Can I drop this a bit?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2RIVERS, Apr 15, 2022.
  1. Apr 15, 2022 at 9:21 AM
    2RIVERS
    2RIVERS [OP] New Member
    Hello, new member here. Alot of great information, thank you.
    My third Tundra, this is a 2021, purchased with a dealer installed 3-1 Pro Comp leveling kit (65225K), Fuel 20" wheels (not sure of the offset- maybe pics will help...?), & 285-55-R20 K02's. I also installed Firestone air bags since I tow a boat & TT on occasion.
    My question(s): Could I change the kit to a 2"-0" (or a 1.75") to reduce what I'm starting to think is excessive space between the tires & fenders? I do not want to trim much if anything, nor do I want any rubbing. If I do that should I remove the 1" block in the rear?
    I measured the actual spacers in the front and they measure 2"- best I can tell but the PC kit specifically says 3"-1". Maybe that's what it raises the front and not necessarily how many inches the spacers measure...? Any help is appreciated.
  2. Apr 15, 2022 at 9:29 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Front spacers in front dont provide A 1:1 ratio on size to lift. Meaning that the 2" spacer will give you more than 2" of lift. If you have airbags I would remove the rear shackle. From what I see the truck looks great. The back end sits hihgher for towing and hauling so that when its weighted you can sit level. But if you have the airbags this is not needed. Id say level it and call it a day (by removing rear spacer only). I would also install the daystar cradles for the airbags. It will improve the ride and give more droop room for the rear.
  3. Apr 15, 2022 at 9:38 AM
    2RIVERS
    Great, thank you. Are you suggesting a smaller 2" front level & remove the rear 1" block will accomplish what I'm considering? If so, do you think I'd have any rubbing issues with these wheels/tires?
  4. Apr 15, 2022 at 9:44 AM
    Tundyfundy
    Bay Area, CA
    Im suggesting to level it. From the looks of the truck I don't think you'll have to mess with the front to do that. Looks like the rake is over a 1" rake in the rear. Hard to tell for sure without measuring it. removing the block from the rear shouldn't give you any rubbing issue in rear. As far as lowering the front I'm not sure. Its so dependent on rim, tire, suspension setup. I know guys doing a Body Mount Chop is fairly common, which is the area of the frame which most likely rubs if you do get rubbing. I have also heard about some rubbing on the front plastic liner which can just be heated and pushed out of the way. Ill leave it to the guys that have amore similar setup as you. Good luck!
    Heres the cradles
    https://www.amazon.com/Daystar-desi...r+airbag+cradles+tundra,automotive,156&sr=1-1
  5. Apr 15, 2022 at 9:54 AM
    2RIVERS
    Really appreciate the feedback. I'll see what some others have to say as well. Have a great day.
    Tundyfundy likes this.
  6. Apr 16, 2022 at 2:25 PM
    2RIVERS
    So I looked at the back of my wheels and I think they are +1 offset. Its stamped ET:1?? If that’s the case could the experts weigh in on if a 2” (0” rear) will work with 285-55-R20’s?
  7. Apr 16, 2022 at 2:44 PM
    The 2nd picture looks level to me. It's hard to tell from the pics. The ET 1 is the offset, it is often referred to a 0 offset as well. I have the same wheels. If you do remove the rear block, replace the ubolts. They are designed as a 1 time use.
  8. Apr 16, 2022 at 2:55 PM
    2RIVERS
    Thanks for the info, I’m basically trying to drop the entire truck down from a 3-1 to a 2-0 and am wondering if everything will clear in the front with the 20x9 ET 1 wheels and 285-55-R20 tires. I don’t really mind the tire size and love the wheels but trying to reduce the distance between the tires and the fenders.
  9. Apr 16, 2022 at 2:57 PM
    Search customoffsets.com. You may find something there. I think you can search by offset, wheel size, tire size, etc.
  10. Apr 16, 2022 at 5:23 PM
    2RIVERS
    Will do, thank you.
  11. May 12, 2022 at 5:05 AM
    2RIVERS
    Update for anyone interested. I pulled the 3-1 & installed a RC 1.75"-0", I think the 285/55/20 K02's look much better with less wheel well- think I could go 285/60 next time around. Handles better & rides better too. Maybe I'm getting old but I'm very happy with the results.
    Pretty straight forward removal/installation. Firestone airbags have about 7 psi I think in these pics so the rear could be dropped another 1/4" or so...?
    bgdv1, Tundyfundy and radon222 like this.
  12. May 12, 2022 at 5:17 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Looks good either way but if I had to choose one I’d say you did it right by lowering it a little. More proportional with that particular tire size. Nice job!
    2RIVERS[OP] likes this.
  13. May 19, 2022 at 3:18 PM
    Tundyfundy
    Bay Area, CA
    Looks great
  14. May 19, 2022 at 6:55 PM
    2RIVERS
    Thanks gentlemen, appreciate the feedback.
