Cap size
Discussion in 'Tonneau Covers, Caps and Shells' started by gegs310314, Oct 6, 2021.
  1. Oct 6, 2021 at 11:59 AM
    gegs310314
    gegs310314 [OP] New Member
    St. Louis
    2019 Platinum
    I found an old Dakota cap for dirt cheap. It’s 5.6 1/2 long by 5.3 wide.
    the crewmax bed is 5.53 wide and 5.5 long. But I don’t know if that’s from the inside of the bed or from the outside, panel to panel.
    Anyone rocking a not perfect fit cap?
  2. Oct 6, 2021 at 12:46 PM
    SouthWestGA
    SouthWestGA New Member
    The tundra beds are curved different than other manufacture beds
    I have not seen reports of a different truck brand fitting any tundras regardless of the generation
    It is possible I could be wrong,but after owning tundras since 2013 I haven’t seen any reports of it
  3. Oct 6, 2021 at 1:15 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I have tried and used Ford DCU shells on the 2nd gen tundra and no real issues at all.
    The Commercial DCU shells are made of Metal usually and the sides sit on top of the bed rails where it does not matter whether they match the curve of the bed sides at all.
    Fiberglass is obviously a different story entirely and hit or miss for a decent fit but I imagine mostly a miss!
    Fiberglass shells usually sit over the edge of the bed side and if the curve of the shell is not a direct match for the curve of the bed then it will probably not sit right or seal from weather correctly even with rubber weatherstripping under the shells rail surface.
    But sure I have seen some pretty crazy mismatches that seem to work for someone else we each have our own threshold for living with this stuff for sure.
    2mchfun and SouthWestGA like this.
