Can't get much closer
Discussion in 'Suspension' started by LWF73, Jun 8, 2018.
  1. Jun 8, 2018 at 2:13 PM
    LWF73
    LWF73 [OP] New Member
    Lief
    Mena, AR
    2008 White Tundra
    Tires 295/55R20, 5100 Bilstein shocks all around
    Just installed Bilstein 5100 on front at the middle setting. The tires are 295/55R20 Nitto Grappers on factory 20" rims with +60 offset. Not sure if I can get much wider. Might be able to go a bit taller thou.
