Canadian Prices 2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by ThePolak, Nov 4, 2021.
  1. Apr 1, 2022 at 12:36 PM
    #781
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Hybrids are (finally) on the Canadian 'Build & Price'.
    Mattedfred and Keon like this.
  2. Apr 1, 2022 at 12:47 PM
    #782
    Keon
    Keon New Member
    Canada
    22 Pro Solar Octane '10 Jeep Wrangler
    THANK YOU! I have been checking every day.
  3. Apr 1, 2022 at 12:55 PM
    #783
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    You and me both. Nice choice on colour, btw.
    Keon[QUOTED] likes this.
  4. Apr 1, 2022 at 1:08 PM
    #784
    Keon
    Keon New Member
    Canada
    The world needs more color! :D
    Mattedfred and DesmoDoe[QUOTED] like this.
  5. Apr 1, 2022 at 1:16 PM
    #785
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    can you explain to me what the attraction is to the hybrid ?
    mileage - about the same - and not many achieving EPA right now.
    non hybrid 21/27/23
    hybrid 22/27/24
    lost payload and lost storage space under seat.
    heavier, even more complicated with battery tech going to be changing alot next couple years
    Outbound likes this.
  6. Apr 1, 2022 at 1:19 PM
    #786
    Keon
    Keon New Member
    Canada
    Power, and the fact that the electric motor makes 184 lb ft of torque, which will eliminate the need to really get into boost. This should help the hybrids get close to EPA milage. Toyota Hybrids have a bit of a learning curve; once you figure out how to maximize fuel efficiency getting or beating those numbers is easy. I can get under 6 L/100km in a RAV4 hybrid with 2 passengers in mixed driving on winter tires with steel rims easily. At first, I was getting ~8 L/100km in those same circumstances. And I don't avoid flooring it while heading up the on-ramp.
    Armament, =JSG= and DesmoDoe like this.
  7. Apr 1, 2022 at 1:25 PM
    #787
    borla123
    borla123 The Pits
    Ontario
    So you are implying Toyota is full of shit with their EPA ratings.
    If what you are saying is true about hybrids using less boost the numbers should be higher for the hybrid.
    Reality is this is not true and the reason the EPA is what it is.
    It a heavy truck with a V6.
    You are going to use boost unless you are doing granny throttle commuting on the highway.
  8. Apr 1, 2022 at 1:25 PM
    #788
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Don't think of it as a hybrid, think of it as the bigger engine option. That's how Toyota introduced it and has marketed it for the most part.
  9. Apr 1, 2022 at 1:34 PM
    #789
    borla123
    borla123 The Pits
    Ontario
    ok bigger engine option.
    that makes more sense as far as horsepower - torque.
    but
    you are losing payload.
    and the tow factor is about the same (20lbs)
    losing storage space
  10. Apr 1, 2022 at 1:34 PM
    #790
    Keon
    Keon New Member
    Canada
    What I'm saying is that Hybrids are less likely to need to be in boost for commuting, since the torque that would be provided by the turbochargers when they're spooled up is substituted for by the electric motors. Obviously, the engine will be producing boost at cruising RPMs, just not the full 20 PSI of it. For now, everything is speculation and reasoning. I will follow up with the fuel economy I am getting during and after the break-in period.
  11. Apr 1, 2022 at 1:45 PM
    #791
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Go take a peak at the 5.3L vs 6.2L GM/Chevy engine options and their towing/payload capabilities, this isn't unique to Toyota.
    For me personally, maximizing payload numbers isn't the reason I'm buying a Tundra. For payload and hauling duties, a Tacoma would do me fine, but I have a wife and 3 kids. Have you every tried putting three car seats in a Tacoma and hitting the road for an 11 hr drive?
    In addition, the TRD Pro is only available with the iForce Max so if one wants that model they don't have a choice, do they?
  12. Apr 1, 2022 at 4:30 PM
    #792
    borla123
    borla123 The Pits
    Ontario
    gmcguire7220 likes this.
  13. Apr 4, 2022 at 8:38 AM
    #793
    borla123
    borla123 The Pits
    Ontario
    So the Cdn Fed govt giving GM Canada $259 million taxpayer dollars - announced today for electric vehicle plans in Oshawa and Ingersoll plants.
    Hopefully those jobs remain in Canada.
    Honestly with all the push to electrification, I assume all hybrid buyers are doing leases or something they can get out of quickly in a few years and not take a big $ hit? I think the tech in vehicles will be much different in a few years time.
  14. Apr 4, 2022 at 9:02 AM
    #794
    Zarex
    Zarex New Member
    super sadge that you can't get the Platinum hybrid with 6.5ft box in Canada, waited so long to pre-order a hybrid to be told no cause reasons
    Armament likes this.
  15. Apr 4, 2022 at 1:13 PM
    #795
    Keon
    Keon New Member
    Canada
    A platinum long bed hybrid would be heavy enough to need a tag axle!
  16. Apr 4, 2022 at 1:16 PM
    #796
    Zarex
    Zarex New Member
    It's available in the states thou and the only diff is about 400 lbs gross weight between them. you can get a Limited long box hybrid as well its just the Canadian Platinum L that you can't for some assinine reasoning
  17. Apr 6, 2022 at 7:55 AM
    #797
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    2023 Supersonic Red Platinum Hybrid
    Just put a deposit down for the Platinum Hybrid, and was told I'm on a waiting list, 14th to be exact which will put me into a '23 MY Tundra. Was told that the dealer allocation is 12 Hybrids for this year, and that's exactly what I wanted, a '23 MY.
    I know I had posted some questions about ordering the '22/'23 Tundra over in this post, but has anyone had any luck financing their truck elsewhere than Toyota? The 4.99% Toyota interest rate is just absurd, and wonder if anyone had any luck with seperate banks? I see Ford, Chevy/GM offer interest rate between 1.99 and 2.99 which is much better than the 4.99 Toyota offer...
    I have checked HELOC, but not sure if it's something I'm wanting at this moment.
  18. Apr 6, 2022 at 8:20 AM
    #798
    Mattedfred
    Mattedfred Toyota Fan Boy Since ‘04
    Ted
    Cambridge, Ontario Canada
    2023 SR5 TRD Sport DC 4X4 in MGM
    TRD Skid Plate/Running Boards, Bison Soft Rollup Tonneau, Thule Canoe Rack, Bedmat, Tailgate Black Insert Badge, Northwest Seat Covers Neoprene Custom Fit Front Row Seat Covers. Tailgate Mat
    Sorry I can't answer your question. However, what do you feel the disadvantages are with the HELOC route? What's the difference in the end? You get the money you need at a lower rate and if the shit hits the proverbial fan (job loss etc) you can reduce your payments to the interest only.
  19. Apr 6, 2022 at 8:24 AM
    #799
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    The only reason not going HELOC route at this time is that we wanted to also use that to do some house renovations in the next year or 2. But I guess it doesn't hurt to check!
  20. Apr 6, 2022 at 8:28 AM
    #800
    Mattedfred
    Ted
    Understood. I feel that it would be worth the effort. Perhaps your house will be worth more in the future. If so, I wonder if the bank would be quite happy increasing your HELOC to cover the costs of your reno also. At the end of the day your in debt to someone for the same amounts. You're just looking for the best way to decrease the cost of carrying that debt.
  21. Apr 6, 2022 at 8:32 AM
    #801
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    All the banks I've talked to have said they cant beat the dealer rate. I'm going to look into the HELOC but i'm more likely going to just take out the longest finance term possible then pay it off as fast aa poasible. Take the 96 month term, pay it off in 36 months kinda thing.
  22. Apr 6, 2022 at 8:38 AM
    #802
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    100% with you on this, I'll check with my bank, I have some time to figure it out!
    Oh really, that's surprising that no banks cant beat the Toyota rate, which I find it very high at 5-6%.
    Toyota offers 96mths?
  23. Apr 6, 2022 at 8:45 AM
    #803
    Outbound
    Aaron
    Northern Alberta
    The banks do a prime + rate when it comes to loans. Prime is 2.70% right now if I remember. From what I've been told, prime + 3 or 4% is normal which puts you 5.7% - 6.7%, higher than Toyotas 4.99%. My unsecured line of credit is prime + 5% iirc.
    Toyota does offer 96 months, at least they did when I put the deposit down on my '22 in Feb. When you really run the numbers, if you can pay off the loan early you can minimize the interest paid because your extra payments go directly against the principle of the loan. Same concept as paying off a mortgage by doubling up payments, you'll pay less interest overall. Without figuring out the exact math, if I take a 96mo loan at 4.99% but pay it off in 36mo, the actual interest I pay may work out to more like 2.99 or 3.5%. Somebody better at math would have to confirm that though. All I know is pay it off sooner, less interest paid overall.
  24. Apr 6, 2022 at 8:53 AM
    #804
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    Oh, makes complete sence, and that's what I've also been doing for my house mortgage! Didn't think it was an option with Toyota, but I guess I may be wrong!
    Outbound[QUOTED] likes this.
  25. Apr 6, 2022 at 9:10 AM
    #805
    Mattedfred
    Ted
    Obviously we all know that you'll always pay more for an unsecured LOC. Granted this was nearly 16 years ago, but we negotiated a HELOC at Prime+1, with no setup fees. I could be wrong, but I feel that it's the least expensive borrowing option if you have enough equity in your home.
    jproy12 and Outbound like this.
  26. Apr 6, 2022 at 11:06 AM
    #806
    borla123
    borla123 The Pits
    Ontario
    Re: the HELOC discussions. JMO
    its ok to hedge on an investment with a HELOC that will appreciate and pay only the interest, but on a depreciating asset like a vehicle?
    The Bank Of Canada is raising rates again at the next mtg. Most industry folks feel it will be a 1/2 per cent increase, doubling the current rate.
    Make a note of that if you are taking a fixed loan rate. Otherwise the Heloc secured or not, interest rate goes up or down with the bank rate as its a variable rate, unless you convert it, or a portion into a fixed mortgage. I am not a financial advisor but I have lived this personally.
    also as a note.
    the government finally realized that people were using HELOC's to help buy homes and pay only the interest every month. This contributed to the increasing house prices. Maybe there will be something in the budget Thursday to curtail this. we will find out soon !
    jproy12 likes this.
  27. Nov 21, 2022 at 4:49 AM
    #807
    borla123
    borla123 The Pits
    Ontario
  28. Nov 21, 2022 at 5:41 AM
    #808
    jproy12
    jproy12 ¯\_ (ツ) _/¯
    JP
    Ottawa, Canada
    But are they really? I was told that dealers in Canada can't add the said "market adjustment", but again, anything is possible.
    Unfortunately, it'll come bite them in the long run, people will remember which dealer charged over MSRP to take advantage of the situation
  29. Nov 21, 2022 at 12:26 PM
    #809
    borla123
    borla123 The Pits
    Ontario
    I interpret this as something different than selling above MSRP. It's to deal with the extraordinary expenses and costs from supply chain issues - shortage of chips, etc..
    Dont have a sales agreement handy to see the language that is used, maybe see where a loop hole exists.
