Can I put bigger tires on my rims?
Discussion in 'Wheels & Tires' started by mike11895, Nov 21, 2020.
  1. Nov 21, 2020 at 7:35 AM
    mike11895
    mike11895 [OP] New Member
    2010 tundra doublecab long bed
    Hey all, I currently have 275/65r18 116s m+s goodyear wrangler tires on my 2010 tundra and need new tires. Want to get some good all terrain tires bf goodrich(any recommendations though?). But my main question is can I go a size up? Like 285? With the same rim...
    TIA!
  2. Nov 21, 2020 at 8:31 AM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If you have stock suspension, you can fit 275/70R18’s on them, which are about an inch bigger in diameter and are available in a lot of different all terrain treads. If you’ve got a lift or leveling kit installed, then you can likely go a bit bigger.
  3. Nov 21, 2020 at 8:46 AM
    mike11895
    Thank you !
  4. Nov 21, 2020 at 8:54 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Going from a Duratrac to an All Terrain is not advised in my opinion. All Terrains are the most marketed tire on the market and pretty much the only reason you see so many of em, highly overrated. Get a bigger size sure but do some more tire research before just diving into All Terrains like everyone else.
  5. Nov 21, 2020 at 8:55 AM
    RainMan_PNW
    Casey
    Clark County, WA
    I ran Goodyear Duratracs in that size, and BFG KO2’s both with good results on my 2008. Currently I’ve got Falken Wildpeak A/T3W (in a larger size) on my 2021, but have only had them a few hundred miles. So far they are great. Lots of people like the Nitto’s too
    BravoDeltaRomeo likes this.
  6. Nov 21, 2020 at 8:56 AM
    RainMan_PNW
    Casey
    Clark County, WA
    All Terrain is a style of tread... are you specifically referring to the BFG KO2?
  7. Nov 21, 2020 at 8:57 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I'm lost. Can you explain why an AT tire is so bad
    RainMan_PNW likes this.
  8. Nov 21, 2020 at 9:19 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    an AT is not bad, great all around tire. AT and MT tires do not ride or handle as well as a "road" tire. However, all tire types have considerations and strengths. Highway or touring tires perform great on road and in wet, but are weak and have limited traction off road. AT tires generally are good on road and off, but are heavier and louder than a street tire. MT tire do well in mud and heavier offroad conditions, but are not as good on road, wet pavement, etc.
    I think they were just saying to think about how you use your truck and what types of tire may be best for the driving you do vs. running an AT or MT because they look cool.
  9. Nov 21, 2020 at 9:25 AM
    mike11895
    I don't give a shit what it sounds like or feels like I haul alot of stuff in the bed and pull a landscaping trailer so I want a heavy duty good quality tire that also looks good and deep. I just don't like the "puffy ness" look of the goodyear wrangler if you see what I mean...
