter instead of the cartridge filter? What did you end up using? Do we have enough clearance for a canister?
  19. Oct 27, 2019 at 4:13 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I just keep the little plastic drain tool that comes with the filters. Go to hard ware store and get a couple feet of 3/4" hose for $2. Insert that on the drain tool and insert into the bottom of the oil filter cartridge and no mess. Exact same thing as above.
    As far as the drain plug goes on my 19 there is sort of a recessed opening and the skid plate does not get in the way nor does it have to be removed to drain the oil with no mess. Easy peasy nice and easy.
    with that being said, I have an RCI skid sitting in the garage and will be installed this week when I do my 25k maintenance.
  20. Oct 27, 2019 at 5:18 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I can't ever get the plastic drain plug to clip into place. I agree, kinda sucks big time. Just like the upcoming weather....
  21. Oct 27, 2019 at 5:47 PM
    tundraforme
    Em
    Vancouver, BC
    I've go the RCI skid plates on already and the little door is too little for me which is why I want the Fumoto on it. And the more I research it, the more I want the BP Adapter so I can put an external canister style filter on.
