Can't see my Climate Control Display - 07 Sequoia
Discussion in 'Sequoia 1st Gen (2001-2007)' started by fuegoman, Apr 20, 2020.
  1. Apr 20, 2020 at 2:45 PM
    fuegoman
    fuegoman [OP] New Member
    2017 Tundra TRD SR5
    Hello all -
    Like the heading says, I can not see my climate control display. At the right angle I can sort of make out some images on there. I replaced the lights behind it with LED lights and still did not help.
    Has anyone run across this before? I will add pictures later today.
    Thanks as always!!
  2. Apr 20, 2020 at 2:49 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  3. Apr 20, 2020 at 5:06 PM
    fuegoman
    2017 Tundra TRD SR5
  4. Apr 20, 2020 at 5:37 PM
    Mnorris1206
    08 tundra
    I know this is not what your asking for but they are not to expensive used. I would probably just replace it. But does seem strange amd there are lights on for all the rest of the dash ?
  5. Apr 21, 2020 at 3:59 AM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    Loose plug?
  6. Apr 21, 2020 at 8:57 PM
    fuegoman
    2017 Tundra TRD SR5
    I fixed the issue. Let's just say, polarity matters :)
    Thanks for the help and suggestions :)
  7. Dec 10, 2022 at 6:10 PM
    MelBell68
    MelBell68 New Member
    I know this was a while ago…but what was the solution? I have the same issue but I’m not sure what to check.
  8. Dec 10, 2022 at 7:32 PM
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    Based on what the OP wrote he installed his LEDs with the polarity reversed, thus no output from the LEDs. Not entirely clear from his descriptionof th eoriginal problem, but it sounds like his incandescents were out and he replaced them with LEDs. But he polarity being reversed they didn't work/ So he turned the bulbs to correct the polarity and all was well.
    landphil likes this.
