Can't decide on wheels
Discussion in 'Wheels & Tires' started by must2fa, May 23, 2017.
  1. May 23, 2017 at 3:51 PM
    must2fa
    must2fa [OP] New Member
    I have a slate metallic 2010 tundra with a leveling kit. Can't decide between moto metal 962 or method wheels.
    Going for 20x9 0 offset. What do you guys think will look better?
    Eclipsed & Floating likes this.
  2. May 23, 2017 at 3:56 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    962's are nice ... But which Method model are you thinking of?
    +0 offset with a level will probably require a cab mount chop. I just recently pushed mine out to a -5 offset with 295/60's and will require it.
  3. May 23, 2017 at 4:05 PM
    must2fa
    I was thinking between method nv or double standard all black.
  4. May 23, 2017 at 4:05 PM
    must2fa
    How hard is it to chop a cab mount? Any disadvantages of doing that?
  5. May 23, 2017 at 4:26 PM
    r4z0r51o
    Dave
    Both of those Method models are nice ... Similar 12 spoke wheels. Without seeing them in person to compare the differences it's hard to say which I'd prefer. I've always liked 8 spoke wheels and wish Method made one.
    As for the CMC, I don't know how hard it is to do. Still need to do it ... But from my own research it doesn't seem hard to do as long as you find a good person to weld in new CMC plates. No disadvantages that I'm aware of.
    must2fa[OP] likes this.
  6. May 23, 2017 at 11:17 PM
    must2fa
    So finally decided to go with method mesh +18 offset to a avoid too much cutting.
    I found them on eBay for a good price, but before I order the listing says bore size 116.5. Is that going to be a problem?
  7. May 23, 2017 at 11:28 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I'm not verse in bore size but other guys are sporting the same wheels but most are 18s. They are really good looking wheels but the 20s make tires more expensive. Are you lifting the truck at all? The cutting isn't a big deal but as far as I know the 20s might make it necessary depending on tire size. I'm certainly not an expert in sizes but this thread is:
    https://www.tundras.com/threads/largest-tire-you-can-run-stock-for-all-generations.9762/
  8. May 24, 2017 at 5:47 AM
    Post pics of what ya want n start a vote
  9. May 24, 2017 at 6:04 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    Those Method Mesh wheels are really nice looking, good choice.
    That bore size is larger than the hub of a 2010 Tundra (110mm, if I recall). It will only cause problems if the wheels are not properly installed. If the correct lugs are used and torqued properly (I think 95 lb-ft) you should be fine.
    Post pics!
  10. May 24, 2017 at 6:30 AM
    must2fa
    Trying to find 20x9 +18 with 110 hub bore. Will post pics soon!
  11. May 24, 2017 at 6:41 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    the only disadvantage is cost
  12. May 24, 2017 at 12:05 PM
    madmax17
    madmax17 New Member
    Rent
    2017 Toyota Tundra Limited Crewmax
    2.jpg 3.jpg 1.jpg Here are my Moto Metal 962's, 20x9 with a zero offset
      File size:
      95.9 KB
      441
      File size:
      94.8 KB
      466
    must2fa[OP] and Jsena like this.
  13. May 24, 2017 at 12:24 PM
    must2fa
    Just placed the order for the wheels. Will my stock lug nuts and tpms work with the new wheels and tires?
    Jsena likes this.
  14. May 24, 2017 at 1:09 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    tpms yes, lug nuts no. If you have steelies, you have to flip them.
    Jsena likes this.
  15. May 27, 2017 at 1:59 PM
    must2fa
    Got the leveling kit installed today. Waiting on wheels to be delivered.
    Voyagermike likes this.
  16. May 27, 2017 at 2:00 PM
    must2fa
    Munk and Voyagermike like this.
  17. May 30, 2017 at 10:30 AM
    must2fa
    Got the 3/1 leveling kit installed but noticed the front two tires are sinking in from the bottom?
  18. Jun 3, 2017 at 2:49 PM
    must2fa
  19. Jun 5, 2017 at 7:17 AM
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    looks good
  20. Jun 5, 2017 at 7:18 AM
    Eclipsed & Floating
    Voluptuous Whitey
    You chose well
  21. Jun 8, 2017 at 11:41 AM
    dmeneses1983
    dmeneses1983 New Member
    Dennis
    2016 Silver Tundra
    Get the scs sr8 they're the cleanest wheels I've seen on a Tundra
