Can you have a non fob key for the door?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joe333x, Nov 21, 2019.
  1. Nov 21, 2019 at 3:05 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    2019 Tundra CrewMax Platinum
    I was a bit disappointed that they no longer do valet keys. Sometimes in the summer I leave my dogs in the vehicle with the AC running and lock the doors and use the valet to open the doors after. If I have a blank key cut to fit will it work just to open the door lock? Also the dealership never gave me that little piece of metal with the number to make a key on it, does that really matter? I'm assuming more people lose that than don't.
  2. Nov 21, 2019 at 5:55 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Yes, I do this all the time in the winter. I start it up then use the key to lock it, I'm too cheap to get a remote start! Leaving dogs in your truck and you lock it? When I leave my rottie in my truck, never had to lock it, even with the windows open!:thumbsup:
    Joe333x[OP] likes this.
  3. Nov 21, 2019 at 6:03 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Cool thanks, were you able to get a key cut at a typical hardware store? Haha good point, I have a lab mix and a hound, I'm sure they'd scare off any would be thieves but just feel safer with the truck locked.
  4. Nov 21, 2019 at 6:03 PM
    biebs96
    PA
    Yes it will work. My old man always told to have a spare key cut... it doesn’t have to start the car, just get you in.
  5. Nov 21, 2019 at 6:05 PM
    johnvan
    johnvan OG
    john
    Rensselaer,New York
    2016 inferno SR5 DC
    Yes any store should be able to cut your key.
  6. Nov 21, 2019 at 6:24 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Thanks guys!
  7. Nov 22, 2019 at 3:31 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Great timing for this thread with winter upon this Tundra-owning brother.
    So can I?
    1. Leave my Tundra running
    2. Parking brake engaged of course
    3. Keep the FOB separate from the key which is in the ignition
    4. Step out, shut the door and lock with the FOB with the engine running
    5. Re-enter the Tundra by unlocking with the FOB and withOUT setting off the panic alarm?
    Thanks, brothers. Have a great weekend!
  8. Nov 22, 2019 at 4:31 AM
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I had a non fob key cut for the door. When I go kayaking, I leave the ignition key locked in the safe in the truck and bring only the door key with me in case I get wet.
  9. Nov 22, 2019 at 4:46 AM
    biebs96
    PA
    The truck won’t lock with the fob if it is running. If you use a regular metal key, you can lock the doors from the driver side, as well as unlock the doors and get in without setting anything off.
  10. Nov 22, 2019 at 4:50 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Since I locked myself out of my truck once, I had this made. Unlocks the door, but won't start the engine. I keep it in my wallet20191122_074856.jpg
  11. Nov 22, 2019 at 9:19 AM
    Haggis777
    SW Michigan
    Thanks for the clarification, biebs96! I have a spare key like RacingJohnDeere55 that I will break out for the winter then. Thanks to both!
    Racingjohndeere55 likes this.
