Can level TRD dual exhaust?
Discussion in 'Performance and Tuning' started by NHPig, May 4, 2019.
  1. May 4, 2019 at 8:51 AM
    NHPig
    NHPig [OP] Toyota For Life
    New Hampshire
    Super White 2016 Tundra Limited TRD CrewMax 5.7L V8
    I can't for the life of me level two two exhaust tips on the TRD dual exhaust. I tighten up bolts and the drivers side is too high. I put the used hanger on the driver's side and it doesn't help.
    Any thoughts?
  2. May 4, 2019 at 10:09 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    new rubber exhaust hangers for both sides maybe? I don't know to be honest.
  3. May 4, 2019 at 10:14 AM
    AZCementTundra
    AZCementTundra Member
    AZ
    2018 TRD OR 4x4
    6112/5160, TRD (Dual Exhaust, Skid, Rear Sway), Durobumps, Rigid D-Series Pro, Talons Cat Skids, 275/70/18 KO2s
    Few things to try others have had success with:
    New rubber hanger
    Hose clamp around the used rubber hanger to tighten it up
    I used a jack stand during install to hold up the pipe in place while i tightened the bolts
  4. May 4, 2019 at 10:38 AM
    NHPig
    New Hampshire
    I tried jacking up the low one quite a bit before tightening. Honestly the low one is where I think the tip should be.
    The driver's side is too close the paint/bumper.
    I'm wondering the driver's lean is contributing in some weird way.
    AZTundra likes this.
  5. May 4, 2019 at 10:42 AM
    AZTundra
    Paul
    Phoenix, AZ
    I have the same problem (driver's side needs to come down about 1 -1.5"). I'm going to take a look at it again this afternoon. I'll let you know if I solve it. Two suggestions so far are to loosen the 3 bolts between the tailpipe and muffler section and rotate and re-tighten. I might use a jack stand or something similar to hold the tailpipe at the correct height. Other option is to lower the drivers side hangar where it's bolted in place by using washers or some type of spacer to force the pipe lower - this would probably require a new longer bolt.
  6. May 4, 2019 at 10:50 AM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    A friend held up the passenger side while I tightened the nuts. Both sides are level.
    P-Factor likes this.
  7. May 4, 2019 at 11:01 AM
    NHPig
    New Hampshire
    I used a floor jack to "twist" the whole system, so the passenger side would be higher, driver's side lower. I first did it to the muffler, when I tightened the bolts to the cat. Then I jacked up the passenger tip.
    I have two new and one used rubber hanger to use on the rear two hanger locations. No combination seems to work.
    I'm sure I am missing something simple somewhere.
    I definitely have a driver's side lean, something I am thinking should be fixed with some shims. But, I don't see it directly fixing an exhaust that is attached to the body. The tips compared to the axle seem pretty freakin' close.
  8. May 4, 2019 at 11:24 AM
    AZCementTundra
    AZ
    2018 TRD OR 4x4
    Keep in mind the install instructions from Toyota stated, "While tightening the bolts, set a gap of 30±5 mm between the exhaust tip and the rear side panel".
    That's only about 1.2".
    I was able to get them level with the jack stand method.
  9. May 6, 2019 at 10:18 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Drill the holes bigger on the flanges. Or even slot them.
    TXDrifter likes this.
  10. May 6, 2019 at 3:02 PM
    NHPig
    New Hampshire
    Big shout out to Keith @dirtydeeds . While I was once a customer, I didn't buy this exhaust from him. Despite that, he still returned my phone call and we discussed the fix above... Haven't dived into it yet, but the fix makes perfect sense in my head!
  11. May 6, 2019 at 3:26 PM
    P-Factor
    P-Factor New Member
    Ditto! As Red Freighter said! :thumbsup:
